Akrim Posted May 30, 2018 Share Posted May 30, 2018 You can absolutely use your Scions in your Cadian army, they just dont get the Tempestus keyword. Link to comment Share on other sites More sharing options...
Frater Cornelius Posted May 30, 2018 Author Share Posted May 30, 2018 You can absolutely use your Scions in your Cadian army, they just dont get the Tempestus keyword. You’re missing the point, dude ;) There were Kasrkins long before there were Scions. I will obviously use the Scion rules, seeing as there are no Kasrkin rules anymore, but what kind of Cadian force would that be, if it wasn’t using what is probably the most iconic Cadian models ever made? Or at least a conversion to mimic those :P This is about the fluff and ideal ;) Link to comment Share on other sites More sharing options...
Canadian_F_H Posted October 20, 2018 Share Posted October 20, 2018 What did you use for legs and arms? Link to comment Share on other sites More sharing options...
Frater Cornelius Posted October 20, 2018 Author Share Posted October 20, 2018 What did you use for legs and arms? Scions. What I did was I cut away the thigh armour plates, cut away part of the waist (had to, because I was using already assembled Scions), then glued it all together with GS and reattached the thigh plates. It still needs some work with GS and maybe plasticard, however, I play very rarely these days and use Scions even more rarely, so I put them on the back burner for a while. Please note that the scion torso is a tad bigger than the hazard ones, so army mat not well without some GS. Link to comment Share on other sites More sharing options...
