you check from one model in the unit
You roll each shot separately and check the range for each weapon you intend to fire. The single range check in step 2 is to decide if your preferred target is even a valid option to declare against, it's not a single range check for the unit.
If some models are outside of 12" range they suffer -1 to hit.
I don't think that is correct. If I have 10 shooting models in range on only one enemy model in a unit of several models I am in range and can roll to hit an roll to wound. (why is there suddenly a requirement to roll each shot one at a time. If I am in range on one model in the unit I am in range of the unit?) It's then up to the opposing play to make saves as they see fit.  Why would I split my to hit rolls if some of them models in that unit are further than 12" away. I only need range to one model when shooting. Why is there a difference?
Edited by Warhead01
Was trying to see if one model of the firing unit needed to be within 12 or all the models firing. I.e. 5 bolters . Only one is within 12 inch of the alpha legion cultists with -1 to hit. So would one hit at normal bs and the rest hit at -1.
Totally agree that the firing models only need to be in range of one model
I misunderstood . I thought it was a whole shooting unit with in 12" of a single model in a unit with that -1 ability. TheWolflord has it right in that instance.
Register a new account
Sign in
