malchos Posted January 16, 2018 Share Posted January 16, 2018 Hi, I would like plead for some help, ideas or advice, or simply an inspiration regarding following issue. Unfortunately I couldn't find Google very helpful. I'm building Mechanized 113th Cadian Mechanized list, so I purchased loads of Chimeras. Some are new, but most of them are second hand, and already pre-built. These pre-built already have Multi-lasers equipped, however my list in order to be WYSIWYG, has to be with HB. So basically I can: - Cut of ML, but big question is should I go for cutting from barrel or entire plate together with barrel - "Normal" turret HB comes with sort of a aiming device that is almost identical to the one Hunter Killer on Rhinos have, so any ideas if there are other bits out there - Leave everything and plead TO to relax WYSIWYG rule on HB :) - If anyone happend to have similar issue and how did he solve it Thank you very much Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/ Share on other sites More sharing options...
Major_Gilbear Posted January 16, 2018 Share Posted January 16, 2018 If you're playing with friends, and as long as it's clear what's what (so all Chimera multilasers = HBs for example, with no mixing), then I would just leave the multilasers. If you're playing in a tournament, you're best off asking the TO rather than us. However, assuming that you will need to change them to HBs, then I would suggest: - Cut the multilaser as the "plate" (the plate is actually called a "mantle"), and keep the multilaser. - Then cut a suitable HB down to fit onto the mantle. - Put a magnet in the HB, the multilaser, and the mantle. - Don't worry about the targeting lens. Now you can swap to whatever weapon you like in future (and even do the same with heavy flamers if you like). :) malchos, Halfpint100, Frater Cornelius and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/#findComment-4984445 Share on other sites More sharing options...
duz_ Posted January 16, 2018 Share Posted January 16, 2018 Gilbear has it right! Definitely ask the TO and chances are it'll be a no for ML counts as HB. Those suckers can be tough to cut off. Id suggest a saw vs trying to use a hobby knife. malchos 1 Back to top Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/#findComment-4984460 Share on other sites More sharing options...
Spyboy Posted January 16, 2018 Share Posted January 16, 2018 I know not quite what you are asking for, but have you considered the chimeras with two heavy bolters in the turret? Just a thought before you build them all. malchos 1 Back to top Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/#findComment-4984871 Share on other sites More sharing options...
malchos Posted January 17, 2018 Author Share Posted January 17, 2018 (edited) I know not quite what you are asking for, but have you considered the chimeras with two heavy bolters in the turret? Just a thought before you build them all. Yes, they are FW although I couldn't find them in FW offer anymore Well basically my question comes down to: have you bought assembled ML Chimera on ebay, but you decided to change it to HB Chimera, and how did it go :) Edited January 17, 2018 by malchos Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/#findComment-4985322 Share on other sites More sharing options...
malchos Posted January 17, 2018 Author Share Posted January 17, 2018 Gilbear has it right! Definitely ask the TO and chances are it'll be a no for ML counts as HB. Those suckers can be tough to cut off. Id suggest a saw vs trying to use a hobby knife. If you're playing with friends, and as long as it's clear what's what (so all Chimera multilasers = HBs for example, with no mixing), then I would just leave the multilasers. If you're playing in a tournament, you're best off asking the TO rather than us. However, assuming that you will need to change them to HBs, then I would suggest: - Cut the multilaser as the "plate" (the plate is actually called a "mantle"), and keep the multilaser. - Then cut a suitable HB down to fit onto the mantle. - Put a magnet in the HB, the multilaser, and the mantle. - Don't worry about the targeting lens. Now you can swap to whatever weapon you like in future (and even do the same with heavy flamers if you like). Thank you very much, this is exactly insight I need Link to comment https://bolterandchainsword.com/topic/343413-advice-ideas-and-wisdom-needed-regarding-hb-chimeras/#findComment-4985324 Share on other sites More sharing options...
