jbaeza94 Posted November 12, 2017 Share Posted November 12, 2017 With a lot of big and unusually shaped bugs, i was wondering how you guys transport them. I have one of those GW boxes for my marines, and i figure i could fit my gaunts and pants stealers in there as well. However, what do you guys do for the big ones? In looking for something in a hard case (i travel often). Any suggestions? Thanks... swarm brothers? I still don’t know what to call this side of the community lol Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/ Share on other sites More sharing options...
Filkarion Posted November 12, 2017 Share Posted November 12, 2017 A tool case and some isolating foam from a DIY store do the trick cheaply for me Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/#findComment-4930205 Share on other sites More sharing options...
Xenith Posted November 17, 2017 Share Posted November 17, 2017 I've found the new(ish) style of gw case/foam pretty adaptable, and it comes is a hard case format for like £80 or so. I think all my gribblies will fit in a crusade case no problem. My stormraven did. Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/#findComment-4933650 Share on other sites More sharing options...
jbaeza94 Posted November 17, 2017 Author Share Posted November 17, 2017 Thanks all. i just got myself a free crusader case from gw, ill try to dedicate the new one to the big bugsXenith, did you have to remove any of the squiggly faom to fit the stormraven? im trying to see if i need to modify my foam Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/#findComment-4933661 Share on other sites More sharing options...
dwez Posted November 17, 2017 Share Posted November 17, 2017 I use a variety of cheap plastic tubs and wrap the model in bubble wrap. Usually I can fit a Tervigon in one with space round the edges for a Venomthrope and a Broodlord as well. I'm not throwing it around so it only needs rigid protection and a little padding. I also have a Trygon in an old plastic Transformers lunchbox Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/#findComment-4933788 Share on other sites More sharing options...
Xenith Posted November 17, 2017 Share Posted November 17, 2017 Thanks all. i just got myself a free crusader case from gw, ill try to dedicate the new one to the big bugs Xenith, did you have to remove any of the squiggly faom to fit the stormraven? im trying to see if i need to modify my foam Nope, it pushes to one side nicely. The wings on mine are removable, though, and I have the landing struts deployed. Raven goes on its side in the bottom, wings slot into the gaps. upper smaller foam insert gets turned upside down. Base fits in the gap between the left and right foam inserts. The raven does take up almost a quarter of the crusade case, but it fits. Link to comment https://bolterandchainsword.com/topic/341264-miniature-transport/#findComment-4934096 Share on other sites More sharing options...
