chapter master 454 Posted December 15, 2017 Share Posted December 15, 2017 kind of needing some bits boxes as of late. Not only for loose bits but for the future I intend to magnetise units and thus need a good box for carrying the options the units will have. So kind of looking for any suggestions for which boxes may work best. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/ Share on other sites More sharing options...
The Yncarne Posted December 15, 2017 Share Posted December 15, 2017 I’ve used screw boxes in the past. However that didn’t scale for me. Now I used plastic sandwich bags based on the bit type - for example, space marine arms, tau plasma rifles, chaos shoulder pads etc. these bags then get placed in a faction box for easy identification. This approach let’s me then pitch the sprues and save space. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4960630 Share on other sites More sharing options...
chapter master 454 Posted December 15, 2017 Author Share Posted December 15, 2017 main use is currently got some wraithguard/blades who I am magnetising and so need a decent box that could keep parts separate and organised so i can chose which arms I need and when (fully magnetising so arms, guns, swords and axes). It is also nice to get recommendations for decent bits boxes in general as I do have a lot of spare bits currently lying around from my marines as well. More of a fan of hard boxes rather soft though. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4960641 Share on other sites More sharing options...
Deafbok Posted December 15, 2017 Share Posted December 15, 2017 Fishing tackle boxes. They've got well-sized compartments. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4960643 Share on other sites More sharing options...
MadGreek Posted December 15, 2017 Share Posted December 15, 2017 I use a simple plastic divided box that you can pick up at most craft stores. I actually got mine from the Container Store. Has extra dividers so I can customize size of the spaces. Brother Lunkhead 1 Back to top Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4960696 Share on other sites More sharing options...
DuskRaider Posted December 15, 2017 Share Posted December 15, 2017 I have about 4 arts and crafts containers with various bins in them for my bits. One for each army, then separated by type (head, arm, body, etc.). Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4960755 Share on other sites More sharing options...
Brother Lunkhead Posted December 16, 2017 Share Posted December 16, 2017 I use a simple plastic divided box that you can pick up at most craft stores. I actually got mine from the Container Store. Has extra dividers so I can customize size of the spaces. Great idea. I have the same kind of containers. They are fantastic for categorizing and storing bits. They store and travel well too btw MadGreek... Semper Fi Brother MadGreek 1 Back to top Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961037 Share on other sites More sharing options...
Xenith Posted December 16, 2017 Share Posted December 16, 2017 Magnetised bits go in the figure case with the models. I have a mix of screw/tool storage boxes and plastic bags with similar bits in them. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961130 Share on other sites More sharing options...
gitface Posted December 16, 2017 Share Posted December 16, 2017 (edited) I imagine something like this would do. [edit:] Just had a further look and found these ones that have more compartments. Also you are a vile temptress these were not on my radar, but I might pick up a couple as they would be handy. Edited December 16, 2017 by gitface Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961189 Share on other sites More sharing options...
Kurgan the Lurker Posted December 16, 2017 Share Posted December 16, 2017 Fishing tackle boxes. They've got well-sized compartments. I use tackle boxes as well. Large ones from Cabela's. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961356 Share on other sites More sharing options...
MadGreek Posted December 17, 2017 Share Posted December 17, 2017 I use a simple plastic divided box that you can pick up at most craft stores. I actually got mine from the Container Store. Has extra dividers so I can customize size of the spaces. Great idea. I have the same kind of containers. They are fantastic for categorizing and storing bits. They store and travel well too btw MadGreek... Semper Fi Brother Semper Fi! Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961711 Share on other sites More sharing options...
Scott-S6 Posted December 17, 2017 Share Posted December 17, 2017 (edited) I always use this range (there are various sizes). https://www.screwfix.com/p/stanley-fatmax-deep-pro-organiser/22910?tc=EA2&ds_rl=1249796&ds_rl=1245250&ds_rl=1249484&gclid=CjwKCAiApdPRBRAdEiwA84bo34j_ImCZOoSMsD9kRL1EEb_pvW08yUHapsUJbULQU391LhjokchbEhoCd2oQAvD_BwE&gclsrc=aw.ds&dclid=CPixid7EkNgCFctmGwodUnwA9A They are a bit more expensive than a tray with dividers or a tacklebox but being able to lift a section out as a tub makes it so much easier to work with your bits and go through bits of a type. You can also pour out a section in order to sort through it which is basically impossible with a divided tray or tacklebox. You also don't have the problem of bits migrating between sections that the other types have either. Worth every penny, you won't look back. Edited December 17, 2017 by Scott-S6 Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961714 Share on other sites More sharing options...
Subtle Discord Posted December 17, 2017 Share Posted December 17, 2017 Yep, go to a local dollar store (or similar type of shop) and get some storage containers from the tools section. They're low cost, most have adjustable compartments, many will stack, and if you run out of space you can simply get more to add to the stack. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961723 Share on other sites More sharing options...
Kinstryfe Posted December 17, 2017 Share Posted December 17, 2017 I'll add my voice to the inexpensive plastic divided containers. I have some larger and some smaller, depending on how big the kit I'm breaking down is. Let me shed a ton of sprues and I got several different colors they had to easily know what's in what. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961779 Share on other sites More sharing options...
chapter master 454 Posted December 17, 2017 Author Share Posted December 17, 2017 thanks for all suggestions guys. Looking at the ones with modular options might be a good idea. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4961968 Share on other sites More sharing options...
Todosi Posted December 17, 2017 Share Posted December 17, 2017 I like these for my hobby desk; https://www.amazon.com/Akro-Mils-10144-20-Inch-16-Inch-Hardware/dp/B003P2UOCO/ref=sr_1_2?ie=UTF8&qid=1513553261&sr=8-2&keywords=parts+bin I keep tools and whatnot in it as well as bits. Link to comment https://bolterandchainsword.com/topic/342369-recommendations-for-a-good-bits-box/#findComment-4962280 Share on other sites More sharing options...
