Helias_Tancred Posted December 19, 2017 Share Posted December 19, 2017 Subject line says it all. Trying to decide which one to build? I have no air assets at the moment. Down the road I plan to add a Stormraven. Thanks. Link to comment Share on other sites More sharing options...
ValourousHeart Posted December 19, 2017 Share Posted December 19, 2017 Why not make it both? It isn't that hard to do with that model... the only real decision you have to make is if you want the shrine or not. The rest of the weapons swap very easily if you build the model with swapping in mind. Helias_Tancred 1 Back to top Link to comment Share on other sites More sharing options...
AccidentalCultist Posted December 19, 2017 Share Posted December 19, 2017 Assuming swapping isnt an option, i personally went with the Dark Talon. it's cheaper and is able to provide 2 sources of mortal wounds. i also like the Hurricane Bolter to go at light infantry. I have also just added a Stormraven, the two paired up are quite a combo. Helias_Tancred 1 Back to top Link to comment Share on other sites More sharing options...
depthcharge12 Posted December 20, 2017 Share Posted December 20, 2017 I am edition based on hordes and causing large amounts of wounds, the Dark Talon is the much better choice to go for. If the Avenger cannon was D2 it would be a tough choice. Helias_Tancred 1 Back to top Link to comment Share on other sites More sharing options...
Helias_Tancred Posted December 20, 2017 Author Share Posted December 20, 2017 I'm thinking the Dark Talon too. Of course I will probably get a second box and build a Nephilim at some future point ;) Thanks for all the feedback brothers. Link to comment Share on other sites More sharing options...
Pvnisher Posted December 20, 2017 Share Posted December 20, 2017 Dark talons were my mvps during the games I played. Link to comment Share on other sites More sharing options...
Loar Posted December 20, 2017 Share Posted December 20, 2017 Dark Talon hands down. With its price reduction and combination of dakka and mortal wounds in a very hordes-heavy edition I would say its almost an auto-take. Pretty much all my competitive lists are gonna have two of them plus a Darkshroud (getting them a -2 to hit, discouraging opponent's turn 1 alpha from going on them, which was their biggest weakness). People are also gonna start realizing how good Speed of the Raven strat will be to use on them. Lets you move them 60 inches across the board, allowing an easy bomb drop + full normal shooting with your hurricane bolters and rift cannon (while also activating the protective ++4 from Jink for any next turn return fire). This can be used to even snipe out characters sitting on the other side of chaff if your opponent is not careful with their spacing. Dark Talons are definitely one of our star units now and unfortunately outshines the Nephilim in almost every aspect of the game. Link to comment Share on other sites More sharing options...
Kasper_Hawser Posted December 20, 2017 Share Posted December 20, 2017 As mentioned by most, Dark Talon seem to be the most versatile and useful overall now, with the Nephilim only slightly better in sniping monsters and tanks by virtue of lascannons and missiles. Nevertheless, the two look so similar that you should have no problem proxying it as the other whichever way you wish. Have fun with both using just one kit. Link to comment Share on other sites More sharing options...
Chaplain Lucifer Posted December 20, 2017 Share Posted December 20, 2017 Magnetize! Then you can have both when need one of them! Cpt. Bannockburn 1 Back to top Link to comment Share on other sites More sharing options...
Lion El Jason Posted December 20, 2017 Share Posted December 20, 2017 Its always Dark Talon. The requirement to move means you get -1 to hit with heavy weapons but this doesn't apply to bombs or hurricane bolters. Strafing run gives 2+ to hit with hurricane bolters after moving, the nephilim only has heavy weapons o its effectiveness drops dramatically. AccidentalCultist 1 Back to top Link to comment Share on other sites More sharing options...
AccidentalCultist Posted December 20, 2017 Share Posted December 20, 2017 Its always Dark Talon. The requirement to move means you get -1 to hit with heavy weapons but this doesn't apply to bombs or hurricane bolters. Strafing run gives 2+ to hit with hurricane bolters after moving, the nephilim only has heavy weapons o its effectiveness drops dramatically. I just assumed the strat was limited to bikers, then reread and the jaw dropped. Then I reread the Dark Talon rules and saw it has jink...and the jaw dropped further! i'm going to play a game in a couple hours and will be aiming to do this! bikes with plasma, dark talon shenanigans, a storm raven and deathwing knights --> multiple threats! Link to comment Share on other sites More sharing options...
