Jamesb_05 Posted December 5, 2017 Share Posted December 5, 2017 Here to do what it says on the tin really, anyone got any ideas I can shamelessly steal and take for my own? Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/ Share on other sites More sharing options...
hushrong Posted December 5, 2017 Share Posted December 5, 2017 One idea I had was to get something like speaker mesh to cover the business end of an ectoplasma launcher from a forgefiend. Been humming and hawing over it to use as a blastmaster for a helbrute. Just cut out a small piece and try to fit into that mouth opening, the jagged teeth holding it in place and figure out how to mount it to a helbrute. Lords of Preyspire 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4951863 Share on other sites More sharing options...
MDops Posted December 5, 2017 Share Posted December 5, 2017 (edited) The mesh seems like a good idea but would use the missile arm as a massive sub woofer Edited December 5, 2017 by MDops Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952068 Share on other sites More sharing options...
hushrong Posted December 5, 2017 Share Posted December 5, 2017 That actually sounds rad. Lords of Preyspire 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952166 Share on other sites More sharing options...
Maschinenpriester Posted December 6, 2017 Share Posted December 6, 2017 I made two from.the brutes plasma cannon. i cut the middle.part out, and inserted two long tubes and added some hoses and a mesh in the mouthn with greenstuff. Going to post pictures tonight, when i am back from work. Lords of Preyspire 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952382 Share on other sites More sharing options...
Filkarion Posted December 6, 2017 Share Posted December 6, 2017 I wanted to try it out and, for the sake of simplicity, I just added the chaos "open weapon mouth" in chaos vehicle sprue to the DV Hellbrute's Melta Not the best conversion but superfast Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952592 Share on other sites More sharing options...
Sception Posted December 6, 2017 Share Posted December 6, 2017 large daemonically mutated & ornately adorned amps rising from the dread's back & replacing the arms. A ripped-open, exposed front chasis revealing the zombified upper torso of the husk of a noise marine entombed within, all mechanically & daemonically wired into the interior. The 'pilot' is playing a multineck guitar which is in turn wired into the dreadnought's systems concept art (please forgive quality, I'm working with a track pad here) Kierdale, shandwen, Iron Father Ferrum and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952837 Share on other sites More sharing options...
Sception Posted December 6, 2017 Share Posted December 6, 2017 alternatively, the same exposed zombie playing instrument concept, but instead of guitar & amps it's organ keyboard & pipes, possibly incorporating SoB Exorcist bits hushrong 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952854 Share on other sites More sharing options...
hushrong Posted December 6, 2017 Share Posted December 6, 2017 alternatively, the same exposed zombie playing instrument concept, but instead of guitar & amps it's organ keyboard & pipes, possibly incorporating SoB Exorcist bits I'd actually like this if they could make the pipes similar to the old Noise Marine champ who had the leering faces/ organ backpack. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952858 Share on other sites More sharing options...
Lords of Preyspire Posted December 6, 2017 Share Posted December 6, 2017 You’ll need to find someone to part with the forge fiend back pipes! Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952902 Share on other sites More sharing options...
hushrong Posted December 6, 2017 Share Posted December 6, 2017 That'd work. And then cram in a few more pipes with plasticard tube and cut out faces using something like a soldering knife/tip. Probably just add some clamps with rivets to the piping and find something to give the tops a 'crown' like the forgefiend exhaust pipes. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4952935 Share on other sites More sharing options...
Kierdale Posted December 6, 2017 Share Posted December 6, 2017 Here’s mine. Still WIP: It has a single blastmaster as that was the old armament. Likely I’ll just say it’s bloody loud rather than add a second barrel to twin link it. Filkarion, Slave to Darkness, Evil Eye and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4953223 Share on other sites More sharing options...
Filkarion Posted December 7, 2017 Share Posted December 7, 2017 (edited) ...then Kierdale arrives from the land of the rising sun and shows us how to do a proper job Edit: to make my comment a bit more useful...where did you pick up that missile launcher from? Edited December 7, 2017 by Filkarion Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4953657 Share on other sites More sharing options...
Kierdale Posted December 7, 2017 Share Posted December 7, 2017 ...then Kierdale arrives from the land of the rising sun and shows us how to do a proper job Edit: to make my comment a bit more useful...where did you pick up that missile launcher from? Not at all! It’s just one idea. :) The missile launcher is actually the one from within a drop pod. I’m glad to hear it’s not immediately recognisable. I really must get back to that model and finish it. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4953684 Share on other sites More sharing options...
Filkarion Posted December 7, 2017 Share Posted December 7, 2017 (edited) Not at all! It’s just one idea. Jun one _ very cool_ idea! I will soon convert something akin thanks to you! Seems i finally found what to do with a half destroyed dreddy and the Heldrake hind legs Edited December 7, 2017 by Filkarion Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4953748 Share on other sites More sharing options...
Sception Posted December 8, 2017 Share Posted December 8, 2017 (edited) Kierdale's looks great. But if I might offer a few humble suggestions: Edited December 8, 2017 by malisteen Panzer and Kierdale 2 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4954635 Share on other sites More sharing options...
hushrong Posted December 8, 2017 Share Posted December 8, 2017 Kierdale, that sonic dread is pretty rad! I kind of echo malisteen in bulking up the blastmaster a wee bit but you have made a damn cool dread. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4954678 Share on other sites More sharing options...
Maschinenpriester Posted December 8, 2017 Share Posted December 8, 2017 (edited) Here a bit delayed as promised a picture of my two Hellbrute- Blastmasters: In my Opinion the big advantages of using the Plasma Connon are: - The Helbrute Plasma Cannon does not work for me in 8th - Its all magnetizable easily with the test of the parts - as I tend to magnetize all options Besides I also converted myself a sonic weapon for terminators, maybe that is some inspiration too: Kida stole the Idea from Kieridale, who was using it for a sonic landspeeder if I remember correctly. I use it as a counts as heavy flamer / autocannon - depending what i want to play. ;) Hope it helps. I am sorry for the :cussty Phone pictures. Constructive critizism is also always welcome. I documented the production process, but somehow the pics got corrupted >.< Edited December 8, 2017 by Maschinenpriester Kierdale, hushrong, Carrack and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4954744 Share on other sites More sharing options...
Lords of Preyspire Posted December 8, 2017 Share Posted December 8, 2017 I love the huge terminator one! Fantastic. Can we have a sonic club page on the same vain as the chooooom crew? Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4954772 Share on other sites More sharing options...
hushrong Posted December 8, 2017 Share Posted December 8, 2017 The terminator one is epic! I also need to use those green stuff pipe rollers. That adds so much to the weapon. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4954822 Share on other sites More sharing options...
Sception Posted December 9, 2017 Share Posted December 9, 2017 That terminator conversion does look amazing! But if I could, again, make one or two tiny little suggestions: brettfp, Maschinenpriester and Panzer 3 Back to top Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4955549 Share on other sites More sharing options...
Evil Eye Posted December 9, 2017 Share Posted December 9, 2017 I'm using an old metal Broadside Railgun as the basis for a Blastmaster. It's attached to one of the Dreadnought weapon mounts (my Helbrute is based on the Venerable Dreadnought kit, back from the days of Ferrum Infernus Dreadnoughts being things) and I've sawn a Daemon Prince head in half to act as a starting point for a "muzzle gargoyle". There's also some other miscellaneous junk added here and there, notably a Tau shield generator and a circular bit from a Chaos Bike, along with some Plasticard, It's far from finished but hopefully it'll look the part. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4955569 Share on other sites More sharing options...
Kierdale Posted December 11, 2017 Share Posted December 11, 2017 :D I’ll see what I can do about bulking up the blastmaster on my dread. As for the pilot carrying a guitar...perhaps not this time. I’m tempted to do some kind of tank with a sonic weapon (performer) on top sometime though. And Maschinenpriester’s terminator there is exactly what I want to do for my Obliterators, with different kinds/mountings of sonic weapons, with plenty of tentacles. Put the ‘flesh’ into ‘flesh weapons’. Link to comment https://bolterandchainsword.com/topic/342014-sonic-dreadnought-conversion-ideas/#findComment-4956676 Share on other sites More sharing options...
