Tyr13 Posted October 10, 2017 Share Posted October 10, 2017 (edited) Just something weird about the wording for the Heavy Quad Launcher. It says "If this model is reduced to 0 wounds, roll a D6 before removing it from the battlefield, and before any embarked models disembark. On a 6+ it explodes, and each unit within 6" suffers D3 mortal wounds.". Now, ignoring the obvious copy-paste from transports, it doesnt actually say anything about *which* model is reduced to 0 wounds. So, technically crew would explode. Im not really going anywhere with this, I just thought it was kind of amusing. Though if someone is actually going to use that in a game, Id like to hear about it. (and yeah, its not just the Quadlauncher, it seems to be every manned artillery piece. I just noticed it first on the Quadlauncher. ) Edited October 10, 2017 by Tyr13 Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/ Share on other sites More sharing options...
librisrouge Posted October 10, 2017 Share Posted October 10, 2017 Heck, I might just try this in the future. Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4905882 Share on other sites More sharing options...
Halfpint100 Posted October 10, 2017 Share Posted October 10, 2017 Technically you are correct. Slight oversite on FW part Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4905923 Share on other sites More sharing options...
CoffeeGrunt Posted October 10, 2017 Share Posted October 10, 2017 Well Gunner Jenkins might drop the shell he's loading if he gets shot. :P 3 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4905932 Share on other sites More sharing options...
Tyr13 Posted October 10, 2017 Author Share Posted October 10, 2017 Technically correct. The best kind of correct. ;) 1 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4905993 Share on other sites More sharing options...
Withershadow Posted October 10, 2017 Share Posted October 10, 2017 If you take two separate guns, it doesn't require specifically its original crew models to be nearby to fire. So you can keep one crew by the guns, continuing to fire both, while running the other crew (preferably composed of models holding the shells) forward as suicide troopers. :D This is so dumb it's genius. 1 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906073 Share on other sites More sharing options...
Tyr13 Posted October 10, 2017 Author Share Posted October 10, 2017 Who needs the Cyclops anyway... <.< 1 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906105 Share on other sites More sharing options...
Lord_Caerolion Posted October 11, 2017 Share Posted October 11, 2017 (edited) If you take two separate guns, it doesn't require specifically its original crew models to be nearby to fire. So you can keep one crew by the guns, continuing to fire both, while running the other crew (preferably composed of models holding the shells) forward as suicide troopers. :D This is so dumb it's genius. In the depths of their oldest archives, the Death Korp found references to an ancient weapon known as the "dreadsock". Lacking the STC for such a device, they improvised, to create... the EarthshakerSock! Just because you don't have artillery doesn't mean those shells are useless. Just grab one standard Munitorum-issue infantry-class fabric-based-foot-undergarment, place one (1) artillery shell inside, and you're ready to slap a 'tic! Show those Orks with their so-called "tankhammers" that good old Imperial technology always wins! Commissars may reprimand you for misusing Munitorum materials (posthumously, of course, at least if you did it right), but 9 out of 10 members of the Ecclesiarchy agree that upon your glorious death, you'll be personally be high-fived by the Emperor for your awesomeness. Edited October 11, 2017 by Lord_Caerolion 3 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906246 Share on other sites More sharing options...
OnboardG1 Posted October 11, 2017 Share Posted October 11, 2017 Worms - 40k. 1 Back to top Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906250 Share on other sites More sharing options...
seriade Posted October 11, 2017 Share Posted October 11, 2017 One small problem is that it also says when shooting at this model the crew may only be targeted if it is the closest model to the firer. So moving crew forward to shoot spot screen is actually really bad because if i say shoot the 3 forward guys i can carry the wounds back to the guys shooting the guns. So while its not actually directly clear that this model refers to the gun its is clear though its not the crew. Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906449 Share on other sites More sharing options...
Tyr13 Posted October 11, 2017 Author Share Posted October 11, 2017 One small problem is that it also says when shooting at this model the crew may only be targeted if it is the closest model to the firer. So moving crew forward to shoot spot screen is actually really bad because if i say shoot the 3 forward guys i can carry the wounds back to the guys shooting the guns. So while its not actually directly clear that this model refers to the gun its is clear though its not the crew. Not necessarily. Its a seperate rule, and it seems like it should be "when firing at this unit" in any case. (since you could attempt to target the crew, and this rule would tell you that you cant if the gun is closer). (besides, the whole point is that its rules lawyering to the ridiculous extreme, RAW all the way. Im *pretty* sure RAI is that only the guns explode. ;) ) Link to comment https://bolterandchainsword.com/topic/340239-exploding-quad-launcher-crew/#findComment-4906458 Share on other sites More sharing options...
