lash144 Posted November 30, 2017 Share Posted November 30, 2017 Hey there, I am tweaking my 2k armoured / mechanised list at the moment and I'm wondering if I can cut some corners in the infantry department. Last game I had 5 mechanised squads + 10 scions and 3 scout sentinels for anti deepstrike. So yeah what are your experiences? How much Infantry does a armoured list really need? Also what's with Hellhounds for bubblewrap? Someone tested it? Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/ Share on other sites More sharing options...
micahwc Posted November 30, 2017 Share Posted November 30, 2017 I run 6 squads for the Brigade bonus, or groups of 3 for the battalion bonus if I run battalions instead. I think 6 squads is a good number, it gives you enough models to lose a few squads without it really effecting your army. BIG ROB OF DEATH 1 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947032 Share on other sites More sharing options...
our_baz Posted November 30, 2017 Share Posted November 30, 2017 (edited) Edit: mis-read the op. Disregard Edited December 1, 2017 by our_baz Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947033 Share on other sites More sharing options...
librisrouge Posted December 1, 2017 Share Posted December 1, 2017 If you’re running mech, 60 ish bodies is probably pushing the amount you’ll ever use on the table. If your putting boots on that ground, start with 200 and go from there. :) iceman2160 and Die4Emprah 2 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947137 Share on other sites More sharing options...
Nicodemus Doloroso Posted December 1, 2017 Share Posted December 1, 2017 6 squads mechanized would cost about 1000 points so I assume you're talking foots logging Baz? Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947174 Share on other sites More sharing options...
duz_ Posted December 1, 2017 Share Posted December 1, 2017 I run 4 on foot and usually find that adequate :) Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947215 Share on other sites More sharing options...
Kinstryfe Posted December 1, 2017 Share Posted December 1, 2017 Any proper Imperial Guard army should have approximately ALL of the infantry. As for this newfangled "Astra Militarum", I have no idea. But enough squads to fill out a Brigade seems sensible. TheShredder and Harrowmaster 2 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947221 Share on other sites More sharing options...
Imperator Deus Posted December 1, 2017 Share Posted December 1, 2017 Previously I always took 9 infantry squads and 2 30-man Conscript Squads, but I haven't tried running mechanized infantry in 8th yet. I haven't figured out what I'm going to do since Concripts aren't really worth it anymore. I'll have 180 points to spend, I might take 2 or 3 more Infantry Squads, or maybe add a Leman Russ with Battle Cannon and Heavy Bolter. I field a Brigade and most of the slots are already pretty full, except for Fast Attack, which usually has a Hellhound and 2 single Sentinels. There aren't really that many FA options anyway, and I only own 1 Hellhound and 5 Sentinels so I'm limited by my collection too. If I was going to run Mechanized I would aim for 6 squads myself, but as I said above I don't have any direct experience with Mechanized Infantry in 8th yet. I have been curious to try it out though. A buddy of mine has a Steel Legion army and I asked him the same question a while back. He runs 6 Infantry Squads and says he probably wouldn't field less than that. I guess it all depends on what else you're fielding and what you're likely to be up against though. Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947245 Share on other sites More sharing options...
our_baz Posted December 1, 2017 Share Posted December 1, 2017 6 squads mechanized would cost about 1000 points so I assume you're talking foots logging Baz? Yup foot slogging, mis-read the op. My bad. Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947319 Share on other sites More sharing options...
lash144 Posted December 1, 2017 Author Share Posted December 1, 2017 I run 4 on foot and usually find that adequate :) In addition to your X mechanised squads? Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947386 Share on other sites More sharing options...
Halfpint100 Posted December 1, 2017 Share Posted December 1, 2017 I usually run 6+ squads in most of my lists. Good sacrifices with double move order Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947391 Share on other sites More sharing options...
Mordian Glory Posted December 1, 2017 Share Posted December 1, 2017 For a foot list you want 150 line infantry + Support elements (total around 200 bodies) For a mixed list you want 100 line infantry, your support elements should be tanks/arty For a mechanized/armoured list you want 60 infantry, preferably in transports. lash144 and The Ergonomic Enginseer 2 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947393 Share on other sites More sharing options...
CoffeeGrunt Posted December 1, 2017 Share Posted December 1, 2017 The only real answer is the flavour text on this card: TheShredder 1 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947412 Share on other sites More sharing options...
Malakithe Posted December 1, 2017 Share Posted December 1, 2017 My Catachan mixed list has 9 infantry squads, supporting guys, and 9 vehicles. Target saturation at its finest Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947415 Share on other sites More sharing options...
lash144 Posted December 1, 2017 Author Share Posted December 1, 2017 For a foot list you want 150 line infantry + Support elements (total around 200 bodies) For a mixed list you want 100 line infantry, your support elements should be tanks/arty For a mechanized/armoured list you want 60 infantry, preferably in transports. Ok so 5 mechanised squads + 10 Scions wasn't that bad. @CoffeeGrunt Sure more stuff is always better, especially as a guard player. But there's also lots of other stuff I would like to fit in, e.g. Hellhounds. Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947422 Share on other sites More sharing options...
CoffeeGrunt Posted December 1, 2017 Share Posted December 1, 2017 I do love me some Hellhounds these days. lash144 1 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947424 Share on other sites More sharing options...
duz_ Posted December 1, 2017 Share Posted December 1, 2017 I run 4 on foot and usually find that adequate :) In addition to your X mechanised squads? Nope, just 4x infantry squads + 2x 5-man scion squads, then lots of other goodies. :) seems to have served me well so far. Silas7 and lash144 2 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947598 Share on other sites More sharing options...
FallenSoldiers Posted December 1, 2017 Share Posted December 1, 2017 The only real answer is the flavour text on this card: I read the topic and was coming here to post “more!”... you beat me to it! Good man! CoffeeGrunt 1 Back to top Link to comment https://bolterandchainsword.com/topic/341879-how-much-infantry-do-i-really-need/#findComment-4947711 Share on other sites More sharing options...
