OnboardG1 Posted November 20, 2017 Share Posted November 20, 2017 Figured I'd post here since it's more recent: With the rare earth magnet - metal option how do you secure tanks to the case? Do you just use a separate foam case or do you magnetise the bottom of the tank somehow? Link to comment https://bolterandchainsword.com/topic/341519-storing-magnetised-tanks/ Share on other sites More sharing options...
Major_Gilbear Posted November 20, 2017 Share Posted November 20, 2017 You could try turning the tank upside-down (assuming that there is nothing sticking up past the turret ring) and let the magnet hold it to the metal tray? Failing that, yes, I would just use a foam-lined case or tray for tanks. :) OnboardG1 1 Back to top Link to comment https://bolterandchainsword.com/topic/341519-storing-magnetised-tanks/#findComment-4936083 Share on other sites More sharing options...
OnboardG1 Posted November 20, 2017 Author Share Posted November 20, 2017 You could try turning the tank upside-down (assuming that there is nothing sticking up past the turret ring) and let the magnet hold it to the metal tray? Failing that, yes, I would just use a foam-lined case or tray for tanks. Not a bad idea. Its going to inform what case I get for my mech guard. Link to comment https://bolterandchainsword.com/topic/341519-storing-magnetised-tanks/#findComment-4936109 Share on other sites More sharing options...
