Harrowmaster Posted November 16, 2017 Share Posted November 16, 2017 Guys, I was wondering if anyone has experience getting a carry case through airport security? Specifically the small skirmish one. I don't have the ability to bring a checked bag on the plane so I'm wondering if I'll be stopped if I put a case in my carry on? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/ Share on other sites More sharing options...
Harrowmaster Posted November 16, 2017 Author Share Posted November 16, 2017 (edited) · Hidden by Brother Casman, November 16, 2017 - No reason given Hidden by Brother Casman, November 16, 2017 - No reason given Edit: Mispost Edited November 16, 2017 by Harrowmaster Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933157
Black Cohort Posted November 16, 2017 Share Posted November 16, 2017 As long as you can open the case and show what is inside I doubt you will have issues. But I have never travelled through airport security with miniatures. Personally I would rather have it as a carry on, who knows what would happen if it was checked. Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933159 Share on other sites More sharing options...
NiceGuyAdi Posted November 16, 2017 Share Posted November 16, 2017 If you’re taking metal miniatures you may want to check with the airline. All it takes is an overzealous security worker deeming the pointy bits potential weapons and you’ll likely not see them again. I was travelling with a photographer once who nearly got into hot water when one official insisted that his rubber lens blower was in fact a bomb. D3L 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933171 Share on other sites More sharing options...
Harrowmaster Posted November 16, 2017 Author Share Posted November 16, 2017 It's going in the carry on and it's all plastic, only thing is I'm not sure if the case is forbidden by EU regulations. Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933219 Share on other sites More sharing options...
Ushtarador Posted November 16, 2017 Share Posted November 16, 2017 Transported my army in the carry on multiple times, never a problem ;) Harrowmaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933225 Share on other sites More sharing options...
Xenith Posted November 17, 2017 Share Posted November 17, 2017 Should be ok as long as there's no 2inch plus metal blades (old keeper of secrets, covenant, eisenhorn, etc) or hollow lead models (1990s Dreadnoughts). I heard a story about someone that had their ork dread cracked open as it was a hollow object they couldn't X-ray inside... Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933778 Share on other sites More sharing options...
NiceGuyAdi Posted November 17, 2017 Share Posted November 17, 2017 (edited) Most army transporting cases are similar in design to hardened cases used for camera kit like Peli Cases. Crews are forever taking those on flights because they’re largely baggage handler-proof, so it should be fine. Edited November 17, 2017 by NiceGuyAdi Steel Company 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933829 Share on other sites More sharing options...
m_r_parker Posted November 17, 2017 Share Posted November 17, 2017 Would have to echo everyone else here - as long as you're only transporting plastic or resin miniatures you should be ok. Just don't bring any hobby tools (i.e. anything sharp), glues or any paints in with your case. Hopefully that's a given, but with what I've seen people try to carry-on with them I wouldn't be overconfident on that. Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933848 Share on other sites More sharing options...
Harrowmaster Posted November 17, 2017 Author Share Posted November 17, 2017 Thanks for the answers guys, it's not the models I'm worried about being stopped so much as the actual case itself, I'm just hoping no one sees it as a 'blunt instrument' and decides it's too dangerous. Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4933857 Share on other sites More sharing options...
Steel Company Posted November 18, 2017 Share Posted November 18, 2017 (edited) One last piece of advice is make sure your case is well labelled, just encase it gets lost so that it can be returned to you. Edit: Also thanks to the post below mine, for making me think of this... Look at getting some documentation pouches, and put in three copies of a packing slip (an itemized list of the contents), with the closest HS code (harmonized sales code) for the items. Doing that really helps get through customs easier. Edited November 18, 2017 by Steel Company Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4934478 Share on other sites More sharing options...
D3L Posted November 18, 2017 Share Posted November 18, 2017 (edited) Things to be aware going transnational, is that certain airports like to crack things open to have a look at cavitiesStansted for one, don't glue your spartan doors shutI've never found a reliable way of transporting via air, long haul freight or separate air freight only, anything going on a an airliner with passengers is subject to much more scrutiny than those posted via DHL/equivalent or on a boat in a cargo containerI use the unbranded pelican cases, it's not the case or packaging that'll get you to tears, it's the airport authoritiesMy advice, pack it, insure it, post it. Do not travel with it. Edited November 18, 2017 by D3L Steel Company 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4934489 Share on other sites More sharing options...
thewarriorhunter Posted November 18, 2017 Share Posted November 18, 2017 I would also be very polite to any staff that will potentially inspect your bag and stress that you have expensive and delicate 'collectibles' in the case. That's terminology that is neutral and understandable to them. If you say miniatures they may get confused and become suspicious. Most people can understand what a collectible is in a general fashion, even if they don't what they are specifically looking at. Steel Company and Harrowmaster 2 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4934768 Share on other sites More sharing options...
Xenith Posted November 20, 2017 Share Posted November 20, 2017 Aim for a male inspector in their 20s. Tell them it's warhammer. I was bringing a bunch of metal models through in my hand luggage once and said I had metal warhammer in there, his response was "space marines?" Harrowmaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4935827 Share on other sites More sharing options...
M@verik115 Posted November 21, 2017 Share Posted November 21, 2017 I honestly wouldn't risk it. Most times it is alright, but you just need that one official who decides that they possess some kind of threat and go in the christmas bonus bin. D3L 1 Back to top Link to comment https://bolterandchainsword.com/topic/341405-bringing-cases-through-the-airport/#findComment-4936801 Share on other sites More sharing options...
