Brother Bish Posted December 11, 2017 Share Posted December 11, 2017 Greetings Brothers, I'm working on an Azrael conversion using the old metal Limited Chapter Master with the Combi-bolter plasma gun in his right hand pointing up. Since his left arm is covered by his cloak, I've been trying to find a sword in it's scabbard to represent Azrael sword. I have an old metal Cypher sword that would work, but I hate to scavenge that model since you can't buy the old Cypher anymore. So does anyone have any bitz suggestions for a sword in it's scabbard? Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/ Share on other sites More sharing options...
Bryan Blaire Posted December 11, 2017 Share Posted December 11, 2017 Could always use the Templar scabbard and simply replace the crossguard with a DA appropriate one. You can also replace the Templar wax on the purity seal with a DA appropriate one. Brother Bish 1 Back to top Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4956677 Share on other sites More sharing options...
Brother Bish Posted December 11, 2017 Author Share Posted December 11, 2017 Good idea, I think I might actually have one of those. I'll dig through my bits and see. Thanks. Bryan Blaire 1 Back to top Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4956702 Share on other sites More sharing options...
FlamingDeth Posted December 11, 2017 Share Posted December 11, 2017 I’m also rather fond of this one, if you don’t mind shaving off chaos arrows. I think it looks a little closer to regular Azrael’s sword than the Templar one. Bryan Blaire and Brother Bish 2 Back to top Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4956730 Share on other sites More sharing options...
Brother Bish Posted December 11, 2017 Author Share Posted December 11, 2017 Thanks, your right the black Templar one does seems a little short. I'll check this one out too. Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4956769 Share on other sites More sharing options...
Aradiel Posted December 11, 2017 Share Posted December 11, 2017 I converted a watcher in the dark to carry a sword. So my Azrael goes around with two watchers. Brother Bish 1 Back to top Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4956800 Share on other sites More sharing options...
Brother Bish Posted December 11, 2017 Author Share Posted December 11, 2017 (edited) I converted a watcher in the dark to carry a sword. So my Azrael goes around with two watchers.That's actually not a bad idea either. I ordered the chaos sword, so I'll see how that works and if not maybe try the Watcher. I've been working on modifying watchers for my Deathwing squads so they don't all look the same as it is. All good idea thanks guys! Edited December 11, 2017 by Brother Bish Link to comment https://bolterandchainsword.com/topic/342194-bitz-suggestion-for-azrael-conversion/#findComment-4957095 Share on other sites More sharing options...
