Jamafore Posted January 21, 2018 Share Posted January 21, 2018 I just got some plasma cannons from Forge World that have the cabling the you heat and bend. Do you bend them before you prime them or can you prime first? My brainfruits logic engine says if I prime first, then bend, the primer coat will crack, but I wanted to make sure. Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/ Share on other sites More sharing options...
Grotsmasha Posted January 21, 2018 Share Posted January 21, 2018 Bend before priming :tu: Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4988842 Share on other sites More sharing options...
Jamafore Posted January 21, 2018 Author Share Posted January 21, 2018 Thank you Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4988869 Share on other sites More sharing options...
Jolemai Posted January 21, 2018 Share Posted January 21, 2018 A small highjack, but would it be best to use a bowl of warm water for this sort of thing? I guess it's too small for the hair dryer treatment? When it's "floppy" do you just hold it in place on the model and wait for it to cool to make the shape? Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4989000 Share on other sites More sharing options...
Major_Gilbear Posted January 21, 2018 Share Posted January 21, 2018 A small highjack, but would it be best to use a bowl of warm water for this sort of thing? I guess it's too small for the hair dryer treatment? When it's "floppy" do you just hold it in place on the model and wait for it to cool to make the shape? Yes, I prefer the bowl of hot water trick myself. The issue I have with the hair dryer is that it's quite hard to control how much heat goes into the resin part(s), and you can end up damaging/warping it/them if you're not careful. I also prefer to hold parts in place until they cool a bit (gently blow air across them, as the evaporation will help cool them faster), and then dunk in some cold water at the end if it's bigger/thicker part. Pro-tip: for the hot water, use a bigger bowl, put it on a heat-proof pad, and wrap an old towel around it. This stops heat-marks on the table, soaks up any splashes, and keeps the water hot for longer. ;) Helycon and Jolemai 2 Back to top Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4989065 Share on other sites More sharing options...
Carlson793 Posted January 21, 2018 Share Posted January 21, 2018 I usually just set a bowl of cold water with ice by the kitchen sink, then run the tap at full hot. FW resin is pliable/soft enough that hot straight from the tap is enough for bending. Run it under the tap, carefully bend it to shape, then submerge in the ice water. Repeat 2-3 times to make sure the shape is right and help it keep the shape better. Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4989375 Share on other sites More sharing options...
binary Posted January 22, 2018 Share Posted January 22, 2018 For the forgeworld cables I attach one end to the gun, and then use hot water in a shot glass to make the cable flexible. I then put a spot of superglue in the back pack and carefully bend the cable into position. I then let the cable cool in position. Jamafore and Kierdale 2 Back to top Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4990399 Share on other sites More sharing options...
Jamafore Posted January 23, 2018 Author Share Posted January 23, 2018 I'm figuring to do roughly the same, since I'm magnetizing it anyway, only gluing it to the backpack and working from that. Also, very nice leds Link to comment https://bolterandchainsword.com/topic/343571-forge-world-plasma-cannon-cables/#findComment-4990728 Share on other sites More sharing options...
