lash144 Posted November 14, 2017 Share Posted November 14, 2017 Hey there, What's your opinon on assassins? Are you using them, if yes which ones? Do you find them effective? I actually had a Culexus last weekend in my match against GK and helped quite a lot obviously. Plus he is really tough to remove ^^ Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/ Share on other sites More sharing options...
H311fi5h Posted November 14, 2017 Share Posted November 14, 2017 Eversor and Culexus are both pretty bonkers. You could play an entire army of assassins, that's how good they are. I wouldn't go and spend a ton of money on 20 assassins though, I have a strong feeling they will go up in points rather soon. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931328 Share on other sites More sharing options...
lash144 Posted November 14, 2017 Author Share Posted November 14, 2017 (edited) Eversor and Culexus are both pretty bonkers. You could play an entire army of assassins, that's how good they are. I wouldn't go and spend a ton of money on 20 assassins though, I have a strong feeling they will go up in points rather soon. I was thinking about adding 20 xD Just adding maybe an Culexus + Eversor just so they can be a pain in :cuss Tie up things in combat, disrupt psykers and charges, counter charge etc. Edit: swear filter dodge Edited November 14, 2017 by duz_ Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931332 Share on other sites More sharing options...
H311fi5h Posted November 14, 2017 Share Posted November 14, 2017 Well, you can never go wrong with a single Culexus. Even when your enemy doesn't have any psykers. He is super annoying to deal with, and can't be ignored. A single Eversor is a bit hit or miss. Everything depends on that first charge roll. If he makes it, he will slaughter anything. If you roll poorly, he will get shot to death during your opponent's turn and do nothing. That's why you want to take multiple Eversors if you want to rely on them being a part of your strategy. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931337 Share on other sites More sharing options...
Feral_80 Posted November 14, 2017 Share Posted November 14, 2017 I think they are all usable, with the exception of the Vindicare. Sadly, he is still terrible. Each has its own limits however, so don't expect much unless they are properly supported. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931341 Share on other sites More sharing options...
WarriorFish Posted November 14, 2017 Share Posted November 14, 2017 Yeah the Vindicare is the weakest sadly (maybe if he got his individual model targeting rule back?), Culexus is good especially if you expect any psyker shenanigans otherwise the Eversor is always choppy fun. As Feral says they need support, so don't treat them as a one man army - just pick the one that suits your needs and they should do a good job for you duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931355 Share on other sites More sharing options...
Godeskian Posted November 14, 2017 Share Posted November 14, 2017 I've been underwhelmed by the eversor to be honest, but I routinely run two Culexus and a Callidus for shenanigans with a cheap 40 point Primaris Psyker as a detachment Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931360 Share on other sites More sharing options...
Toomanyprojects Posted November 14, 2017 Share Posted November 14, 2017 I prefer a Vindicare - good character harassment, brilliant against multiwound infantry (termies/primaris) and can reliably knock wounds off large untis of guard etc. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931378 Share on other sites More sharing options...
Halfpint100 Posted November 14, 2017 Share Posted November 14, 2017 I usually use an eversor, he is a great distraction carnifex and if he dies, oh well, he was 70 points. Occasionally i use a Cullexus as well, but that is opponent specific, since i generally have 5+ psykers, psychic defence isn't an issue. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931408 Share on other sites More sharing options...
TheShredder Posted November 14, 2017 Share Posted November 14, 2017 I used an Evesor once in a themed army and he did pretty well.For 70pts, I think he's okay. The anti-psyker one looks pretty decent as well, though I've yet to try him. The only real issue I have (and this isn't exclusive to assassins) is that the codex has made me less inclined to use non-IG units. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931421 Share on other sites More sharing options...
our_baz Posted November 14, 2017 Share Posted November 14, 2017 I'll be running a Vindi, Callidus and Evesor in a game next weekend. I'll report back on how it all goes. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931476 Share on other sites More sharing options...
Brother Captain Ed Posted November 14, 2017 Share Posted November 14, 2017 Vindicares need to run in twos. One is an irritation. Two will actually pop auras. Try a pair. It will change how you feel about the Vindicare. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931873 Share on other sites More sharing options...
Withershadow Posted November 14, 2017 Share Posted November 14, 2017 That really goes for the Eversor too. One is obnoxious enough, a pack of them is a tragedy. Halfpint100 1 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931888 Share on other sites More sharing options...
The Ergonomic Enginseer Posted November 15, 2017 Share Posted November 15, 2017 So that is there plural then. "A tragedy of Eversors" Azekai, CoffeeGrunt, librisrouge and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4931932 Share on other sites More sharing options...
lash144 Posted November 15, 2017 Author Share Posted November 15, 2017 So if I want some melee punch I should at least take 2 Eversor? Maybe even three if my points are allowing it? Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932030 Share on other sites More sharing options...
Halfpint100 Posted November 15, 2017 Share Posted November 15, 2017 So if I want some melee punch I should at least take 2 Eversor? Maybe even three if my points are allowing it? Pretty much, get an inquisitor and 3 eversors in a vanguard (whatever the elite one is called) for 265 points to get 3 deep striking screaming murder machines and a lovely LD9 buff (and psychic stuff) for your guard lash144 1 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932039 Share on other sites More sharing options...
Godeskian Posted November 15, 2017 Share Posted November 15, 2017 I must be using them wrong. I can usually hit whatever I charge into, but I never seem to do much damage. How exactly is the eversor working for you folk? Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932278 Share on other sites More sharing options...
Feral_80 Posted November 15, 2017 Share Posted November 15, 2017 I'm not much persuaded by this thing that assassins (or whatever) are good in multiples. Or that this tactic makes them good at least. Yes thank you, I think it's only reasonable that if I spend 2-300+ points in a number of units they *will* eventually kill something. This however does not make them necessarily 'good'. I believe those points can be spent in much better and more effective ways as AM. As I said, I believe 3 out of 4 assassins are playable. That means playable, not good. They provide annoyance and can be used as psychological distraction against some opponents, but that does not make them killy or even *that* dangerous. In my experience even the most generous in terms of choppa, the Eversor, won't kill that many models, because regardless of his many attacks, depending on the weapon he uses he lacks either the strength or the AP to really inflict pain. The others have good AP, but they all lack both attacks and strength, so, in conclusion...unimpressed. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932281 Share on other sites More sharing options...
Guardsman Bob Posted November 15, 2017 Share Posted November 15, 2017 Without proper prey assassins wouldn’t be useful. Bouncing them on a horde amry for instance. Considering our fighting character options I’m thinking about pulling mine back out of storage and finish painting the others. The Callidus was pretty sweet in the Inquistion Codex so her paintjob was done long ago. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932291 Share on other sites More sharing options...
TheShredder Posted November 15, 2017 Share Posted November 15, 2017 I'm not much persuaded by this thing that assassins (or whatever) are good in multiples. Or that this tactic makes them good at least. Yes thank you, I think it's only reasonable that if I spend 2-300+ points in a number of units they *will* eventually kill something. This however does not make them necessarily 'good'. I believe those points can be spent in much better and more effective ways as AM. As I said, I believe 3 out of 4 assassins are playable. That means playable, not good. They provide annoyance and can be used as psychological distraction against some opponents, but that does not make them killy or even *that* dangerous. In my experience even the most generous in terms of choppa, the Eversor, won't kill that many models, because regardless of his many attacks, depending on the weapon he uses he lacks either the strength or the AP to really inflict pain. The others have good AP, but they all lack both attacks and strength, so, in conclusion...unimpressed. Yeah, once you start buying multiple assassins, you quickly enter the realm of 'I could have had a whole MT detachment for that price'. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932339 Share on other sites More sharing options...
Halfpint100 Posted November 15, 2017 Share Posted November 15, 2017 I'm not much persuaded by this thing that assassins (or whatever) are good in multiples. Or that this tactic makes them good at least. Yes thank you, I think it's only reasonable that if I spend 2-300+ points in a number of units they *will* eventually kill something. This however does not make them necessarily 'good'. I believe those points can be spent in much better and more effective ways as AM. As I said, I believe 3 out of 4 assassins are playable. That means playable, not good. They provide annoyance and can be used as psychological distraction against some opponents, but that does not make them killy or even *that* dangerous. In my experience even the most generous in terms of choppa, the Eversor, won't kill that many models, because regardless of his many attacks, depending on the weapon he uses he lacks either the strength or the AP to really inflict pain. The others have good AP, but they all lack both attacks and strength, so, in conclusion...unimpressed. Yeah, once you start buying multiple assassins, you quickly enter the realm of 'I could have had a whole MT detachment for that price'. But they arn't screaming murder machines on the drug cocktail to end all drug cocktails librisrouge 1 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932369 Share on other sites More sharing options...
Tirak Posted November 15, 2017 Share Posted November 15, 2017 Savlar Chemdog Temestus XD librisrouge, Halfpint100 and The Ergonomic Enginseer 3 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932383 Share on other sites More sharing options...
Halfpint100 Posted November 15, 2017 Share Posted November 15, 2017 Savlar Chemdog Temestus XD This one made me laugh so much! Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932393 Share on other sites More sharing options...
TheShredder Posted November 15, 2017 Share Posted November 15, 2017 I'm not much persuaded by this thing that assassins (or whatever) are good in multiples. Or that this tactic makes them good at least. Yes thank you, I think it's only reasonable that if I spend 2-300+ points in a number of units they *will* eventually kill something. This however does not make them necessarily 'good'. I believe those points can be spent in much better and more effective ways as AM. As I said, I believe 3 out of 4 assassins are playable. That means playable, not good. They provide annoyance and can be used as psychological distraction against some opponents, but that does not make them killy or even *that* dangerous. In my experience even the most generous in terms of choppa, the Eversor, won't kill that many models, because regardless of his many attacks, depending on the weapon he uses he lacks either the strength or the AP to really inflict pain. The others have good AP, but they all lack both attacks and strength, so, in conclusion...unimpressed. Yeah, once you start buying multiple assassins, you quickly enter the realm of 'I could have had a whole MT detachment for that price'. But they arn't screaming murder machines on the drug cocktail to end all drug cocktails And I for one am glad about that. Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932419 Share on other sites More sharing options...
narcolepticltd Posted November 16, 2017 Share Posted November 16, 2017 I always liked the assassins in the old daemon hunters codex... the biggest issue I have with them currently is the super inflated price tag per model, so I'm pretty much boycotting them - $32 a pop for a tiny, 5-7 part sprue of plastic? Nope nope nope nope nope. duz_, JBugman and Guardsman Bob 3 Back to top Link to comment https://bolterandchainsword.com/topic/341334-using-assassins/#findComment-4932792 Share on other sites More sharing options...
