Magos_Adephus Posted December 29, 2017 Share Posted December 29, 2017 Been thinking of how to do a conversion for a Macrocarid for a while, especially with FoC coming out next year. The FW model is amazing, but it doesn't really appeal to my tastes. The other part is I want to mount small Bluetooth speaker on it so I may play binahric choruses and soothing hymns during battle (also this: https://youtu.be/wy-sVTaZRPk ). I'll have to turn this thread into a WIP when I start. I'm torn between the Goliath Rockgrinder/Truck and the good ol' Land Raider for the chassis. The Goliath is what I first envisioned for the project, but it seems fairly undersized, both to proxy and for fitting a speaker into/onto. The Land Raider of course has far more room inside to hide the speaker's parts, and is much larger for proxying. Plus, many Great Crusade era Macrocarids were little more than refurbished and repurposed Land Raider's, so fluff-wise it'd make sense, whoever owned this particular one simple didn't wander far from the original design. Does anyone know how the Goliath and Land Raider compare size-wise? Also if anyone has seen/heard of this being done this before or is knowledgeable on adding electronic parts to models, any advice or ideas are welcome. Xisor 1 Back to top Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/ Share on other sites More sharing options...
Xisor Posted December 29, 2017 Share Posted December 29, 2017 I can't answer directly, but I've seen stripped down/under gunned Bane blade variants that might work too, e.g. The Banelord (?) - ones with transport capacity. Leaving off the bigger guns might make for a relatively massive and armoured, but not too combat-militarised looking vehicle. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4970015 Share on other sites More sharing options...
MajorNese Posted December 29, 2017 Share Posted December 29, 2017 Without a Goliath on hand, I can't directly compare the two. From what I remember, the goliath is slightly smaller than a chimera, and in no way comes close to a LandRaider. With the origin of the Macrocarid's rules as "Mechanicum LandRaider" in the first Heresy black books, I guess taking a LR or similar sized model is necessary. Adding speakers shouldn't be too hard, with small, cheap bluetooth speakers all over the marked. A friend built two in his Armies on Parade board simply by magnetizing shut the Sector Mechanicus tanks. Open them, put the (unmodified) speaker inside, snap back together. The LandRaider has quite a bit of space to use, and a lazy friend proved that leaving out the floor plate won't be noticed by anyone. Once you have a fitting speaker, I guess a speaker holder can be built from spare sprues. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4970393 Share on other sites More sharing options...
Magos_Adephus Posted December 30, 2017 Author Share Posted December 30, 2017 I've seen stripped down/under gunned Bane blade variants that might work too I'd considered crossing a Banehammer and Stormlord with a couple altercations, but after doing some size comparisons it's just too big (sadly. I don't own a Baneblade currently but I've wanted one for ages). Also LR is cheaper, so more money to splurge on extra, AdMech-y bits and speakers. Knowing me, my brain will probably convince myself that Rule of Cool is more important than proper planning, budgeting, and WYSIWYG a lazy friend proved that leaving out the floor plate won't be noticed by anyone. =D Sounds like something I'd do. Was this the Armies on Parade friend and did he win, I gotta know Xisor 1 Back to top Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4970559 Share on other sites More sharing options...
MajorNese Posted December 30, 2017 Share Posted December 30, 2017 a lazy friend proved that leaving out the floor plate won't be noticed by anyone. =D Sounds like something I'd do. Was this the Armies on Parade friend and did he win, I gotta know Nope, the lazy guy just left out every floor plate ever (for lazyness-related reasons). The AoP guy magnetized the storage tanks to insert speakers and give his board some advantage. Won Best Terrain, with a huge Sector Mechanicus construct. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4970572 Share on other sites More sharing options...
Red_Shift Posted December 31, 2017 Share Posted December 31, 2017 (edited) I have a goliath and a land raider. Would pics be helpful? Edit I can't believe goliath autocorrected to holiday Edited January 1, 2018 by Red_Shift Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4971440 Share on other sites More sharing options...
Magos_Adephus Posted January 1, 2018 Author Share Posted January 1, 2018 If it's not too much trouble, pics would be fantastic, thanks! Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4971533 Share on other sites More sharing options...
Red_Shift Posted January 1, 2018 Share Posted January 1, 2018 Can you recommend an image hosting site? I was part of the photobucket purge! Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4971869 Share on other sites More sharing options...
Subtle Discord Posted January 1, 2018 Share Posted January 1, 2018 I've found imgur to be a great image hosting site that is only an image hosting service by design, unlike Photobucket that want to sell other services. Xisor 1 Back to top Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4971899 Share on other sites More sharing options...
Xisor Posted January 2, 2018 Share Posted January 2, 2018 Seconded for Imgur - its easy to use and very simple in its offering, so also works in a nice polished way. All my sig-linked images are Imgur hosted. ---- Are Forgeworld still doing their massive "Icon Mechanicus" thing? Grafting that onto a Land Raider might get things closer to a Macrocarid? Alternatively, reversing the orientation of the Land Raider to have the tiny Icon Mechanicus on the engine housing facing "forwards" might work easily. Shifting the lights and things around might be difficult, but the big/pintel guns themselves are easy enough to do (only the now rear-facing heavy bolter/assault cannons would be an issue!). Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4972264 Share on other sites More sharing options...
DanPesci Posted January 2, 2018 Share Posted January 2, 2018 For some reason wont let me post images, but if you google 'macrocarid land raider' there are a couple photos of the models side by side. The macrocarid is slightly smaller than the LR, but definately bigger than a rhino/chimera/goliath etc. Land raider would be the best place to start for a conversion IMO. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4972269 Share on other sites More sharing options...
Shinespider Posted January 4, 2018 Share Posted January 4, 2018 The lore around Macroarids also explicitly says that they were originally tricked-out land raiders, and that the more purpose-built designs only came in later. A converted land raider isn't just convenient, it's canon. DanPesci 1 Back to top Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4974131 Share on other sites More sharing options...
Khulu Posted January 7, 2018 Share Posted January 7, 2018 I'm definitely keen to see how this turns out! Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4976818 Share on other sites More sharing options...
Magos_Adephus Posted January 8, 2018 Author Share Posted January 8, 2018 Thanks for the replies everyone. Had a quick think today at work, if one were to use a Baneblade chassis, would it really be too big? From the pics I've seen the Baneblade is roughly an inch longer than a Land Raider and about 1/2 an inch wider. Without the main turret they look about the same height as well. Keeping in mind, the Macrocarid model is almost the exact same size as a LR. Maybe I just want a Baneblade/Banehammer, but I just love the idea of the open deck in the rear. A thought I had was adding a shielded rollcage over the deck, similar to the Knight Lancer's shield. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4977284 Share on other sites More sharing options...
Red_Shift Posted January 8, 2018 Share Posted January 8, 2018 (edited) Https://imgur.com/gallery/qkDoQ Sorry for the delay. I'm also it sure how to embed images. I can probably do a baneblade pic, be quicker now I have an imgur account! One of the baneblade variants has an open rear.deck but they are big tanks! I've always wanted to convert one to have the massive imperial eagle cannon from the scenery piece on it. Edited January 8, 2018 by Red_Shift Magos_Adephus 1 Back to top Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4977855 Share on other sites More sharing options...
Magos_Adephus Posted January 11, 2018 Author Share Posted January 11, 2018 Thx Red. Also, fan-friggin-tastic conversion with the Mega Bolter. I think I've settled on what I'll doing. Gonna make a Land Raider Ares, minus the Heavy Flamers, just gonna keep the Lascannons. Convert the Demolisher cannon to a Graviton Imploder (somehow), and either patch up Heavy Bolter mount or put a targeting array/servitor in there for the Imploder. The extra bits from the Vindicator set I'll just use to trick it out, probably use on a future conversion. So yep, its a plan! With recent revelations about when FoC will come out I'm gonna wait till it drops to start the project, or if some stuff gets leaked, whichever comes first. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4980442 Share on other sites More sharing options...
Red_Shift Posted January 12, 2018 Share Posted January 12, 2018 If you're stuck for a suitable hull cannon I can dig through my bitz box. I'm fairly sure there are shadowsword spare parts in there. Link to comment https://bolterandchainsword.com/topic/342805-converting-a-macrocarid/#findComment-4981468 Share on other sites More sharing options...
