Nekro83 Posted December 9, 2017 Share Posted December 9, 2017 Hi guys! Going to take some basilisks ro my iron warriors. Am i obliged to take heavy bolters on them? Link to comment https://bolterandchainsword.com/topic/342145-basilisks/ Share on other sites More sharing options...
Malakithe Posted December 9, 2017 Share Posted December 9, 2017 Hi guys! Going to take some basilisks ro my iron warriors. Am i obliged to take heavy bolters on them? They are a stock item Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4955601 Share on other sites More sharing options...
Halfpint100 Posted December 9, 2017 Share Posted December 9, 2017 Yes you need a heavy bolter or a heavy flamer on them Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4955604 Share on other sites More sharing options...
duz_ Posted December 9, 2017 Share Posted December 9, 2017 From memory the kit only comes with a HB although the codex allows for heavy flamers too. You could magnetise it easy enough to switch as needed. Personally I prefer the HB as a cheap and cheery option Guardsman Bob 1 Back to top Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4955697 Share on other sites More sharing options...
Nekro83 Posted December 9, 2017 Author Share Posted December 9, 2017 Ok thank you! Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4955703 Share on other sites More sharing options...
Major_Gilbear Posted December 10, 2017 Share Posted December 10, 2017 From memory the kit only comes with a HB although the codex allows for heavy flamers too. You could magnetise it easy enough to switch as needed. Personally I prefer the HB as a cheap and cheery option Depends - the current version of the kit as sold directly by GW comes with the IG Vehicle Accessory Sprue, which has a HF on it. ;) duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4956481 Share on other sites More sharing options...
Nicodemus Doloroso Posted December 10, 2017 Share Posted December 10, 2017 In the old days my heavy flamer equipped Basilisk caught a few opponents off guard and caused much rage when a weapon destroyed was rolled and they thought the Basilisk was totally neutralized without it’s Earthshaker. Then it rolled up and cooked some tightly packed unawares infantry. It wouldn’t have the same shock effect now but could still work with a weakened bassie since damage would not impact the HF. Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4956527 Share on other sites More sharing options...
Withershadow Posted December 10, 2017 Share Posted December 10, 2017 Heavy flamers are too expensive for that. If it was an even swap for heavy bolters, then sure. Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4956619 Share on other sites More sharing options...
WarriorFish Posted December 11, 2017 Share Posted December 11, 2017 Yep, the heavy flamer is still a good hull weapon for Bassies but unfortunately not so much for the price tag. Shame I built mine before I started with magnets Link to comment https://bolterandchainsword.com/topic/342145-basilisks/#findComment-4956852 Share on other sites More sharing options...
