Marshlands Posted December 29, 2017 Share Posted December 29, 2017 (edited) So I was wondering peoples views on the tactical merit of the Dreadclaw and Kharybdis now that Chapter Approved has dropped. Prior to CA they were 200 and 300 points respectively and the Kharybdis seemed worth the extra 100 for double capacity alone and a decent (and fun) choice of delivery system. Now I'm thinking that at 130 points a Dreadclaw is affordable enough to be used in a similar way to a loyalist drop pod but with the added benefit of moving and venting exhaust in later turns. What are other people's views? Do you have a preference and what do you put in them? With the CA points adjustments if you had 20 guys to drop would you use a kharybdis or two dreadclaws? Edited December 29, 2017 by Marshlands Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/ Share on other sites More sharing options...
Azekai Posted December 29, 2017 Share Posted December 29, 2017 I like the idea of dreadclaws, but since I often limit myself to smaller skirmishes I haven't been able to justify taking them in 8th (I have two I converted from old Doctor Who Genesis ark toys I scavenged). The idea of zooming around to absorb overwatch, tie up enemy shooting squads or block LoS is pretty appealing. Part of the problem with loyalist drop pods is you play a lot just to have the thing sit there and do almost nothing after the squad inside is deployed. The dreadclaw, on the other hand, can get really annoying if your opponent doesn't deal with it. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4970340 Share on other sites More sharing options...
hushrong Posted December 29, 2017 Share Posted December 29, 2017 I want a dreadclaw because I like the model and I think it would be a great way of chucking some Berzerkers at my enemies. With the points drop its a bit more tantalizing. I like the idea of dreadclaws, but since I often limit myself to smaller skirmishes I haven't been able to justify taking them in 8th (I have two I converted from old Doctor Who Genesis ark toys I scavenged). The idea of zooming around to absorb overwatch, tie up enemy shooting squads or block LoS is pretty appealing. Part of the problem with loyalist drop pods is you play a lot just to have the thing sit there and do almost nothing after the squad inside is deployed. The dreadclaw, on the other hand, can get really annoying if your opponent doesn't deal with it. None of these ideas ever occurred to me and I really like them. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4970383 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted December 29, 2017 Share Posted December 29, 2017 Having used a Dreadclaw with my World Eaters very recently, I'd say it's definitely worth it to have at least one....perhaps two if you're going all-in on assault and/or point-blank shooting. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4970394 Share on other sites More sharing options...
Commissar K. Posted December 30, 2017 Share Posted December 30, 2017 (edited) Close to twice the cost of a Rhino but a great choice nontheless. In reality if you dont play Daemons soon Id thake it. Mono WE actually needs it in my opinion. Its worth the 130, just be sure to cram it. I like to use 10 Zerkers with it and that worked. Edited December 30, 2017 by Commissar K. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4970728 Share on other sites More sharing options...
Zodd1888 Posted December 30, 2017 Share Posted December 30, 2017 Close to twice the cost of a Rhino but a great choice nontheless. In reality if you dont play Daemons soon Id thake it. Mono WE actually needs it in my opinion. Its worth the 130, just be sure to cram it. I like to use 10 Zerkers with it and that worked. If you're DG or TS you'd likely see two Rhinos anyway. Having one unit slogg around and the other in pod land around a nearby enemy objective. You've got two hard to move units disrupting the field. Seems decent. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4970751 Share on other sites More sharing options...
TURBULENCE Posted December 31, 2017 Share Posted December 31, 2017 As a death guard player it's becoming more and more of an attractive choice. Seems like a great way to get plague marines right into their most effective range/ makes melee setups/blight bombardment easier to use Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971488 Share on other sites More sharing options...
Khornestar Posted January 1, 2018 Share Posted January 1, 2018 (edited) What do you all think about 2 units of 5 Berzerkers per Dreadclaw? Both with icons of wrath, obviously; increases the likelihood that at least one unit will get a charge off. Less effective at killing than 10, but if the unit fails its charge, then they’ll probably get shot to death (or close enough to it to wipe the unit due to morale). The second unit that fails (unless they both succeed in charging) can move into prime position the next turn for whatever they need to do. Edited January 1, 2018 by Juggernut Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971568 Share on other sites More sharing options...
Bloody Legionnaire Posted January 1, 2018 Share Posted January 1, 2018 Why not bump the units of 5 up 3 and run 2x8s in Dreadclaws? Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971588 Share on other sites More sharing options...
Khornestar Posted January 1, 2018 Share Posted January 1, 2018 Well, Dreadclaws only have a capacity of 10, so a unit of 8 would have the same problem as 10. If it fails the charge, that's that. No backup plan. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971590 Share on other sites More sharing options...
Commissar K. Posted January 1, 2018 Share Posted January 1, 2018 (edited) Well the back up plan is sometimes spending a Stratagem. Roll 6,1 for a charge, better re-roll 1 instead of the full result. If you roll 2 and 4 you might aswell re-roll it completely. Now this is for WE Berzerkers and while its possible to fail, everything can be failed. Part of the risk/reward. Alternatively fly to them, if its anti infantry heavy shooting :) The Claw does his AoE well against those armies. Edited January 1, 2018 by Commissar K. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971661 Share on other sites More sharing options...
Marshlands Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks for all the replies! I've just ordered a Dreadclaw over a Kharybdis, glad i saw the points changes first and seems like everyone is pretty much in favour of that one now. 10 zerkers was my main thought, but also toying with 9 plague marines and a putrifier with a jump pack sorcerer dropping in for the DG grenade strategem. Had thought about this previously with a kharybdis but it was way too expensive even with warp time it's difficult to get everything into grenade range. Post CA with 9 guys the claw and the Character it's now clocking in at 357 points - pretty good for a potential 9D6 shots with S4, +1 to wound, Damage 2 and a bonus Mortal Wound on a 5 or 6. Also my understanding is that chaos daemons can go in a Dreadclaw as it allows the Mark keyword to be transported... be interesting to see if the daemons codex gives any good options for that (maybe Bloodletters or Flamers if there's a way to move them again) 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971974 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted January 2, 2018 Share Posted January 2, 2018 What do you all think about 2 units of 5 Berzerkers per Dreadclaw? Both with icons of wrath, obviously; increases the likelihood that at least one unit will get a charge off. Less effective at killing than 10, but if the unit fails its charge, then they’ll probably get shot to death (or close enough to it to wipe the unit due to morale). The second unit that fails (unless they both succeed in charging) can move into prime position the next turn for whatever they need to do. Did exactly that. Both did nothing with their plasma pistols, both failed charge and then got deleted by Repulsor and Hellblasters. The Claw itself went on to do amazing. Couldn't use Commissar K's method because I had to use all my CP correcting so many bad die rolls elsewhere that I didn't have them to spare. At least they were a fire sink that let my walkers get in with only light damage and wreck face....and the Claw itself almost won me the game with CC kills and disruption. 2 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4971983 Share on other sites More sharing options...
The Traitor Posted January 2, 2018 Share Posted January 2, 2018 I'm thinking about getting one myself, with the price drop they seem very appealing. Also curious thing to note is that Cult of Destruction models don't seem to take more than one space in a dreadclaw, so you can hilariously take three units of mutilators/ obliterators and a character. Since mutilators also got a big price drop, it might be worth trying. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972017 Share on other sites More sharing options...
Bulwyf Posted January 2, 2018 Share Posted January 2, 2018 I'm actually thinking of getting one to drop Lucius and some possessed on top of someone in my EC list. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972317 Share on other sites More sharing options...
Marshlands Posted January 2, 2018 Author Share Posted January 2, 2018 I'm actually thinking of getting one to drop Lucius and some possessed on top of someone in my EC list. Also not a bad way to guarantee noise marines get to do their thing - although that's where the Kharybdis might be better to get a unit of 20 down to max the VoTLW and shoot twice stratagem 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972363 Share on other sites More sharing options...
Bulwyf Posted January 2, 2018 Share Posted January 2, 2018 Noise marines are criminally underrated. I like having them to support Lucious and his Possessed since I can't get a better melee option for EC to put around him. I pray for the day GW gives us EC players our own codex with 40k versions of Palatine Blades and Phoenix Guard termies. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972431 Share on other sites More sharing options...
Marshlands Posted January 2, 2018 Author Share Posted January 2, 2018 Noise marines are criminally underrated. I like having them to support Lucious and his Possessed since I can't get a better melee option for EC to put around him. I pray for the day GW gives us EC players our own codex with 40k versions of Palatine Blades and Phoenix Guard termies. Not by me! Aside from Deep Striking them I'm pretty content to just infiltrate them with Alpha Legion, they might get shot at if you're opponent goes first but with a 2+ in cover they're pretty survivable and if they do still die, worst case is I only get to shoot with them once. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972466 Share on other sites More sharing options...
Trevak Dal Posted January 2, 2018 Share Posted January 2, 2018 Are the points costs/data sheets in the chapter approved book? Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972710 Share on other sites More sharing options...
Commissar K. Posted January 2, 2018 Share Posted January 2, 2018 Are the points costs/data sheets in the chapter approved book? Point costs yes, data sheet not. But you can google it. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972712 Share on other sites More sharing options...
Flipl8 Posted January 3, 2018 Share Posted January 3, 2018 (edited) I'm actually thinking of getting one to drop Lucius and some possessed on top of someone in my EC list.Also not a bad way to guarantee noise marines get to do their thing - although that's where the Kharybdis might be better to get a unit of 20 down to max the VoTLW and shoot twice stratagemIf we're talking about Kharybdis, is it worth discussing the Storm Eagle as an alternative? Running it with a Vengeance Launcher, Hellstrike Missiles, and a twin Heavy Bolter, it clocks in at 295 points--80 points less than the Kharybdis. You could swap in twin Lascannons and still save, come to think of it. For that price, you get the same infantry transport capacity (no dreads, though) and much better mobility. Firepower and durability seem to even out, at least at a glance. I haven't done the mathhammer on it. I think the Eagle can reliably deliver its cargo to target on turn 2. Dropping 20 khorne berzerkers on the enemy flank would be pretty hilarious. Question in my mind becomes: how valuable, exactly, is drop pod assault? Edited January 3, 2018 by Maelstrom48 Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972939 Share on other sites More sharing options...
Marshlands Posted January 3, 2018 Author Share Posted January 3, 2018 It guarantees you get in if you're opponent has an alpha strike but like you say is a very expensive way of doing it. I think the Kharybdis also has some unique use through its exhaust attacks for some splash damage Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972975 Share on other sites More sharing options...
Trevak Dal Posted January 3, 2018 Share Posted January 3, 2018 Well you are dropping stuff 10" away from the badguys. In drop pods that can attack blob squads and put your opponent in a bad position to make bad choices. Link to comment https://bolterandchainsword.com/topic/342820-kharybdis-or-dreadclaw-or-neither-post-chapter-approved/#findComment-4972977 Share on other sites More sharing options...
