BeamKatana Posted January 28, 2018 Share Posted January 28, 2018 Hey all, new to 8E, and I wanted some confirmation. The Chaos index lists among potential HQ choices as Lords and Sorcerers on bikes, or various demon mounts, but they're not in the CSM codex. Is this deliberate, in that you can't have lords/sorcerers on bikes anymore in official play? Or is stuff from the index valid unless explicitly overwritten (i.e., reduced cost of blastmasters) by codex or errata? Link to comment https://bolterandchainsword.com/topic/343827-8e-chaos-index-v-codex-question/ Share on other sites More sharing options...
Mr. Shine Posted January 28, 2018 Share Posted January 28, 2018 (edited) This image: Can be found on the last page of the Designer's Commentary on the Warhammer Community FAQs page. Basically if it's in the codex you use the codex datasheet, unless it has wargear options in the index that are not in the codex, in which case you may use the index wargear options with the codex datasheet. If it's in the index but not the codex then you may use the index datasheet. Edited January 28, 2018 by Mr. Shine brother Vorn_GarDos 1 Back to top Link to comment https://bolterandchainsword.com/topic/343827-8e-chaos-index-v-codex-question/#findComment-4995983 Share on other sites More sharing options...
BeamKatana Posted January 28, 2018 Author Share Posted January 28, 2018 Ok, that makes sense. Thanks! Link to comment https://bolterandchainsword.com/topic/343827-8e-chaos-index-v-codex-question/#findComment-4996006 Share on other sites More sharing options...
