MiniB1084 Posted October 29, 2017 Share Posted October 29, 2017 hello, my friend is starting and imperial fist army for hh and needs help with his list. so far hes thinking of praetor in terminator armor cataphractii terminator squad w/ land raider 10 man tactical squad w/ land raider 10 man tactical squad w/ land raider contemptor dreadnought would this be around 1500 points do you think? thanks Link to comment https://bolterandchainsword.com/topic/340886-imperial-fists-1500-points-help/ Share on other sites More sharing options...
Unknown Legionnaire Posted October 31, 2017 Share Posted October 31, 2017 Consul - Delegatus (Chosen Duty), Cataphractii, master-crafted Thunder Hammmer Command Squad - 3 Chosen & 1 Standard Bearer, Cataphractii Armour, 4x Combi-Bolter, 2x Power Fisl, 2x Chain Fist Land Raider Phobos - Dozer Blade, Ceramite 10 man Veteran Tacticals - Marksmen, Sergeant w. Artificer Armour & Power Fist Land Raider Phobos - Dozer Blade, Ceramite 10 man Veteran Tacticals - Marksmen, Sergeant w. Artificer Armour & Power Fist Land Raider Phobos - Dozer Blade, Ceramite Makes up for 1.410 pts. and uses Heavy Support slots to get the Phobos Raiders. One could downgrade the Veterans to regular Tacs and roll with the Armoured Spearhead RoW instead, making the Phobos dedicated transports: Praetor (Armoured Spearhead) - Cataphractii - Combi Bolter, master-crafted Thunder Hammer, Digital Lasers Command Squad - 3 Chosen & 1 Standard Bearer, Cataphractii Armour, 4x Combi-Bolter, 2x Power Fisl, 2x Chain Fist Land Raider Phobos - Dozer Blade, Ceramite 10 man Tacticals - Sergeant w. Artificer Armour & Power Fist, Vexilla Land Raider Phobos - Dozer Blade, Ceramite 10 man Tacticals - Sergeant w. Artificer Armour & Power Fist, Vexilla Land Raider Phobos - Dozer Blade, Ceramite About 1.435 pts. Just two examples. Adding the contemptor would bring it closer to 1.750 than 1.500 Link to comment https://bolterandchainsword.com/topic/340886-imperial-fists-1500-points-help/#findComment-4921052 Share on other sites More sharing options...
K3nn3rs Posted October 31, 2017 Share Posted October 31, 2017 Perhaps run the LR for the vets as proteus and add extra lascannons. Also upgrade the command squad to have vigil pattern storm shields and all chain fists. Link to comment https://bolterandchainsword.com/topic/340886-imperial-fists-1500-points-help/#findComment-4921495 Share on other sites More sharing options...
