I am starting up a Tau army in 2018 and I am interested in including a Ghostkeel but I'm on the fence about what loadout to give it. Right now there are 2 possibilities I am considering.
1) Ghostkeel w. 2 stealth drones - Cyclic Ion Raker, 2x Burst Cannons, Advanced Targeting, Target Lock
2) Ghostkeel w. 2 stealth drones - Fusion Collider, 2x fusion, Shield Generator, Target Lock
I think option 2 fits with most of the lists I have played around with as they are a little lacking in anti-tank but its also ~50 points more expensive. I'm also a little concerned by the difference in the # of shots between the two options.
I may end up magnetizing but, in general, I'm not a huge fan of doing that.
Thoughts? What loadouts have other people had success with?
https://bolterandchainsword.com/topic/342734-ghostkeel-loadouts/
I used to play him with CIR+2xBC+ATS and Target Lock.
I tested a bunch of other combinations as well (including your second option) but none were as reliable and efficient as that one.
The fact that Commanders can do the anti-tank so much better and the additional 6" range on the CIR in case you want to play more carefully just sets the CIR loadout in stone for me. Sometimes I switchout the 2xBC with 2xFlamer to scare enemy melee and chaff away but it barely makes a difference.
However with the Chapter Approved Stratagem for easy 1d3+1 Markerlights I'm thinking about replacing the Target Lock with a Shield Generator on the CIR loadout. I haven't tested that one yet tho.
You are spot on the two Ghostkeels I usually play:
Except for the fusion one, I play that with the defense matrix. With 3 to 5 fusion blaster shots I usually keep him close to vehicles / characters and they don't really want to charge him... And he demolishes them really nice.
I personally run CIR + FBs + Target Lock + ATS. It's a more generalist option that I generally send after harder targets, loitering at >18" from serious threats. It's not the best loadout, but it's the one I had left over from 7th. :P
I'm not sure BCs would really bring the pain in an appreciable way for me.
I personally run CIR + FBs + Target Lock + ATS. It's a more generalist option that I generally send after harder targets, loitering at >18" from serious threats. It's not the best loadout, but it's the one I had left over from 7th. :tongue.:
They don't....but at least they are cheap and benefit from ATS more than Fusion Blaster. :P
But yeah I tried the CIR + FB loadout as well thanks to 7th edition but it just felt wrong to take ATS when you also paid points for FB so I eventually switched to Flamer as backup weapons in case I have to be close to the enemy for some reason.
Register a new account
Sign in
