Anamnesis Posted January 17, 2018 Share Posted January 17, 2018 (edited) I did a small tut on doing some concrete base on my Plog, i thought you might find it useful so here it is! 1. Choose some cork to add some height to your base and use it as a base for the concrete 2. Cut some plasticard and glue it to your cork 3. Trim with a cutter the side of the plasticard to mostly match the cork underneath, make some marks and tears with a cutter or other pointy thing (mind your fingers please) 4. This step is optionnal but finding a few bits and pieces to matches the idea behind your basework is nice and break the monotony of a plain base. 5. Drown everything in black lava putty from vallejo or any other pumice like stuff, and push your bits and pieces in it. I also added a piece of razor wires because i like it Cheers Anamnesis Edited January 18, 2018 by Anamnesis Ezr91aeL and Tokugawa 2 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/ Share on other sites More sharing options...
Major_Gilbear Posted January 17, 2018 Share Posted January 17, 2018 A well presented tutorial! :) If the cork is completely covered, can't the plasticard be glued directly to the base instead? With the texture paste around it afterwards, I'm not seeing what the cork is contributing besides adding some height (and you could just use a few plasticard scraps or a bit of cheap putty for that). Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4985626 Share on other sites More sharing options...
Brother-Chaplain Kage Posted January 18, 2018 Share Posted January 18, 2018 You really should change the color of your text to something more visible. Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4986152 Share on other sites More sharing options...
Anamnesis Posted January 18, 2018 Author Share Posted January 18, 2018 A well presented tutorial! If the cork is completely covered, can't the plasticard be glued directly to the base instead? With the texture paste around it afterwards, I'm not seeing what the cork is contributing besides adding some height (and you could just use a few plasticard scraps or a bit of cheap putty for that). Thanks, the cork is mostly there for stability, since the plasticard is quite thin, i've found that it doesn't stay flat if it don't have a support underneath. Thought if you don't want the added weight, it's perfectly fine to glue it directly to the base ! You really should change the color of your text to something more visible. I'll investigate that, i'ts plain black on white font on my screen Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4986210 Share on other sites More sharing options...
Brother-Chaplain Kage Posted January 18, 2018 Share Posted January 18, 2018 I've got the default skin on PC with the near-black background and your letters are just barely lighter than the background. At first I didn't even see the writing. Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4986215 Share on other sites More sharing options...
Anamnesis Posted January 18, 2018 Author Share Posted January 18, 2018 I've got the default skin on PC with the near-black background and your letters are just barely lighter than the background. At first I didn't even see the writing. Should be alright now, though it seems to be a problem with the ip board skin. Never had that before... Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4986241 Share on other sites More sharing options...
Major_Gilbear Posted January 18, 2018 Share Posted January 18, 2018 Odd, the text was black yesterday, and today it's barely darker than the board's background (I use the default IPB blue/white skin). On the subject of the cork, that makes sense. I suppose if you just used some thick plasticard, you could stick it straight onto the base with plastic glue, and it saves you the whole cork step. Have you tried/considered leaving some of the cork visible? It's got a nice texture, and it seems a shame to cover it all up if you're doing something ruined. Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4986483 Share on other sites More sharing options...
Anamnesis Posted January 19, 2018 Author Share Posted January 19, 2018 Odd, the text was black yesterday, and today it's barely darker than the board's background (I use the default IPB blue/white skin). On the subject of the cork, that makes sense. I suppose if you just used some thick plasticard, you could stick it straight onto the base with plastic glue, and it saves you the whole cork step. Have you tried/considered leaving some of the cork visible? It's got a nice texture, and it seems a shame to cover it all up if you're doing something ruined. Actually, that's interesting. i didn't thought about that! Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4987461 Share on other sites More sharing options...
Anamnesis Posted February 1, 2018 Author Share Posted February 1, 2018 (edited) 1. Following the last photo dump on the making of i just undercoat the base black 2. I sponge on the concrete vallejo dark sea blue randomly, then scalecolor bering blue using the samesponge 3.Mix some white with your bering blue and continue sponging until you're satisfied with the effect Keep in mind we'll wash it after so it need to be quite light 4. Paint the sand with rhinox hide 5. Drybrush scalecolor gobi brown, then vallejo yvory on the sand 6. Wash the whole base with army painter strong tone, make some pool on the concrete to mix it up 7. To decorate the base, i use some tamiya tape to mark the place i want for my yellow chevron I use a sponge and masking fluid to make some marks so i can rub it off after painting 9.Using your sponge lightly dab the place you've masked with scalecolor sahara yellow 10. Pull of the masking tape and enjoy the result. Use blue tac to rub of the masking fluid Paint your little piece drowned in the sand with vallejo armour brown Paint the rim black 11. Dab some kalahari orange then a brighter orange to make the rust on the pieces Finish by lightly dabbing some metal paint to finish the effect Clean any detail you need now 13. Time to add some effect with different kinds of pigments on the base, i'm using burnt umber, burnt sienna, green earth and some light rust Done ! Edited February 1, 2018 by Anamnesis DuskRaider, infyrana, Stoic Raptor and 11 others 14 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4999889 Share on other sites More sharing options...
infyrana Posted February 1, 2018 Share Posted February 1, 2018 Awesome tutorial - thank you! Anamnesis 1 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-4999952 Share on other sites More sharing options...
Brother Desultor Posted February 2, 2018 Share Posted February 2, 2018 Excellent tutorial, thank you for taking the time to create it. Anamnesis 1 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-5000419 Share on other sites More sharing options...
Anamnesis Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks guys :) Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-5000638 Share on other sites More sharing options...
Major_Gilbear Posted February 2, 2018 Share Posted February 2, 2018 Gorgeous work, thank you for sharing! :) Anamnesis 1 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-5000747 Share on other sites More sharing options...
DeadMilkman Posted February 23, 2018 Share Posted February 23, 2018 I love the way you did the stripes on the concrete, that looks awesome! Thanks for sharing! Good gaming! Wes Anamnesis 1 Back to top Link to comment https://bolterandchainsword.com/topic/343459-how-to-doing-concreteroad-like-base/#findComment-5017371 Share on other sites More sharing options...
