rendingon1+ Posted January 3, 2018 Share Posted January 3, 2018 Battle vs DG today. Problem: Do DG get their 4+ FnP vs phospex? Generally I would say yes (poison) but phospex is also S5 which means it wounds normal T4 on 3+ anyway. So: how to play this? Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/ Share on other sites More sharing options...
Charlo Posted January 3, 2018 Share Posted January 3, 2018 It has the poison rule, therefore it is a poison weapon - so you will get your 4+ FNP against it :) rendingon1+ 1 Back to top Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973106 Share on other sites More sharing options...
Runefyre Posted January 3, 2018 Share Posted January 3, 2018 DG definitely get their FnP against phosphex. The only way to ignore it is if the weapon that has poisoned/fleshbane also has Instant Death. rendingon1+ 1 Back to top Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973107 Share on other sites More sharing options...
rendingon1+ Posted January 3, 2018 Author Share Posted January 3, 2018 Thanks for responses. I'm not trying to push it but... can someone say he's using S5 to wound and not poisoned? Just to make things clear. Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973129 Share on other sites More sharing options...
Charlo Posted January 3, 2018 Share Posted January 3, 2018 No, I don't believe so, unless the unit is immune to poison (such as targeting a vehicle), in which case they would use the natural S5. Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973142 Share on other sites More sharing options...
Raktra Posted January 3, 2018 Share Posted January 3, 2018 No, you can’t choose to ignore your weapon’s rules. rendingon1+ 1 Back to top Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973364 Share on other sites More sharing options...
rendingon1+ Posted January 3, 2018 Author Share Posted January 3, 2018 Thanks again. Battle went without problems (defeat), as predicted my opponent took his infamous phosphex achilles x2, suprisingly he didn't argue about FnP (was asking because I assumed he will lol). As a side note - phosphex achilles is a must in my lists form now on. It's insanely powerfull and super difficult to destroy, even more than spartan. Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4973599 Share on other sites More sharing options...
LtDan Posted January 6, 2018 Share Posted January 6, 2018 Fyi phosphex quad guns are str4 ap3, medusas are str 5 ap2 Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4976382 Share on other sites More sharing options...
Raktra Posted January 6, 2018 Share Posted January 6, 2018 Regult phosphex is also S5 AP2. Your point? Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4976400 Share on other sites More sharing options...
LtDan Posted January 8, 2018 Share Posted January 8, 2018 That the op said it was strength 5 but is refurring to quad guns. So wouldn't wound on a 3+. Its a 4+. As there str4! If wanted to use the str to wound Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4977480 Share on other sites More sharing options...
SkimaskMohawk Posted January 26, 2018 Share Posted January 26, 2018 You can't choose strength over poison or sniper though.... The problem with the achilles-alpha is that it has no flare shield and 4 hull points. Sure it's harder to explode by a lot, but being AV 15 is usually better than -1 Damage, especially since laser vindicators are so undercosted Link to comment https://bolterandchainsword.com/topic/342961-death-guard-poison-immunity/#findComment-4994577 Share on other sites More sharing options...
