Wargamer Posted December 10, 2017 Share Posted December 10, 2017 I'm planning to build a Captain in Corvus armour, but I'm not sure what models are best to use as a starting point. Any thoughts? In particular, I want to have the greaves and shoulders correct. Link to comment https://bolterandchainsword.com/topic/342182-corvus-captain-need-a-base-model/ Share on other sites More sharing options...
sockwithaticket Posted December 10, 2017 Share Posted December 10, 2017 Captain Korvydae? Arms and head are separate so there's room for a little customisation.Sticking to the 'correct' pads is going to be a bit dull for Captain imo and HQs generally have leeway for unique, blingy pads. I'd skip the studded one at least.The Sternguard and Vanguard kits have some bling encrusted mk. VI legs. Those kits could also provide you with cool pads, there's a few that are sort of up-armoured versions of the smooth mk. VI pad; they have a mk.III top part but no rim on the bottom and part way up the side http://www.bitzbox.co.uk/images/space_marine_vanguard_legs_3.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_legs_4.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_legs_3.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_shoulder_pad_1.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_shoulder_pad_2.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_shoulder_pad_3.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_shoulder_pad_4.jpghttp://www.bitzbox.co.uk/images/space_marine_sternguard_shoulder_pad_5.jpg Major_Gilbear and Kinstryfe 2 Back to top Link to comment https://bolterandchainsword.com/topic/342182-corvus-captain-need-a-base-model/#findComment-4956503 Share on other sites More sharing options...
spiros14 Posted December 10, 2017 Share Posted December 10, 2017 I know it isn't the same as building one from scratch, but are you aware of the "master of recruits," captain from the masters of the chapter box? He's got the corvus armour (bar helmet, although one can be put on) a big swooshy cape Space Marine Captains love to wear, and a (IMO) kickass pose. Major_Gilbear 1 Back to top Link to comment https://bolterandchainsword.com/topic/342182-corvus-captain-need-a-base-model/#findComment-4956561 Share on other sites More sharing options...
Wargamer Posted December 10, 2017 Author Share Posted December 10, 2017 Oh yeah, Master of Recruits is a really good candidate. I was thinking of doing bolter and power sword so the wargear is spot on. As you say, a headswap wouldn't be that hard to do if needs be. Link to comment https://bolterandchainsword.com/topic/342182-corvus-captain-need-a-base-model/#findComment-4956606 Share on other sites More sharing options...
