Dark Bjoern Posted December 7, 2017 Share Posted December 7, 2017 Greetings fellow heretics! For several weeks i´m thinking about the problem how to equip DG Predators best? Option 1: Predator Auto Cannon 2 HB A good infantry killer and quite cheap. But i don´t know if i need more fire anti infantry firepower. And i don´t know if the armament will be any good against tanks. Option 2: Predator Auto Cannon 2 Las Cannons The two Las Cannons make this option expensive. What do you think about the AC/LC mix? Option 3: Predator twin Las Cannon 2 Las Cannons Very expensive and very specialized. But a lot of long range anti tank firepower. What worked best for you? What are your experiences with Predators in 8th Ed? Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/ Share on other sites More sharing options...
BlackTriton Posted December 7, 2017 Share Posted December 7, 2017 (edited) First will state that I havrle no experience with deathguard predator. That said, I would consider ped. auto cannon + las x3 so I can use the kill shot strat. You should always build your list with stratgem in mind! That and share more of the list you have in mind, a good predator load out in vacuum may be a bad fit for your list! Edited December 7, 2017 by BlackTriton Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/#findComment-4954013 Share on other sites More sharing options...
Praetoria Posted December 8, 2017 Share Posted December 8, 2017 I typically run: Lascanoon Pred with Havoc Launcher and Autocannon, Heavy Bolters and Havoc Launcher Pred. Both are invaluable and you cant go wrong with either. The Las pred can and will generally destroy a land raider in one shot. The autocannon is good for shooting at multi wound models and tanks. The havoc launcher I have found to be useful in putting on a wound or two on tanks or goes well with targeting infantry. Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/#findComment-4954343 Share on other sites More sharing options...
TURBULENCE Posted December 8, 2017 Share Posted December 8, 2017 My predator is somewhat of an odd layout. Autocannon and las, with added havoc launcher and components. If I were more competitive i'd drop the extra weapons but the autocannon often does more work than the 2 las do for me. Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/#findComment-4954378 Share on other sites More sharing options...
Dark Bjoern Posted December 8, 2017 Author Share Posted December 8, 2017 Thanks for the respons, brothers! The Stratagem is the main reason why i wanna have 3 Predators. I´ve different options how to run my DG. Typhus with 60 Poxwalkers and a hard core of 2 squads Blightlords and 1 squad Deathshrouds or replacing the Poxwalkers with 3 squads Plague Marines. Both list should be around 2500 points. Typhus Plaguecaster 3x 20 Poxwalker 5 Blightlords: 3 Combi-Melta, 1 Flail, 1 Blight Launcher 5 Blightlords: 3 Combi-Plasma, 1 Flail, 1 Reaper Autocannon 3 Deathshrouds Plague Surgeon with Helmet or Typhus Plaguecaster 7 PM: 3 Plasma guns, 7 PM: Plasma Pistol, 2 Melta 7 PM: Fist/Sword, 2 Flails, 4 Axes/Knifes 5 Blightlords: 3 Combi-Melta, 1 Flail, 1 Blight Launcher 5 Blightlords: 3 Combi-Plasma, 1 Flail, 1 Reaper Autocannon 3 Deathshrouds The rest will be filled up with three Predators or three Crawlers and some drones. I´m not sure if the loadout of the squads will give me enough anti tank firepower specially facing AM with 6 Leman Russ. Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/#findComment-4955027 Share on other sites More sharing options...
Marshal Loss Posted December 8, 2017 Share Posted December 8, 2017 (edited) I think if you take a Predator, they should be loaded up with all lascannons. I'd probably be more inclined to take plagueburst crawlers though. Edited December 8, 2017 by Marshal Loss Link to comment https://bolterandchainsword.com/topic/342082-how-to-equip-dg-predators/#findComment-4955212 Share on other sites More sharing options...
