Ovidius Incertus Posted November 4, 2017 Share Posted November 4, 2017 I just got two packs to make some press molds. Any dos and don'ts for its use? Particularly, how should I store it after using? Just in a plastic bag? Secondly, will the mold release without adding any sort of lubricant like vaseline? Is using vaseline a no-no? Link to comment https://bolterandchainsword.com/topic/341049-tips-for-using-instantmold/ Share on other sites More sharing options...
Brother-Chaplain Kage Posted November 5, 2017 Share Posted November 5, 2017 If I'm not mistaken Instant Mold/Blue Stuff is the same material as Oyumaru and I did a tutorial in my WIP thread on using it. Khornestar 1 Back to top Link to comment https://bolterandchainsword.com/topic/341049-tips-for-using-instantmold/#findComment-4924681 Share on other sites More sharing options...
Kisada Posted November 5, 2017 Share Posted November 5, 2017 the clear, heat and mold, stuff? It's super easy to use ... heat it ... press mold it (sometimes using a box made out of legos or something helps when pressing the mold so that you don't lose detail) After just let it cool down (I'm impatient so I put it in cold water) Once it's cool it'll be solid. Press and go. I use green stuff and no lubricant and its been just fine. Link to comment https://bolterandchainsword.com/topic/341049-tips-for-using-instantmold/#findComment-4924686 Share on other sites More sharing options...
