Ahistorian Posted January 10, 2018 Share Posted January 10, 2018 I am building a small character force of Guardsmen based on the Espandor Veterans from Dark Imperium. I plan to make an ersatz Sgt Harker, and then a squad of 9 with an LT and 2 command squads to mimic a more modern force organisation. Any thoughts on the loadout? I primarily intend to use Neophyte Hybrid and Scout arms. Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/ Share on other sites More sharing options...
librisrouge Posted January 11, 2018 Share Posted January 11, 2018 Depends on what you want them to do. I assume shooting, so I’d say lascannons on the squads. Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4979818 Share on other sites More sharing options...
Hatarus Posted January 11, 2018 Share Posted January 11, 2018 what kind of battles do you expect to be getting into it will really depend on that Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980053 Share on other sites More sharing options...
Halfpint100 Posted January 11, 2018 Share Posted January 11, 2018 To make that legal you will need an officer per command squad, so you will need 2 officers (harker doesn't count). the list might look like: HQ Company commander boltgun (maybe power weapon) Company commander boltgun (maybe power weapon) Elites Command squad + lascannon Command squad + lascannon +banner (optional, but with officer within 6" and banner, your guard are LD10. Only 5 points, optional) Harker Vet squad + 3 grenade launchers (cheap option) or + 3 plasma guns + heavy weapon (heavy bolter is cheap, lascannon is good) Since you want harker, i assume catachan as the regiment. Hope this helps Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980071 Share on other sites More sharing options...
librisrouge Posted January 11, 2018 Share Posted January 11, 2018 If you’re going Catachan, I can’t recommend power fists enough. Giving the officer S8 and -3ap catches so many people by surprise and is great to take those last two wounds off the daemon prince that thought it could charge your lines. duz_ and Halfpint100 2 Back to top Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980451 Share on other sites More sharing options...
duz_ Posted January 11, 2018 Share Posted January 11, 2018 Wouldn't it just be S7? Multipliers before additions? I do like my S6 Lord Commissar PFist though :) Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980466 Share on other sites More sharing options...
Mileposter Posted January 11, 2018 Share Posted January 11, 2018 Pretty sure it'd be S8, as it's the characteristic being buffed not the attack. Characteristic has to be figured before the attack can be calculated (believe that was described in the Directors Commentary?) - if it was +1 to attack strength, you'd be spot on. Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980470 Share on other sites More sharing options...
librisrouge Posted January 11, 2018 Share Posted January 11, 2018 Pretty sure it'd be S8, as it's the characteristic being buffed not the attack. Characteristic has to be figured before the attack can be calculated (believe that was described in the Directors Commentary?) - if it was +1 to attack strength, you'd be spot on. Basically this. There is an FAQ (I don't know which one) that spells out the process. Basically, you modify the statistic and then you modify the strength of the attack itself. This means that the strength becomes 4 before the powerfist kicks in. duz_ and Tirak 2 Back to top Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980490 Share on other sites More sharing options...
Ahistorian Posted January 11, 2018 Author Share Posted January 11, 2018 Thanks for all the answers guys. A powerfist sounds like a good idea. I plan to go more SOF with them though, so Heavy Weapon teams are off the cards until I acquire some Kataphrons to mod as weapons platforms. They will either be stand alones for Shadow War Armageddon type games, or supporting Primaris marines. Are medics worth it this edition? duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4980728 Share on other sites More sharing options...
librisrouge Posted January 12, 2018 Share Posted January 12, 2018 Nope. If they ever are, they just be shot up. Link to comment https://bolterandchainsword.com/topic/343224-tiny-force-composition-question/#findComment-4981295 Share on other sites More sharing options...
