Captain Idaho Posted January 10, 2018 Share Posted January 10, 2018 Hi all. Has anyone got any inspiration or ideas on how to implement a conversion or alternative to the Inceptor unit? I fancy using a unit with Assault Bolters as for 135pts that ain't too shabby. Reminds me of a time when dual Heavy Bolter Land Speeders was worth while. (Actually they probably still are but that's a digression) I want to base the models on classic Space Marines so the scale fits. A friend suggested I use standard Jump Packs with a Storm Bolter grafted onto the arms but I think that'll look clumsy and might not suit the T5. Some sort of flying Attack Bike that isn't too large? The Space Marines Jetbikes from the HH are huge for just 2 wounds and T5. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/ Share on other sites More sharing options...
Kinstryfe Posted January 11, 2018 Share Posted January 11, 2018 Wish I still had a tutorial bookmarked, but you can make sm bikes into fairly small jetbike/speeders with just a few adjustments. Those with the appropriate weapons may be able to pull it off. Or using the giant inceptor jump packs on old marine models, would make it pretty obvious what they're supposed to be. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4979813 Share on other sites More sharing options...
chamberlainskeksil Posted January 11, 2018 Share Posted January 11, 2018 I found this tutorial: https://www.dakkadakka.com/wiki/en/Modeling_the_insaniak_way_-_Simple_Space_Marine_Jetbike I'm thinking I may go the jet bike route as well. Though i think I'd replace the underslung bolters with larger weapons. Maybe make a green stuff press mould out of the front of a heavy bolter or something. Spinsanity 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4979854 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 (edited) Nice replies. That tutorial is pretty in depth! What do people think about (deep breath) Tartarus Terminators with jump packs? A friend suggested the old school Raptor jump packs? Edited January 11, 2018 by Captain Idaho Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980017 Share on other sites More sharing options...
Major_Gilbear Posted January 11, 2018 Share Posted January 11, 2018 Whilst bulky, have you considered simply adding the assault bolters and Inceptor jump packs to regular assault marines? I know they'd be somewhat big, but the added bulk will help convey the T5, and the weapons will be unequivocal. Perhaps using the Dark Imperium ones (which are a little less detailed) will let you trim them down a little to help suit the assault troops better, as well as being cheaper to acquire. Failing that, you could also consider using bolt pistols. Modifying these with added gun shields and ammo feeds leading to waist-mounted hoppers (sort of like the Devastator HBs, or the 30k Moritats) would be reasonably straightforward and very convincing. Again though, I'd still consider using the Inceptor jump packs. As you have quite a bit of choice with the classic marine figures, you could also give your not-Inceptors all mk8 chest pieces too, as the raised collar will suit them well. :) Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980038 Share on other sites More sharing options...
Kinstryfe Posted January 11, 2018 Share Posted January 11, 2018 That's basically the tutorial I followed for jetbikes. Awesome. I'm not a fan of the idea of tartarsauce termies with jump packs. Maybe if you use different arms and shoulder pads, and it's just the Tartaros body, but I'm having a hard time imagining them looking quite right. I imagine they'd look more or less like termies with jump packs strapped to them. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980204 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 A serious worry. The bodies look like they'd work mind. I dunno. I'd have to get hold of the sprues. Whilst bulky, have you considered simply adding the assault bolters and Inceptor jump packs to regular assault marines? I know they'd be somewhat big, but the added bulk will help convey the T5, and the weapons will be unequivocal. Perhaps using the Dark Imperium ones (which are a little less detailed) will let you trim them down a little to help suit the assault troops better, as well as being cheaper to acquire. Failing that, you could also consider using bolt pistols. Modifying these with added gun shields and ammo feeds leading to waist-mounted hoppers (sort of like the Devastator HBs, or the 30k Moritats) would be reasonably straightforward and very convincing. Again though, I'd still consider using the Inceptor jump packs. As you have quite a bit of choice with the classic marine figures, you could also give your not-Inceptors all mk8 chest pieces too, as the raised collar will suit them well. :) Interesting idea actually. By doing that, then using Green stuff to bulk out the Armour by thickening sections, I might be able to make it work. It's mostly the height that is the problem, ya see. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980221 Share on other sites More sharing options...
Major_Gilbear Posted January 11, 2018 Share Posted January 11, 2018 Hmm, what about using the actual Inceptors as a start, and then kitbashing the torso, head, and arms to fit? Seems like less work in the bigger scheme of things. With respect to just addressing the height, what about using a flying stand? If they are in the air, it's *much* harder to judge the relative model size. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980229 Share on other sites More sharing options...
Grotsmasha Posted January 11, 2018 Share Posted January 11, 2018 Nice replies. That tutorial is pretty in depth! What do people think about (deep breath) Tartarus Terminators with jump packs? A friend suggested the old school Raptor jump packs? I can do a mock up shortly, I think it has potential. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980320 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 The options that stand out to me are: - Tartarus with jump pack from Raptor/Older marks/Inceptors. - Assault Marines with Inceptors packs and bulked out with Green Stuff. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980426 Share on other sites More sharing options...
Paradogmatic Posted January 11, 2018 Share Posted January 11, 2018 (edited) Nice replies. That tutorial is pretty in depth! What do people think about (deep breath) Tartarus Terminators with jump packs? A friend suggested the old school Raptor jump packs? I like these jumppacks -- I snagged a few a while ago for when I do regular Assault Marines to go with my Inceptors -- I find they have a similar look with the big engine. From : https://www.forgeworld.co.uk/en-DK/Legion-MKIV-Destroyer-Squad-with-Jump-Packs Edited January 11, 2018 by Paradogmatic Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980615 Share on other sites More sharing options...
chamberlainskeksil Posted January 11, 2018 Share Posted January 11, 2018 (edited) Nice replies. That tutorial is pretty in depth! What do people think about (deep breath) Tartarus Terminators with jump packs? A friend suggested the old school Raptor jump packs? I recently built a custom terminator character and in the end something was wrong with it. The lower legs were simply too small. There's something about terminators where the lower area needs to be as big and wide as the shoulders. I think a jump pack would add to this. I also think it's the reason they put those hover sandals on the inceptors in the first place. Gravis, like terminator armour, would just look strange with any sort of small size or void of unoccupied base space. So I think you may need to add something to the tartaros to make them work. I think it's going to be a challenge to add something to the lower legs given the sleek and straight lines of the tartaros lower shin guard. Edited January 11, 2018 by chamberlainskeksil Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980620 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 Hmm. Those MK4 Jump Packs could work with a Tartaros? I'll have to have an experiment with how to make it work. What sort of suggestions to the Tartaros legs do people have? I'm thinking green stuff to bulk then out? Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980629 Share on other sites More sharing options...
Jolemai Posted January 11, 2018 Share Posted January 11, 2018 Instead of one MK IV jump pack, why not two joined together? Cut off a left vent from one and a right vent from another and join them alongside the main turbines? Sang Guard boxes are probably the best source for them. For the legs, maybe make them look skin to Devastator legs? Or perhaps give them Dreadnought style feet? Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980637 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 I had no idea Sanguinius Guard had such Jump Packs. Good who sir. That's cheaper than FW. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980650 Share on other sites More sharing options...
Captain Idaho Posted January 11, 2018 Author Share Posted January 11, 2018 What do folk reckon for guns? I might just use the assault bolters? Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980691 Share on other sites More sharing options...
Grotsmasha Posted January 12, 2018 Share Posted January 12, 2018 What do folk reckon for guns? I might just use the assault bolters? Sorry ran l.ate @ work lask night and couldn't do the mock up, but I'll get to it this afternoon. As for the guns, I'd recommend IG HW Team Heavy Bolters. I think I've got one about, I'll incljde it in the mock p if I can. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980819 Share on other sites More sharing options...
Kinstryfe Posted January 12, 2018 Share Posted January 12, 2018 I had no idea Sanguinius Guard had such Jump Packs. Good who sir. That's cheaper thoan FW. Cheaper than FW and, by the time you've bought enough boxes for 30 or so packs for different projects, you end up with the makings of some really cool looking Blood Angels to ally with your other forces. Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4980823 Share on other sites More sharing options...
Grotsmasha Posted January 13, 2018 Share Posted January 13, 2018 With some minor trimming of an inceptor rear torso, and a Cataphractii or Tartaros torso front, they pair and align quite nicely. The Inceptor rear torso has a flat piece that any of the current jump packs will attach to easily. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/343229-alternative-inceptor-modelsconversion-advice-please/#findComment-4981746 Share on other sites More sharing options...
