Impact1 Posted January 22, 2018 Share Posted January 22, 2018 (edited) I thoulght I'd start collectiong som e photos of a few buildings I've done These will wander a bit From mechanicus to Habs to alien stuff. First up, cargo shipping containers. Scratch built ~1:48 scale 20 Foot Shipping container for war-gaming. Enclosed container, 1 of 4 built. Dimensions are 54mm W x 57mm T x 133mm L. I built 4 of these in one go. Using florescent light grating for the sides, and 2" tiles for the end caps. The top and bottom plates are 3mm Sentra (foam PVC). The rest is plastic strip and 1.5mm rivets. Rear view: I built a 5th container, same length, but with an open mechanical area. Still needs details for the mechanical area. Fuel tank/generator, pipes, wires and such. Edited January 23, 2018 by Impact1 Kierdale, Gstealer, Subtle Discord and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/ Share on other sites More sharing options...
Pearson73 Posted January 22, 2018 Share Posted January 22, 2018 Nice work, good idea with the light grating. Impact1 1 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4990539 Share on other sites More sharing options...
Impact1 Posted January 23, 2018 Author Share Posted January 23, 2018 (edited) Next up is the Defense Platforms, for use as a firing platform, or mounting a large turreted weapon. I'm sill building the Defense Lasers. But these just drop into the ring pitsFirst version, after primer. Version Secundus, before primer. These are built using 3 electrical box and a VHS tape for the main structure. After disassembly I cut off 1/3 of the VHS tape, cut the circular opening, and glued it to the"top" of a round electrical box. The ring around the bottom is the lid from an electrical tape container. The other half of the body is a orange low voltage box stacked onto a blue single gang ebox The white trim is Drywall edge molding "corner bead". And the rest is electronic junk.Both models still need doors, ladders and hatches, and bitz hanging from the overhang added.Inspiration from Ironhands.comhttp://ironhands.com/h2_dl0.htmNext is the Ember Shrine, an Incinerator/Crematorium. Again it's been primed, but needs more detail, and a good paint job. This is built from two VHS tapes and two electric tape containers. Still need lights, ladders, and bitz hanging from the overhang added.Inspiration from Ironhands.comhttp://ironhands.com/ember.htmAfter building main body, I set it down up side down, and decided I liked better that way. I added the "lights" and tanks in a slightly different way.Soue materials:VHS Tape, Electric Box , Drywall Molding, electronc bits. Edited January 23, 2018 by Impact1 Pearson73, Markus_, deathspectersgt7 and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4990743 Share on other sites More sharing options...
Impact1 Posted January 23, 2018 Author Share Posted January 23, 2018 Built a couple more cargo containers. This time they are open platform with fixed end plates. Searching through my junk box, I found some of these. So after a little re-configuring, I get this. I had to cut the diagnal struts, but they are otherwise a perfect fit. Just have to touch up the grey primmer before painting. The load will need more detail added before painting. and I'll likely add some LEDs as well. Calyptra and deathspectersgt7 2 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4991427 Share on other sites More sharing options...
Maschinenpriester Posted January 23, 2018 Share Posted January 23, 2018 Very inspiring stuff indeed. I like these containers! Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4991566 Share on other sites More sharing options...
Impact1 Posted January 24, 2018 Author Share Posted January 24, 2018 For the doors and endcap on my containers, I started with these: They are Fluoroware 2 inch electronic chip carriers. I've ened up with several hundred over the years by dumpster diving at my place of work. I have about 10 varieties. This is my favorite. Kierdale, Aramis K and Subtle Discord 3 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4992619 Share on other sites More sharing options...
Naryn Posted January 25, 2018 Share Posted January 25, 2018 Great builds and good tips on bits. I’ll have to keep an eye out for those. Looking forward to more! Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4992883 Share on other sites More sharing options...
Subtle Discord Posted January 25, 2018 Share Posted January 25, 2018 Ummm... Yes, yes, and yes! It's absolutely amazing what you can make from nothing if you execute it right. And this is sooo right. A little creativity with the right found bits mixed with some scratch built styrene and you have something straight from the depths of a hive complex. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4992901 Share on other sites More sharing options...
Impact1 Posted January 29, 2018 Author Share Posted January 29, 2018 (edited) More stuff from this weekend. This time Tau scenery. I don't even own Tau models, but these seemed like a fun project, and after all it's for the greater good.Tau field generatorIt's typical primary function is believed to be creating a defensive barrier. More common use is to hide behind for hard cover.Tau Power Generators Not really sure how they work. Is it plasma, cold fusion, hamsters on a wheel?All three together for scale.These were made from small plastic plates. Wouldn't you know it, all I had in the cupboard was black plates. These are filled with layers of foam core and card stock. The end caps are cut down utility boxes, and caps for liquid laundry detergent. These were assembled primed grey. Then again in white. Then was added 1/8" ID and 1/4" ID wire loom, and whatever industrial fitting I had laying around. Recycled SMA RF connectors and keyboard bits. Edited February 6, 2018 by Impact1 Subtle Discord, Calyptra, Pearson73 and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4996172 Share on other sites More sharing options...
Bjorn Firewalker Posted January 29, 2018 Share Posted January 29, 2018 Impressive work. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4996724 Share on other sites More sharing options...
Mr Yellow Posted January 29, 2018 Share Posted January 29, 2018 Those shipping containers look really good, I think a tutorial is needed. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4996890 Share on other sites More sharing options...
Impact1 Posted January 30, 2018 Author Share Posted January 30, 2018 Those shipping containers look really good, I think a tutorial is needed. Thanks everyone. A tutorial? That sounds like work. I doubt i could find more of that type of light grating, it's from a dumpster dive. And Sentra pvc board may also be hard to find. I could redesign it using foam core and paper card stock. I'll try it this weekend. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4997631 Share on other sites More sharing options...
Ovidius Incertus Posted January 30, 2018 Share Posted January 30, 2018  Those shipping containers look really good, I think a tutorial is needed. Thanks everyone. A tutorial? That sounds like work. I doubt i could find more of that type of light grating, it's from a dumpster dive. And Sentra pvc board may also be hard to find. I could redesign it using foam core and paper card stock. I'll try it this weekend.   Not to jump you and your awesome containers, but if you want a ready-made tutorial, look on Youtube for the "Terrain Tutor" channel. He has a video tutorial for cargo containers very much like Impact's, just with slight different materials. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4997643 Share on other sites More sharing options...
Impact1 Posted January 31, 2018 Author Share Posted January 31, 2018 No worries. I saw that video after I built my containers. I'm working on a recipe that requiers only cardboard, card stock and PVA/white glue. Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-4997939 Share on other sites More sharing options...
Impact1 Posted February 6, 2018 Author Share Posted February 6, 2018 I've started on some modern/future urbane terrain. These are road bed tiles that are 1/2" tall at the sidewalks, and 12" wide. I have `11 feet of road bed tiles so far, including 2T intersections and 1X intersection. And plan to build 2 more intersections and 4 more feet of straight road bed tiles. When I'm done with these, I'll be starting on the city block tiles. The bottom layer is 5mm foam core. On top of this placed 1 1/8" thick 6 " wide strip of Sintra Link to comment https://bolterandchainsword.com/topic/343642-impact1s-scratch-build-buildings-and-scenery/#findComment-5004130 Share on other sites More sharing options...
