Has anyone used landspeeders to much success this ed? I built a iron wolves force for last ed, and they were a must take in that force. I want to use them this ed but I can justify the points cost for them. A single speeder with heavy bolter and typhoon missiles is 140pts.
Any thoughts?
https://bolterandchainsword.com/topic/343783-landspeeders/
A Long Fang pack with HB and 2 MLs has the same firepower output for a similar points cost. They can benefit from cover and can natively reroll 1s but have lower toughness and total wounds. They are less vulnerable to a couple of lascannon hits but more vulnerable to anti-infantry fire.
I think overall it depends how much you value the mobility of a Speeder.
https://bolterandchainsword.com/topic/343783-landspeeders/#findComment-4995024
Space Wolves have plenty of options for speed and mobility, it just depends on what you want to do when you get there.
For close combat, TWC are looking better after the points drop in Chapter Approved. For anti-horde shooting, Wolf Guard bikers are amazing for their points although I am not sure if they will retain all their current build options once the codex arrives. Wulfen deploying on the flanks thanks to our new stratagem are good, particularly if you drop in a Wolf Priest with jump pack nearby. Our flyers are both pretty good although pricey.
https://bolterandchainsword.com/topic/343783-landspeeders/#findComment-4995160
I'm currently using out flanking Wulfen, a blizz dread in a lucius pattern pod, a squad of termies with SS+combi plasma and Njal as my alpha strike. Im finding it pretty effective. I'm finding once that is down though, I'm fairly easy to out manoeuvre, so I want something with speed that can react and deal with a lot of different threats. It's why landspeeders came to mind, fast, can fly over terrain to get to objectives quickly and when given heavy bolters and missiles they are pretty effective against infantry or armour.
I guess comparing them to long fangs makes sense, I was comparing them to Grey Hunters in my head, but there not really the same. All food for thought.
https://bolterandchainsword.com/topic/343783-landspeeders/#findComment-4995279
It's just for an all comers list. I usually play pick up games in my local games shop.
Sorry for all the questions Yoyo I have an engineering mind.  Like to have the problem in mind before I brainstorm solutions.
We need to establish the primary role for your response unit from among the following:
TEQ: Terminator Equivalent - Terminator Stats
MEQ: Marine Equivalent - Space Marine Stats
GEQ: Guard Equivalent - Guardsman Stats
There are different solutions to each of those.
Handling 1 of those types of targets is easy.  The more versatile you want your response unit the more expensive it will be.
IMO pure SW response units go in this type of escalating order
-Landspeeder (mono response)
-Wolf guard with jump packs (multi response but getting pricey)
-Wolf guard bikes (same as above...but increased dakka to counter hordes for more points)
-Stormwolf/Stormfang economy package (i.e., don't upgrade weapons)
Low cost response unit
Landspeeders are probably the tool of choice for GEQ (think cheap objective sitters or infiltrated scouts)
A single landspeeder runs you approx. 100 depending what you put on it
16 mobility lets you move easily to try and get angles to negate cover or simply stay away from the guns covering your target
Nice cheap option to deal with GEQ but that loadout isn't a serious threat to other categories
Basically a landspeeder with dual heavy bolters will shred GEQ but it won't have the same results against MEQ or TEQ.  If that is fine and you have other choices to deal with it use this
Luxury response unit
A basic stormwolf can hunt anything.  The focused helfrost + lascannon handle TEQ and even anti armor (4 shots worth).  The dispersed helfrost + HBs handle GEQ and MEQ in large numbers (6 + 2D3 shots).  The problem is you pay just under 300 for that platform.
Moderate response unit
IMO the middle of the road jack of all trades unit would be wolf guard with jump packs
You start to get pricy here but they fill many holes
-they deep strike so you guarantee they do their job before dying
-they are extremely versatile and can handle a variety of targets
-Combi plasma lets them handle pretty much all of GEQ MEQ and TEQ (plasma is the versatile choice but you can go stormbolter or melta as well)
-You can even toss storm shields on all of them as an insurance policy for them to stick around longer
This unit comes in slightly under 200 (call it double the landspeeder) but is a much more versatile tool
*Edit*
Was using the index points instead of CA...minor difference
It is more expensive than the LS and slower (12 is still good and infantry status lets them handle certain types of terrain better)
Hope that helps in your decision making!
Edited by TiguriusX
https://bolterandchainsword.com/topic/343783-landspeeders/#findComment-4995786
Register a new account
Sign in
