Khalan Posted January 11, 2018 Share Posted January 11, 2018 Is there anything out there whether we can use the CSM version of this vs the Daemon version? Assuming we are running a CSM slannesh caster in a CSM detachment. Otherwise it would force CSM to buy the daemon book/cards for 1 spell. Link to comment Share on other sites More sharing options...
Panzer Posted January 11, 2018 Share Posted January 11, 2018 Not sure what you are talking about, there are no Delightful Argonies in the Daemon book. Even if there were it wouldn't matter as long as it's not in the same psychic discipline and if daemons actually have the exacz same powet in the exact same psychic discipline just with slightly different rules then you can expect an errata for csm anyway. So in short: no you don't need to buy the daemon book for your csm. Link to comment Share on other sites More sharing options...
Kraken Posted January 11, 2018 Share Posted January 11, 2018 (edited) Not sure what you are talking about, there are no Delightful Argonies in the Daemon book. Even if there were it wouldn't matter as long as it's not in the same psychic discipline and if daemons actually have the exacz same powet in the exact same psychic discipline just with slightly different rules then you can expect an errata for csm anyway. So in short: no you don't need to buy the daemon book for your csm. Delightful Agonies is a power in the Slaanesh dicipline of the Daemon codex. Edited January 11, 2018 by krakjen Link to comment Share on other sites More sharing options...
Khalan Posted January 11, 2018 Author Share Posted January 11, 2018 Not sure what you are talking about, there are no Delightful Argonies in the Daemon book. Even if there were it wouldn't matter as long as it's not in the same psychic discipline and if daemons actually have the exacz same powet in the exact same psychic discipline just with slightly different rules then you can expect an errata for csm anyway. So in short: no you don't need to buy the daemon book for your csm. Yeah not sure what you are talking about. There 100% is a delightful agonies in the new Daemon book. Link to comment Share on other sites More sharing options...
Panzer Posted January 11, 2018 Share Posted January 11, 2018 Must be one of the new powers in the Codex then. I obviously don't have it yet or I would've known that. Anyway, my answer remains the same. As long as it isn't part of the psychic discipline the CSM Sorcerer/CSM Daemon Prince has access to it doesn't matter for them. Then they are simply two different powers with the same name and they have only access to one of those. Link to comment Share on other sites More sharing options...
Lord Abaia Posted January 11, 2018 Share Posted January 11, 2018 I believe that Delightful Agonies in the CSM book will just remain a different power than Delightful Agonies in the Daemons book because both of them will have different keyword requirements for target units, Slaanesh Heretic Astartes vs Slaanesh Daemon. I would just keep using the Delightful Agonies with the 5++ while playing CSM until GW officially says otherwise. Link to comment Share on other sites More sharing options...
