Kilofix Posted January 9, 2018 Share Posted January 9, 2018 The DG FAQ reads: Q: Can Poxwalkers use the Curse of the Walking Pox ability to increase the unit above its starting strength? A: Yes. I read that as, if a unit is originally say 10 strong, it can exceed 10. But can it exceed its normal maximum unit size of 20? Thanks for the feedback. Link to comment https://bolterandchainsword.com/topic/343183-can-curse-of-the-walking-pox-increase-unit-size-over-20/ Share on other sites More sharing options...
Kallas Posted January 9, 2018 Share Posted January 9, 2018 I think if you expand your question a little it's yes. Assuming you have a unit that starts at the maximum unit size of 20 then apply the FAQ answer then, yes, you would be allowed to increase above 20. It seems reasonable, from that train of logic, that a unit of 10 could expand above the maximum unit size. Theoretically, a unit of Poxwalkers could increase infinitely (given enough time/triggers). Link to comment https://bolterandchainsword.com/topic/343183-can-curse-of-the-walking-pox-increase-unit-size-over-20/#findComment-4978685 Share on other sites More sharing options...
