Charlo Posted December 12, 2017 Share Posted December 12, 2017 So because Inceptors cost £30 for 3 models and Hellblasters are £37.50 for Ten with a BA upgrade sprue, I'm thinking of using converted Hellblasters as Inceptors. Sticking on a Jump Pack is easy enough... But what about adding a bit of bulk to convey that T5? What do people think might be an elegant solution? Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/ Share on other sites More sharing options...
shandwen Posted December 12, 2017 Share Posted December 12, 2017 If cost is a real issue pick up the guys from the starter sets, if you want plasma come plasma cannons can't be too difficult to find. Stoic Raptor, Major_Gilbear and Dosjetka 3 Back to top Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4958057 Share on other sites More sharing options...
Major_Gilbear Posted December 12, 2017 Share Posted December 12, 2017 Agreed; the snap-fit models are already the correct minis, and weapon swaps are normally pretty easy. Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4958070 Share on other sites More sharing options...
carnosaur93 Posted December 12, 2017 Share Posted December 12, 2017 i'd say a jump-pack (the classic assault marine kind because of its size, rather than say the sanguine guard packs) and the shock absorbers would go a very long way to make them look the part, especially if you also repose them abit to be more dynamic and "jumpy" (which can also be used for extra height with the classic "tiptoeing on rocks" sorta setup) aside from that i'll echo just getting the snap fit ones and maybe use old spare plasma guns or something for them if you want that dualwielding look. they come in both the "know no fear" and "dark imperium" boxes, so getting a decent chunk of them should not be too hard considering the low numbers you'd normally field these guys in Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4958102 Share on other sites More sharing options...
Stoic Raptor Posted December 12, 2017 Share Posted December 12, 2017 I think adding Jump Packs to Hellblasters is honestly about the most inelegant solution. There are so many ways to obtain the real models inexpensively and mofiying them would still be easier than the original idea. Blindhamster 1 Back to top Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4958118 Share on other sites More sharing options...
Blindhamster Posted December 12, 2017 Share Posted December 12, 2017 agreed, inceptors are cheap online if you want inceptors, for example a quick ebay search: https://www.ebay.co.uk/itm/Warhammer-40k-Primaris-Inceptor-Squad/272967162552?hash=item3f8e1c5ab8:g:tusAAOSwUM5aJF1U 10 quid for 3 bolter inceptors from Dark Imperium. you can get the plasma guns for them for about 4 quid per marine from bits sites, or you could have a pop at making your own using plasma canons.or, just buy a regular squad of inceptors from an alternative source that sells at discount (element games, dark sphere etc).they have two plasma weapons, so whatever models you make should ideally also have two. shandwen 1 Back to top Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4958293 Share on other sites More sharing options...
Charlo Posted December 13, 2017 Author Share Posted December 13, 2017 *cough* Well I mean I have already done this ;) But I was asking for conversions because I quite like the Plasma Rifles! Damo1701 1 Back to top Link to comment https://bolterandchainsword.com/topic/342256-turning-hellblasters-into-inceptors/#findComment-4959110 Share on other sites More sharing options...
