Madmonkeyman Posted December 2, 2017 Share Posted December 2, 2017 How does stratagems that happen before the first turn but after the game start i.e. Deploy alpha legion infiltrating unit interact with stratagems that enable interceptor( i.e. Spacemarine / admech/ eldar stratagems ) I think they would be allowed to do it as it's after the game has started Link to comment https://bolterandchainsword.com/topic/341929-interceptor/ Share on other sites More sharing options...
TheWolfLord Posted December 2, 2017 Share Posted December 2, 2017 (edited) How does stratagems that happen before the first turn but after the game start i.e. Deploy alpha legion infiltrating unit interact with stratagems that enable interceptor( i.e. Spacemarine / admech/ eldar stratagems ) I think they would be allowed to do it as it's after the game has started The game doesn't start until the beginning of the first battleround. Deployment is pre game and so is everything before the first battleround. I'm assuming you're talking about Early Warning Override, if you are then that allows you to shoot at a unit that arrives mid game. It's late but I can't recall any definition of what mid game it. For all of those Stratagems the units are setup after the start of the first battleround but before the first turn begins. I'd assume once the first battleround begins the game has official began. Others may know of exact wording that confirms or contradicts that. Edited December 2, 2017 by TheWolfLord Link to comment https://bolterandchainsword.com/topic/341929-interceptor/#findComment-4949208 Share on other sites More sharing options...
Madmonkeyman Posted December 3, 2017 Author Share Posted December 3, 2017 The stratagems work against 'reinforcements' when they are deployed. So in the rule book they say reinforcements come in during the game mid phase. Alpha legion are set up outside of the turn - i.e. Not in a phase. They also have a definition : tactical reserves ( for matched play) - units that are not deployed on the battlefield during deployment which alpha legion would count as. Link to comment https://bolterandchainsword.com/topic/341929-interceptor/#findComment-4949457 Share on other sites More sharing options...
TheWolfLord Posted December 3, 2017 Share Posted December 3, 2017 The stratagems work against 'reinforcements' when they are deployed. So in the rule book they say reinforcements come in during the game mid phase. Alpha legion are set up outside of the turn - i.e. Not in a phase. They also have a definition : tactical reserves ( for matched play) - units that are not deployed on the battlefield during deployment which alpha legion would count as. I'm sorry I've only just realised what exactly you were asking. I thought you were asking about Tau Early Warning Override vs the Strike from the Shadows, Clandestine Infiltration and Forward Operatives I now realise you're asking about the Stratagems Auspex Scan, Infoslave Skull and Forewarned. So as you've alluded to you cannot use the Stratagems to fire on the units using SftS, CI and FO. It states reinforcements and they are defined as arriving mid turn, either in the movement phase or other phases. SftS, CI and FO are setup before the first game turn so don't arrive in a phase or mid turn. Link to comment https://bolterandchainsword.com/topic/341929-interceptor/#findComment-4949728 Share on other sites More sharing options...
Madmonkeyman Posted December 3, 2017 Author Share Posted December 3, 2017 Yeh it seems like RAW they are not reinforcements as you said . Link to comment https://bolterandchainsword.com/topic/341929-interceptor/#findComment-4949793 Share on other sites More sharing options...
