Krakendoomcool Posted August 22, 2018 Share Posted August 22, 2018 Your poor bikers. That’s a bugger. But overall I think you’ll do better with all the new combos and stratagems etc in the new codex. Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5150834 Share on other sites More sharing options...
TiguriusX Posted August 25, 2018 Author Share Posted August 25, 2018 My LED kit finally came. I got my old wire strippers out and tested the LEDs Step 2 is the hard part....drilling I have the direct line from the rear of the head but I need to drill secondary paths from the actual eye slits to connect the light path Will be fun trying to hit a target with drilling. Never tried it before Unfortunately I learned don't have a large enough drill bit for the LED My temporary fix is to simply insert it in the rear and let the light go down the path I drilled Next up is drilling the path for the wires into the interior. That has to wait for another day though...free time is over *EDIT* LOL so my wife and I were talking about my problem just now. She asked why I wasn't using my "regular' tools (I was limiting myself to the small hobby tools I bought) Thanks babe! Grabbed a giant bit and it actually fit in my hand tool Proper sized hole is now drilled! Next decision is 1 hole and LED per eye? Or do I use 1 LED and just make a light path now hmmm Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5153559 Share on other sites More sharing options...
GrFlur Posted August 25, 2018 Share Posted August 25, 2018 Next is and arduino with some rotors for movement and the another with some laser scan for target locking? Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5153566 Share on other sites More sharing options...
Bjorn Firewalker Posted August 25, 2018 Share Posted August 25, 2018 Impressive work. Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5153652 Share on other sites More sharing options...
TiguriusX Posted August 29, 2018 Author Share Posted August 29, 2018 Today was damage control day When I drilled the matching hole on the left side it cracked and I lost the rear left portion of the wolf head (compare/contrast with right side) I put a generic layer of green stuff on (haven't done green stuff in ages but I did remember I need water!!!) I made sure the hole was big enough for the LED and am letting it cure tonight If all goes well I will spray primer on it next and test how the light looks Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5155955 Share on other sites More sharing options...
TiguriusX Posted August 29, 2018 Author Share Posted August 29, 2018 Bought a can of mechanicus standard grey primer ($19.99 bleh) Assembled a squad of 5 GHs (I have a ton of heads already primed black they go on after painting) This gives me 3x5 so I can form my battalion under the new codex I also primed the knight wolf head The LED looks much better with the painted head Next step is routing wires in the body of the knight (probably a weekend project) Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5156611 Share on other sites More sharing options...
Dantay VI Posted August 30, 2018 Share Posted August 30, 2018 Loks great, hopefully a few mre layers of paint will keep all the excess glow under control Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5157537 Share on other sites More sharing options...
Jackalwolf Posted August 31, 2018 Share Posted August 31, 2018 Nice! I really like the use of LEDs for Knights. Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5157836 Share on other sites More sharing options...
TiguriusX Posted September 1, 2018 Author Share Posted September 1, 2018 The hole for a wire is cut out. But I ran into a few problems. -I can have a hidden hole and run 1 LED through it or cut a massive hole for 2 LEDs. I am leaving a single hole only for now. -I magnetized the head so it can swivel but the wires are stiff and basically lock the head into position. The funny thing is I have 2 different holes drilled so I can swap holes and rotate the head if I want but the greenstuff repair side is better off hidden Anyways here is the assembled head with a single LED. Glow is just fine (maybe over glow but I figure paint will reduce it as I add layers) I like it. I was terrified of doing this project and thought I would break my expensive model but so far so good. I am glad I pushed myself. Next step is figuring how I want to mount the battery case and switch. The plan is to have it internally mounted so I can remove the large hatch and flip the switch. Lets see if reality matches my plan... Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5158696 Share on other sites More sharing options...
GrFlur Posted September 1, 2018 Share Posted September 1, 2018 Wau! It's going outstanding!!!! Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5158715 Share on other sites More sharing options...
TiguriusX Posted September 20, 2018 Author Share Posted September 20, 2018 Dipping my toe in the terrain field now I picked up some printed paper terrain from Infinity https://store.corvusbelli.com/products/scenery_packs/285059-kurage-station-scenery-pack I read it works for 40K and kill team so I said why not Here are some shots with various sizes of models I have from tiny power armor all the way up to a knight-gallant I think I will be able to use it. It isn't the highest quality but it works and was cheap. Game on! Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5169665 Share on other sites More sharing options...
Dantay VI Posted September 20, 2018 Share Posted September 20, 2018 Looks great and thanks for the link.. If you want something a bit more substantial but not pay GW prices, I would recommend MDF terrain There are loads of companies out there This cost me about £40 or so. thumbnail (77) by Danny Taylor, on Flickr Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5169683 Share on other sites More sharing options...
PeteySödes Posted September 21, 2018 Share Posted September 21, 2018 Board looks cool! I've been itching to give mine a facelift. Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5170740 Share on other sites More sharing options...
TiguriusX Posted September 21, 2018 Author Share Posted September 21, 2018 Part of the reason I am experimenting with terrain is because I've decided to dive into KT *a 30-45 min game is MUCH easier to play with my 8 and 6 year old Here is a link to my new campaign log-Wolf Pack Tigurius. Starting on sunday! Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5170798 Share on other sites More sharing options...
TiguriusX Posted October 11, 2018 Author Share Posted October 11, 2018 I went a little bit crazy since I last reported in I dove in to KT and am 3-1 in my FLGS for the official GW campaign Playing made me realize I need reinforcements I picked up the Fangs of Ulfrich and a box of 10 intercessors as well I will probably never use Reivers in 40k but they are nice filler in my KT squad The intercessors are DREAMY...I love the models and enjoyed assembling them. GW blew it big time trying to write in primaris fluff. I would have voluntarily replaced all my old power armor models over time if I could get similar war gear (chain swords...power weapons etc.) I have a BA friend so I got him some free primaris upgrade bits for the same price as a regular box I have to agree with others who say the lack of a Space Wolf intercessor box is BS After theory crafting my airwolf list I eventually said what the hell and decided to put my money where my mouth is Picked up 5 wulfen (waiting to decide if I need 5 more). I don't like the default pack leader so made an alternative model who isn't jumping like a clown Also ordered my 2 stormwolf flyers earlier this week I ALSO acted on an overstock sale at my FLGS and picked up a box of assault marines for $20 I needed a few more bodies for my planned battalions (need troops!) and extra jump packs are handy to have These running legs are kinda cool. Plan on using 2 of them for a wolf lord and WGBL model And with this huge growing collection of models I am overflowing my hobby space in the house... Picked up 3 more KR multicase boxes to store all these things nicely 1 box dedicated to my knights (holds a gallant + 2 armigers) 1 box dedicated to my flyers (holds 2 stormwolf models and I can squeeze in some basic infantry) 1 box dedicated to an armor variant that holds 3 dreads 2 leviathans and 4 razorbacks (the nerfing of bikes makes my dread+bike foam layout not as useful anymore) Xmas come early woo hoo (I busted my ass to make FY end goals at work and honestly just felt like rewarding myself) Assembling is definitely my favorite part....painting not so much I am waaaay behind on scheduled painting now. Although I did process a batch of heads and painted around 15 or so (I blue tacked a few of them on those new assault marines) Thus ends your B&C 2018 outage update Assembly and painting in my near future Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5172086 Share on other sites More sharing options...
GrFlur Posted October 18, 2018 Share Posted October 18, 2018 Trigrus X just to let you know Shappeways is stealing models from Thingiverse and making money without autorization from the designers. The wolf head you ordered is one example :/ Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5176106 Share on other sites More sharing options...
TiguriusX Posted October 18, 2018 Author Share Posted October 18, 2018 Trigrus X just to let you know Shappeways is stealing models from Thingiverse and making money without autorization from the designers. The wolf head you ordered is one example :/ what is your support for the allegation? The guy who makes the wolf variants i have (comradequiche) had a blog about his designs and how he came up with them. i doubt he stole them from someone else. For example....as far back as 2015 (before new knights exploded in the meta) it was public knowledge and he was the designer behind it Spikeybits article on the "iron werewolf" as he calls it Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5176149 Share on other sites More sharing options...
GrFlur Posted October 19, 2018 Share Posted October 19, 2018 https://www.thingiverse.com/groups/40k/forums/general/topic:32032 Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5176646 Share on other sites More sharing options...
TiguriusX Posted October 19, 2018 Author Share Posted October 19, 2018 Those designs I see from imperial workshop appear to have nothing to do with the wolf knight parts I have. There is probably more reading I could do but honestly I'm not doing a research project to try and figure out what you are telling me. Please give me a direct link if you have it. I understand concern about this (I'm a patent attorney I live in the intellectual property world) but I don't think the blanket accusation for all of shapeways is appropriate. That is like saying YouTube is ripping people off because an individual uploads something that was copyrighted. As I said above, the guy who made the wolf knight parts appears legitimate to me and has been in it a long time. I got mine from a designer named comradequiche This is his shop https://www.shapeways.com/shops/gadgetsplus Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5176664 Share on other sites More sharing options...
TiguriusX Posted October 26, 2018 Author Share Posted October 26, 2018 The last of my B&C blackout items have arrived Double flyers KR boxes I am becoming a 40K hoarder... I will admit the boxes help tidy up the models I have (they were spilling out of my hobby area onto the dining table recently) Think I need to undertake a vow of no more spending... I will ask for the missing razorbacks as Xmas gifts instead muwahaha Seriously though I started this hobby almost exactly 1 year ago (post #1 is from Nov 2nd, 2017) I originally intended to dip my toe in the water and have fun I have definitely been hooked by the hobby and enjoyed my time. I love building far more than painting but I do take pride in the progress I have made. Now to focus on building/painting what I have! Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5179561 Share on other sites More sharing options...
TiguriusX Posted December 31, 2018 Author Share Posted December 31, 2018 I failed my oath to myself.... I still haven't modeled or glued or painted since the last update But I did just buy 2 boxes of Aggressors because my FLG was having a clearance sale Total addict....no questions asked Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5225727 Share on other sites More sharing options...
TiguriusX Posted January 1, 2019 Author Share Posted January 1, 2019 I just learned about and watched Helsreach It is a badass animation of Grimauldus at the 3rd war of armageddon This is some quality work....can't believe I never knew about it before today Anyways my favorite Astartes dialog happens at this link hahahaha https://youtu.be/SUplioG2DC4?t=4242 TechMarine-"This is a magnetic field stabilizer housing" IG-"What does it do?"TechMarine-"It houses the stabilizers for the magnetic field generator" IG- ... Eyeroll Just very factual interaction between an astartes and a curious IG but it made me laugh Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5226104 Share on other sites More sharing options...
TiguriusX Posted January 4, 2019 Author Share Posted January 4, 2019 With the New Year I vowed to get off my arse and make progress I still have some magnetizing to do so I can swap between Wolf and Fang configurations but flyer #1 is now playable Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5228002 Share on other sites More sharing options...
GrFlur Posted January 5, 2019 Share Posted January 5, 2019 Are you following some tutorial on how magnetize it? I've 2 of them but still boxeds Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5228295 Share on other sites More sharing options...
TiguriusX Posted January 5, 2019 Author Share Posted January 5, 2019 Are you following some tutorial on how magnetize it? I've 2 of them but still boxeds I've been looking at Brother Wulfebane's post from 2014 as general guidance However I have to admit the kit is fairly straight forward. The stormwolf nose piece actually sits nicely on top of the frost cannon...if you wanted to do it lazy style just put that on top and you don't have to magnetize anything. It covers 90% of the frost cannon unless you are facing a stickler it should be fine. The part I need to worry about is the cockpit. There are some small pieces that won't be easy to add/remove to swap between versions. I haven't decided how to address that yet. I also prefer the tail fin of the stormwolf and glued it permanently in place Link to comment https://bolterandchainsword.com/topic/340985-digital-wolf-stepping-through-the-warp-onto-the-tt/page/7/#findComment-5228315 Share on other sites More sharing options...
