Malakithe Posted December 9, 2017 Share Posted December 9, 2017 Anyone have any pics of comparison shots of Goliaths next to standard Cadians? I want to scratch build a Catachan force and looking for ideas. If the Goliaths are too ridiculous then ill wait for the awesome looking Orlocks Link to comment Share on other sites More sharing options...
Feral_80 Posted December 9, 2017 Share Posted December 9, 2017 They are almost the same height, but much wider. They don't look ridiculous side by side, if you use the Goliaths as Catachans. The main problem is that they are designed for 32mm bases. I am not 100% sure of the strictness of the rules for basing in this edition (if any), since base size does not matter that much anymore now that templates are gone. But I believe you would still need to put them on 25mm bases, and that might be a bit difficult/inconvenient for some of the poses of the Goliath. Still, it can be done. Link to comment Share on other sites More sharing options...
Malakithe Posted December 9, 2017 Author Share Posted December 9, 2017 They are almost the same height, but much wider. They don't look ridiculous side by side, if you use the Goliaths as Catachans. The main problem is that they are designed for 32mm bases. I am not 100% sure of the strictness of the rules for basing in this edition (if any), since base size does not matter that much anymore now that templates are gone. But I believe you would still need to put them on 25mm bases, and that might be a bit difficult/inconvenient for some of the poses of the Goliath. Still, it can be done. Hmm...this gives me hope then. Yeah as far as I know there are no basing 'rules' but 25mm might be difficult. Not to mention equipping those beefy dudes with Cadian standard weapons like lasguns and the occasional plasma gun..Orlocks on the other hand would be super simple to swap arms/weapons Link to comment Share on other sites More sharing options...
Atia Posted December 9, 2017 Share Posted December 9, 2017 They are almost the same height, but much wider. They don't look ridiculous side by side, if you use the Goliaths as Catachans. The main problem is that they are designed for 32mm bases. I am not 100% sure of the strictness of the rules for basing in this edition (if any), since base size does not matter that much anymore now that templates are gone. But I believe you would still need to put them on 25mm bases, and that might be a bit difficult/inconvenient for some of the poses of the Goliath. Still, it can be done. Hmm...this gives me hope then. Yeah as far as I know there are no basing 'rules' but 25mm might be difficult. Not to mention equipping those beefy dudes with Cadian standard weapons like lasguns and the occasional plasma gun..Orlocks on the other hand would be super simple to swap arms/weapons There are no basing rules other than "not smaller", afaik. So no, 32mm bases are no problem for your Guard :) Link to comment Share on other sites More sharing options...
Malakithe Posted December 9, 2017 Author Share Posted December 9, 2017 They are almost the same height, but much wider. They don't look ridiculous side by side, if you use the Goliaths as Catachans. The main problem is that they are designed for 32mm bases. I am not 100% sure of the strictness of the rules for basing in this edition (if any), since base size does not matter that much anymore now that templates are gone. But I believe you would still need to put them on 25mm bases, and that might be a bit difficult/inconvenient for some of the poses of the Goliath. Still, it can be done. Hmm...this gives me hope then. Yeah as far as I know there are no basing 'rules' but 25mm might be difficult. Not to mention equipping those beefy dudes with Cadian standard weapons like lasguns and the occasional plasma gun..Orlocks on the other hand would be super simple to swap arms/weapons There are no basing rules other than "not smaller", afaik. So no, 32mm bases are no problem for your Guard With as many bodies are in the list it could be viewed as power gaming due to the sheer amount of board control that would exist. But those weapon arms are still worrisome Link to comment Share on other sites More sharing options...
