Havok13 Posted October 31, 2017 Share Posted October 31, 2017 Hi, Looking at the index for wolves, i would love to try out the following unit, but it is an awful lot of points. Has anyone used it and what size list would you use it in? StormWolf 5 Wolfguard in Terminator Armour. Arjac Njal Wolf priest in Terminator Armour The load out comes in at 1066 points! Is this too much? 7 thunder hammer hits, 9 wolf claw, 5 for arjac, 3 for Njal, 3 for WP. Rerolling failed hits and rerolling wounds of 1. You have smite and the ability to get wounds back and 3 storm bolters, 1 assault cannon and Njal and Arjac shooting attacks. Would love to try it out but wow what a point sink. Link to comment https://bolterandchainsword.com/topic/340918-hard-hitting-unit-too-much/ Share on other sites More sharing options...
jlmb_123 Posted October 31, 2017 Share Posted October 31, 2017 You should call it the Norse Conquest formation. If you have the figures, go with it. You can fit three five-man squads of Grey Hunters with a plasma gun each and three Razorbacks with Assault Cannons into a 1850 list alongside what you've already listed. Link to comment https://bolterandchainsword.com/topic/340918-hard-hitting-unit-too-much/#findComment-4921060 Share on other sites More sharing options...
Karhedron Posted October 31, 2017 Share Posted October 31, 2017 It is a lot of eggs in one basket but it will hit like a ton of bricks. Your main problem is actually probably going to be finding something big enough for it to be worth killing. If you opponent fields a Knight or similar LoW, would should be able to kill (or at least badly cripple) it in one round of combat. But if you opponent does not have a single high value target, you could struggle. After you have dropped in and killed a unit, your Termies on foot will have to walk to their next target unless the Stormwolf manages to circle round and pick them up again. A smart opponent will back away and shoot you to pieces while you walk. Still, it looks fun to try and would be a good antidote to some of the big hitters that can dominate games. Link to comment https://bolterandchainsword.com/topic/340918-hard-hitting-unit-too-much/#findComment-4921091 Share on other sites More sharing options...
Deadnaughty Posted October 31, 2017 Share Posted October 31, 2017 It is a lot of eggs in one basket but it will hit like a ton of bricks. Your main problem is actually probably going to be finding something big enough for it to be worth killing. If you opponent fields a Knight or similar LoW, would should be able to kill (or at least badly cripple) it in one round of combat. But if you opponent does not have a single high value target, you could struggle. After you have dropped in and killed a unit, your Termies on foot will have to walk to their next target unless the Stormwolf manages to circle round and pick them up again. A smart opponent will back away and shoot you to pieces while you walk. Still, it looks fun to try and would be a good antidote to some of the big hitters that can dominate games. You could hit 3 targets. Terminators on 1, Arjac on another and Njal + Priest on a 3e. (or even 4th but that might be stretching to thin. You have 3"disembark + 5"move + charge so you have enough threat range. Link to comment https://bolterandchainsword.com/topic/340918-hard-hitting-unit-too-much/#findComment-4921205 Share on other sites More sharing options...
Bulwyf Posted October 31, 2017 Share Posted October 31, 2017 That's a lot of points but if you are going up against a Knight or LoW then that is worth it. Also...just play what you find fun. Who cares if it isn't optimum or "best spec"? Link to comment https://bolterandchainsword.com/topic/340918-hard-hitting-unit-too-much/#findComment-4921465 Share on other sites More sharing options...
