depthcharge12 Posted January 9, 2018 Share Posted January 9, 2018 Pretty much what it says on the tin. I have a green DKoK army with brown and brass accents and was curious what, if any, tank camo or scheme I should use. I’ve seen some cool ones in grey or dunkelgelb (dark brownish yellow/German WWII tank camo) but idk if they would look kosher in my army. I could always paint them the same green but I’m not super keen on that. What should I do? Here’s a model for reference: Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/ Share on other sites More sharing options...
Feral_80 Posted January 9, 2018 Share Posted January 9, 2018 (edited) I don't think that green would look good on vehicles. I've recently painted a Mars-Alpha LR camo green, and that looks quite ok because it is reasonably realistic, but the green you're using is too bright. I've always seen and imagined Krieg vehicles in colours that are basically those of WW1-WW2 European armies, especially German and French. I'd definitely go with those because they exhalt the more realistic and tough look of their vehicles, vs the more toy-style stuff of the normal Guard. You can always pick up a connection with the infantry by painting a few bits with your green, eg crew, rolled cloth, flags, shields/coat of arms hanging around, etc. Edited January 9, 2018 by Feral_80 duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4978632 Share on other sites More sharing options...
librisrouge Posted January 9, 2018 Share Posted January 9, 2018 Camouflage is the color of cowardice. Paint it green anyway. Works for Dark Angels, and Leman Russ tanks aren't exactly known for their stealth qualities. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4978749 Share on other sites More sharing options...
iceman2160 Posted January 9, 2018 Share Posted January 9, 2018 You could always invert the color scheme of your guardsmen for your vehicles. Brown and brass with green accents. Silas7 1 Back to top Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4978754 Share on other sites More sharing options...
Doof Posted January 9, 2018 Share Posted January 9, 2018 The tanks do not have to match your men's fatigues. Look at Vostroyans for example, they are usually red-coated with loss of brass, but their tanks are a unique cool-tan color. I recommend you paint your tanks a drab color like others have mentioned, and then just maybe do some squad markings on the tanks in green, or perhaps use green lenses or something like that. Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4978762 Share on other sites More sharing options...
Imperator Deus Posted January 11, 2018 Share Posted January 11, 2018 (edited) I paint mine with a base of Dunkelgelb, I spray them with Battlefront's Late War German spray primer, or Army Painter's Desert yellow, depending on which is available. They're pretty much the same colour. Then I drybrush it with Vallejo's Yellow Ochre, then I paint on splotches using Deathworld Forest, then drybrush those with Ellysian Green. I then edge the green splotches with Steel Legion Drab. I modified a WWII German camo scheme from a reference book that I have, the real shades of green and brown were too dark for my purposes (roughly closer to Caliban Green and Dryad Bark in case you're interested), so I went with some lighter shades. It might go well with your troops if you use the darker shades of green and brown. I couldn't find the exact image online to link to, but this one's pretty close, it just substitutes black in place of brown. http://r.search.yahoo.com/_ylt=Az_6xdYW41ZahTcAu5T2FAx.;_ylu=X3oDMTBtdXBkbHJyBHNlYwNmcC1hdHRyaWIEc2xrA3J1cmw-/RV=2/RE=1515672470/RO=11/RU=http%3a%2f%2ftanktaco.blogspot.com%2f2013%2f03%2fgerman-wwii-afv-camouflage-colors.html/RK=2/RS=NrfTW7lZLHsy6jl1eRUShiKuk4A- Or if you wanted to stick to the WWI theme, you could use the German disruption pattern on the Stahlhelm: http://r.search.yahoo.com/_ylt=A0WTTciJ5VZar6oAVCD2FAx.;_ylu=X3oDMTBtdXBkbHJyBHNlYwNmcC1hdHRyaWIEc2xrA3J1cmw-/RV=2/RE=1515673097/RO=11/RU=https%3a%2f%2fwww.ar15.com%2fforums%2ft_3_118%2f711727_Anyone-else-think-this-would-be-a-cool-paint-job-.html/RK=2/RS=lxt5p1WZx8jE2TtQQHVW6bVH9Ms- Edited January 11, 2018 by Imperator Deus depthcharge12 1 Back to top Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4979901 Share on other sites More sharing options...
depthcharge12 Posted January 11, 2018 Author Share Posted January 11, 2018 Thanks! I wound up doing a German ambush style camo with a dunkelgelb base (Zandri Dust). I wanted to do that one that has the little individual dots within that camo, but it might’ve looked a bit OTT for Krieg. walter h, duz_, The Ergonomic Enginseer and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4979906 Share on other sites More sharing options...
Imperator Deus Posted January 11, 2018 Share Posted January 11, 2018 Looks great and it goes really well with the troops! Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4979909 Share on other sites More sharing options...
The Mad Hermit Posted January 11, 2018 Share Posted January 11, 2018 Looks great and it goes really well with the troops! I agree! Very nicely done. Link to comment https://bolterandchainsword.com/topic/343176-krieg-tank-camo/#findComment-4979912 Share on other sites More sharing options...
