DoomulusPrime Posted October 25, 2017 Share Posted October 25, 2017 (edited) Hey guys, So, I have finally started building my AdMech force, and since I'm bored with Knights, I decided to take a Shadowsword for my LoW. A friend of mine recommended I try and take it in a Supreme Command detachment so that I could make it a Valhallan Shadowsword Since I know nothing about Guard, and don't yet have the Codex, I was hoping you guys could give me tips on building the cheapest possible Valhallan SC detachment so that I can take a beefy Shadowsword. He also recommended trying to work in Kurov's Aquila on someone. Any help would be greatly appreciated. Edited October 25, 2017 by DoomulusPrime Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/ Share on other sites More sharing options...
Withershadow Posted October 25, 2017 Share Posted October 25, 2017 The "Lords of War" have to be taken in a Superheavy formation, which is separate from the rest of your list, and can have any Doctrine they want. Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4916721 Share on other sites More sharing options...
Lysere Posted October 25, 2017 Share Posted October 25, 2017 The "Lords of War" have to be taken in a Superheavy formation, which is separate from the rest of your list, and can have any Doctrine they want. Supreme command detachment has an optional Lord of war slot, but unless you need the three HQs for something it's better to just take it in the lone slot since you can still make it whatever regiment you want. Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4916768 Share on other sites More sharing options...
DoomulusPrime Posted October 25, 2017 Author Share Posted October 25, 2017 (edited) I had been told that Superheavy Auxiliary detachments don't get the benefits of regiment rules? In fact it says as much on the 1d4chan IG tactics page (perhaps not the best source, but it's all I've got ATM). I was under the impression that the only way to get Regimental rules on a LoW was to take it in the Supreme Command? Edit: The quote in question from 1d4chan Superheavy Auxiliary Detachments don't benefit from Doctrines, so if you want a LoW with a Doctrine you need to pay for a Superheavy Detachment (3-5!), or a cheaper Supreme Command Detachment (3-5HQ compulsory plus 0-1 LoW), which is cheaper in both points and cash while letting you bring more Officers you could use. Edited October 25, 2017 by DoomulusPrime Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4916770 Share on other sites More sharing options...
Tirak Posted October 25, 2017 Share Posted October 25, 2017 (edited) For those wondering, Pg. 132, IG Codex "If your army is Battle-forged, all <Regiment> units in an Astra Militarum Detachment (excluding those in Super-heavy Auxiliary Detachments) gain a Regimental Doctrine, so long as every unit in that Detachment (apart from the exceptions noted opposite) is drawn from the same regiment. So the easy way to do this to gain utility and the Shadowsword would be 3 Primaris Psykers and the Shadowsword. Each Primaris Psyker is 40pts, so you're looking at a 524 point investment for the whole thing. The Psykers give you psychic powers, which Ad Mech lack, and don't prevent your Shadowsword from being Valhallen. Unless your warlord is Astra Militarum, you can't take a relic, so unless you want to lose your Ad Mech relics, you can't take Kurov's Aquilla. In addition, Kurov's Aquilla is Officers Only, so if you wanted it, you'd either have to invest 30 points in a useless Company Commander, as he has nothing to command, or spend 195 points minimum on a Leman Russ Punisher Tank Commander. Edited October 25, 2017 by Tirak 4 Back to top Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4916778 Share on other sites More sharing options...
DoomulusPrime Posted October 25, 2017 Author Share Posted October 25, 2017 @ Tirak: thanks a lot man :D. Sounds like a plan, I can model up some Psy-servitor looking Primaris psykers and scatter 'em throughout my army. Too bad on the Aquila. Can't give up on Cawl though. Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4916783 Share on other sites More sharing options...
FallenSoldiers Posted October 25, 2017 Share Posted October 25, 2017 AdMech have a trait to get CPs back whenever they’re spend by either side too... granted theirs is only on a 6+ Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4917334 Share on other sites More sharing options...
Beams Posted October 25, 2017 Share Posted October 25, 2017 For those wondering, Pg. 132, IG Codex "If your army is Battle-forged, all <Regiment> units in an Astra Militarum Detachment (excluding those in Super-heavy Auxiliary Detachments) gain a Regimental Doctrine, so long as every unit in that Detachment (apart from the exceptions noted opposite) is drawn from the same regiment. So the easy way to do this to gain utility and the Shadowsword would be 3 Primaris Psykers and the Shadowsword. Each Primaris Psyker is 40pts, so you're looking at a 524 point investment for the whole thing. The Psykers give you psychic powers, which Ad Mech lack, and don't prevent your Shadowsword from being Valhallen. Unless your warlord is Astra Militarum, you can't take a relic, so unless you want to lose your Ad Mech relics, you can't take Kurov's Aquilla. In addition, Kurov's Aquilla is Officers Only, so if you wanted it, you'd either have to invest 30 points in a useless Company Commander, as he has nothing to command, or spend 195 points minimum on a Leman Russ Punisher Tank Commander. You can spend 1cp to take an Astra Militarum relic as long as you have an Astra Militarum detachment. The Aquilla can only be taken by an officer though, so if you find yourself wanting that, I'd suggest taking one company commander and two psykers. Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4917361 Share on other sites More sharing options...
micahwc Posted October 25, 2017 Share Posted October 25, 2017 Alternate view: 3 Leman Russ tank commanders to compliment your superheavy. 2 Back to top Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4917400 Share on other sites More sharing options...
Reviler Posted October 26, 2017 Share Posted October 26, 2017 Alternate view: 3 Leman Russ tank commanders to compliment your superheavy. Pricey points wise though. I played last night and just took three primaris and an astropath as the supreme command det, no super heavy though as I don't own one (yet!). Really cheap at 141 and just used it as smite spam in a game of cities of death rules. Great fun, for me at least. I'd take a banehammer and load it up with a preist, 6 crusaders and 6 bullgryns (from a vanguard), Brutal fun Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4918158 Share on other sites More sharing options...
WarriorFish Posted October 26, 2017 Share Posted October 26, 2017 I missed the LoW in the Supreme Command detachment... brb rewriting my Banehammer list :lol: 1 Back to top Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4918183 Share on other sites More sharing options...
WarriorFish Posted October 29, 2017 Share Posted October 29, 2017 I missed the LoW in the Supreme Command detachment... brb rewriting my Banehammer list Turns out the Banehammer is pretty good, I can't comment more because the Tremor Cannon's special rule never got used and I completely forgot about the Regimental Doctrine Completely all game for everything that is - but at least I remembered some of the fancy stratagems If nothing else the extra Command Point didn't hurt, so definitely the best way to run a LoW if you can use the extra HQs (which you probably can). 1 Back to top Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4920059 Share on other sites More sharing options...
Malakithe Posted October 30, 2017 Share Posted October 30, 2017 My Catachan list for 2k has a shadowsword with primaris, tech-priest, and trojan for support in a supreme command Link to comment https://bolterandchainsword.com/topic/340764-trying-to-build-a-supreme-command-detachment/#findComment-4920146 Share on other sites More sharing options...
