Aothaine Posted October 31, 2017 Share Posted October 31, 2017 (edited) That’s a lot for 2k. I’d say it’s too hard to juggle that in a competitive environment. Although I agree about the apothecary except you need to make sure you can protect him because he’s walking without a Repulsor. So 3 of them becomes a logistics issue. But I have used one in my lists. It does help. Yeah for sure all of that won't fit into 2k. I would add them into the list as follows: Watch Master Apothecary x3 Dreadnought (twin lascannon + fist) x3-4 Kill Team(Terminator(TH+SS), Van Vet(Bolter & Powersword if possible), Vetx5(Bolters) x4-5 Librarian x2 Corvus (Geared for anti-tank) x2 (Only if there is room. The four dreadnoughts should be doing most of the heavy lifting here) Split up the apothecaries to be able to support two squads each and start foot slogging up the board. Should be pretty effective baring an amazing alpha strike by your opponent. If you could add more Kill Teams the better. I would take more Kill Teams over the Corvas personally. Edited October 31, 2017 by Aothaine Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921439 Share on other sites More sharing options...
Moostick Posted October 31, 2017 Share Posted October 31, 2017 You can have every single-model unit, 5 KTs and 3 dreads from that list for 2k. No Corvus. About 40 models with no high rate of fire weapon. To be blunt, this might have a slight chance against elite armies, but will get absolutely slaughtered by horde. In a 1k game against nids, my opponent had 80 models; I imagine it'll be hitting 110-120 in 2k. Even against their weakest gaunts, and assuming you're in rapid fire range, your 50 bolter shots will kill on average 25 gaunts a turn assuming he just charges at you out in the open. Your remaining models will likely finish them off and maybe put a wound or two in another. That's 30-35 of his weakest models a turn and he'll likely have 80-90 of them. They will be able to get into assault by turn 2 and your dreads won't be killing much of these guys in both shooting or melee. This gives time for his big boys to get in by turn 3 and table DW by turn 4. Won't even get out of your deployment zone. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921473 Share on other sites More sharing options...
Aothaine Posted October 31, 2017 Share Posted October 31, 2017 You can have every single-model unit, 5 KTs and 3 dreads from that list for 2k. No Corvus. About 40 models with no high rate of fire weapon. To be blunt, this might have a slight chance against elite armies, but will get absolutely slaughtered by horde. In a 1k game against nids, my opponent had 80 models; I imagine it'll be hitting 110-120 in 2k. Even against their weakest gaunts, and assuming you're in rapid fire range, your 50 bolter shots will kill on average 25 gaunts a turn assuming he just charges at you out in the open. Your remaining models will likely finish them off and maybe put a wound or two in another. That's 30-35 of his weakest models a turn and he'll likely have 80-90 of them. They will be able to get into assault by turn 2 and your dreads won't be killing much of these guys in both shooting or melee. This gives time for his big boys to get in by turn 3 and table DW by turn 4. Won't even get out of your deployment zone. Fair enough. Thank you for the point estimation. I understand how Nids work and I think it would be all about placement of units. I would honestly focus fire everything except the lascannons into one unit of gaunts until it was more manageable then turn the lascannons onto the big beasties that are providing Synapse. It would be a very tough fight. Most likely ending in a loss but with the right positioning you can deny a flank to a swarm list so you can focus on one part of the army. Again, it would be a really difficult fight. Tyranids are really strong right now in swarm form. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921483 Share on other sites More sharing options...
LunarSol Posted October 31, 2017 Share Posted October 31, 2017 I get an anti-horde Corvus, but doesn't seem to have a lot of value in the anti-tank config. Too few shots at low accuracy on a fairly expensive base chassis. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921488 Share on other sites More sharing options...
Aothaine Posted October 31, 2017 Share Posted October 31, 2017 (edited) I get an anti-horde Corvus, but doesn't seem to have a lot of value in the anti-tank config. Too few shots at low accuracy on a fairly expensive base chassis. DW have a few good anti-horde options. Razorbacks with AC are most likely their best bet for now imho. Other options might be an anti-horde kill team with a veteran vanguard so you can back up and fire. Why the veteran vanguards are not fallback and assault and the bikes are not fallback and shoot I just don't understand. Also this is only if we are running pure DW which I think is a bad idea. I think running pure with most armies is a bad idea right now. Running a detachment of Veteran DW with Terminators and Apothecaries and a cheap captain in razorbacks/rhinos and a second detachment of a faction with really good anti-vehicle would be the best way to go. Currently Militarum Tempeusts is by far the best imho. Edited October 31, 2017 by Aothaine Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921500 Share on other sites More sharing options...
shanewatts Posted November 1, 2017 Share Posted November 1, 2017 This is the list I am looking at for tournaments right now: BN Captain w/hammer,shield,jump Lib w/sword 5 vets w/2xfrag,3xchainsword 5 vets w/2xfrag,3xchainsword 5 vets w/2xfrag,3xchainsword Land Raider Crusader Fly detach Xiphon(DW) Xiphon(DW) Valkyrie w/multilaser, rocket pods BN Tempestor Prime w/cane,chainsword (kurov's aquila) Tempestor Prime w/cane,chainsword (laurels of command) Scion Command w/4xmelta Scion Command w/3xmelta 10 scions w/1xbolt pistol 5 scions w/2xvolley,1xbolt pistol 5 scions w/1xvolley,1xbolt pistol 10CP(9CP for extra relic) All the Deathwatch gets in the Land raider, captain starts in reserve. Either the 10 man scions or both melta command squads start in the valk with a prime (allows you to get 3 inches away with the valk disembark after movement.) Only things deployed are the 3 fliers and the land raider. If needed scions can deploy to screen the land raider. Its mobile, able to deal with all targets and able to steal objectives. Aothaine 1 Back to top Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4921591 Share on other sites More sharing options...
Aothaine Posted November 1, 2017 Share Posted November 1, 2017 Yup something like this is what I was thinking. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922009 Share on other sites More sharing options...
Moostick Posted November 1, 2017 Share Posted November 1, 2017 Main worry I have with the Xiphon is the potential FAQs incoming for the forgeworld books. They used to not really care, but seeing they've done some edits to the guard one already, we may see more attention to FW models. Right now Xiphon is undercosted as it brings more firepower and a more useful ability than the Stormhawk for about the same points. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922045 Share on other sites More sharing options...
MeltaRange Posted November 1, 2017 Share Posted November 1, 2017 What do you think about Deathwatch allied with Mechanicus? They have some decent cheap troops & nasty long ranged firepower. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922073 Share on other sites More sharing options...
Aothaine Posted November 1, 2017 Share Posted November 1, 2017 What do you think about Deathwatch allied with Mechanicus? They have some decent cheap troops & nasty long ranged firepower. Could totally work. Just need to make sure that you setup the roles carefully. DW right now are more geared toward the mid-range so you would want your Mechanicus to be focused on melee, which they can do, or long range firepower. Just keep in mind you will need something that can take objectives in the mid-late game. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922121 Share on other sites More sharing options...
shanewatts Posted November 2, 2017 Share Posted November 2, 2017 What do you think about Deathwatch allied with Mechanicus? They have some decent cheap troops & nasty long ranged firepower. What Mechanius units are you thinking? The troop units are fairly cheap, but not very mobile. If you wanted to make a gunline list it could work. Realistically at that point you might as well just play Mechanicus though, their gunline is superior to ours. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922389 Share on other sites More sharing options...
Prot Posted November 2, 2017 Author Share Posted November 2, 2017 What do you think about Deathwatch allied with Mechanicus? They have some decent cheap troops & nasty long ranged firepower. Definitely workable. But the Admech are really static so I would concentrate on Corvus DW or some other means to get them in mid range Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922398 Share on other sites More sharing options...
Mobius0288 Posted November 2, 2017 Share Posted November 2, 2017 What do you think about Deathwatch allied with Mechanicus? They have some decent cheap troops & nasty long ranged firepower. I'd definitely say use their stuff fill what you're lacking - Dunecrawlers for long range and/or anti-air, and Rangers for sniper-ish stuff. I would think they'd be cheap enough to still allow you to get some razorbacks and decently kitted-out kill teams, hopefully a blackstar as well. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922619 Share on other sites More sharing options...
MeltaRange Posted November 2, 2017 Share Posted November 2, 2017 I've thought about a couple options, not sure about the viability. This is just an initial pass, but 2 interesting options below. There is also the obvious Cawl + Mars stuff but that gets pretty expensive so I'd honestly rather have like a Tallarn Guard detachment full of cheap troops and transports to use for blocking/objective grabbing with that setup. That might end up working better with any of the armies below actually, but, at least I had enough points for the DW detachment to bring something decent. Army 1 Graia Battalion Dominus (emotionless clarity, runs up front with vanguard) Enginseer 10 Vanguard 3x Arc Rifle 10 Vanguard 3x Arc Rifle 10 Vanguard 3x Arc Rifle 2x Onager w/ Neutron Laser 1x Onager w/ Eradication ray (runs with vanguard + warlord) Deathwatch Battalion Watch Master Terminator Librarian Naked Kill Team just Bolters Naked Kill Team just Bolters Kill Team w/ Stalker Bolters 8 man Kill Team 5 Bolters 3 Frag Cannons (rhino) 6 Vanguards w/ bolt pistols + power swords Rhino This army is basically designed to flood the opponent with flexible and cheap troops (they are relatively tough with Graia trait) that can tie the units up in combat and still shoot, while also featuring 3 onagers and having a deep strike element that synergies well with Rad Saturation. Hopefully opponent leaves rhino alone in order to focus on the dunecrawlers. Army2 Agripiinaa Spearhead Dominus (necromechanic, arkhan land) 6 Destroyers w/ Plasma, 3x flamer 3x phosphor 2x Robots w/ 3x heavy phosphor 2x Onager w/ Neutron Laser Deathwatch Battalion Watch Captain w/ Jump Pack, TH Watch Master Kill Team 2x Combi-Plas (pod) Kill Team 1 Frag (pod) Stalker Kill Team Stalker Kill Team 3x Bikers power weapons Drop Pod This army is designed to have a well-entrenched and extremely lethal firebase and DW to run interference. Kataphons will be used aggressively to try and take advantage of 5+ overwatch and the "Fresh Converts" strategem - 3 CP to completely regenerate that unit of 6! (not to mention elimination volley) I don't know, it's an initial pass like I said. You could also probably make a nice Stygies VIII army that's actually pretty fluffy since they are Xenos oriented (thought I believe in the fluff, the DW actually have been known to actually attack Stygies VIII tech-priests because they are TOO far Xenos...but that's another matter.) Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4922803 Share on other sites More sharing options...
Moostick Posted November 25, 2017 Share Posted November 25, 2017 With Sicaran Venators getting the "buy me" treatment, what's the better option for anti-tank? Venator or Xiphon? Venator - 230 pts +3 Wounds 3 S12, AP4, D6, -1 to hit on wound 2 S9, AP3, D6 3 S5, AP1, 1D Boots on the ground/screener LoS can be an issue Xiphon - 240 points (assuming no changes to Missile Battery) -1 to Hit for fire against +1 to Hit against Flyers 4 S9, AP4, D6 3 S6, AP2, 3D Movement can be good or bad/can't capture or screen Can't be tied up in assault Difficult to screen against on alpha strike/can't protect from alpha strike Both have some form of Machine spirit, so I didn't include that. Hard choice, and I think it depends on the rest of your army composition. If you need to take our backline artillery then Xiphon. Anything else, I would opt for the Venator. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4940479 Share on other sites More sharing options...
mega_marines Posted December 3, 2017 Share Posted December 3, 2017 With Sicaran Venators getting the "buy me" treatment, what's the better option for anti-tank? Venator or Xiphon? Venator - 230 pts +3 Wounds 3 S12, AP4, D6, -1 to hit on wound 2 S9, AP3, D6 3 S5, AP1, 1D Boots on the ground/screener LoS can be an issue Xiphon - 240 points (assuming no changes to Missile Battery) -1 to Hit for fire against +1 to Hit against Flyers 4 S9, AP4, D6 3 S6, AP2, 3D Movement can be good or bad/can't capture or screen Can't be tied up in assault Difficult to screen against on alpha strike/can't protect from alpha strike Both have some form of Machine spirit, so I didn't include that. Hard choice, and I think it depends on the rest of your army composition. If you need to take our backline artillery then Xiphon. Anything else, I would opt for the Venator. Honestly the Xiphon is a better choice. It will be able to hunt more and be a much better distraction than the Venator. As much as I adore the Sicaran chassis it just doesnt ooze character like the Xiphon does either. It being able to be anywhere it needs to be is also incredibly helpful, and that alone is one of the biggest selling points. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4949390 Share on other sites More sharing options...
Prot Posted December 4, 2017 Author Share Posted December 4, 2017 Did the Xiphon get any CA love? I know it’s a favourite in the Astartes forum but I haven’t seen a lot of people use it with DW Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4950082 Share on other sites More sharing options...
Moostick Posted December 4, 2017 Share Posted December 4, 2017 It got increased by 30 points, which I thought was actually pretty reasonable. Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4950150 Share on other sites More sharing options...
Thanatos31 Posted December 4, 2017 Share Posted December 4, 2017 Did the Xiphon get any CA love? I know it’s a favourite in the Astartes forum but I haven’t seen a lot of people use it with DW was interested in that flyer too. Do you have any experience with it or could link to a good thread ? Thanks Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4950268 Share on other sites More sharing options...
Prot Posted December 4, 2017 Author Share Posted December 4, 2017 There's a decent all around FW thread in the Astartes section here: http://www.bolterandchainsword.com/topic/340943-competitive-fw-units-for-sm/ Link to comment https://bolterandchainsword.com/topic/340866-deathwatch-tournament-play/page/2/#findComment-4950424 Share on other sites More sharing options...
