advancing
march10k
When you declare that a unit is advancing, do you have to actually go farther from your starting point than your normal move allows?  If your move value is 8", for example, can you declare an advance, and then move 5", or do you have to end your move at least 8.000001" from your starting point?  There aren't many units that would find it useful to declare an advance and then not move a long distance (since you generally give up shooting to do so, and not mane units gain anything but extra movement from it), but they do exist...
https://bolterandchainsword.com/topic/342364-advancing/
Dark Angels Ravenwing that want to get the jink save but don't want to move all the way. Harlequiens that want to do something similar with Prismatic Blur. Anything else that gains something other than distance from advancing but may want to stay on an objective or in range of a particular enemy.
https://bolterandchainsword.com/topic/342364-advancing/#findComment-4960891
