Lucerne Posted January 29, 2018 Share Posted January 29, 2018 What's an economical, good looking way to get modelling chain for, say, bolter straps, or to decorate Marines with? I hear shops like Michaels will have model chain, but what scale should I be getting, and is there a particular brand or keyword to keep in mind? Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/ Share on other sites More sharing options...
Tichinde Posted January 29, 2018 Share Posted January 29, 2018 I just tend to use cheap jewelry chain, at a size that looks ok for what I plan to use it for used some recently on this guys waist: Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4996742 Share on other sites More sharing options...
Lucerne Posted January 29, 2018 Author Share Posted January 29, 2018 I just tend to use cheap jewelry chain, at a size that looks ok for what I plan to use it for used some recently on this guys waist: Um, can you tell me if there's any label for the thickness you used/how you prepare the chain for the miniature/painting? Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4996769 Share on other sites More sharing options...
Tichinde Posted January 29, 2018 Share Posted January 29, 2018 I just tend to judge by eye, use old chain from necklaces collected over the years. Use small clipper\pliars to get right length then carefully superglue,prime and paint. Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4996773 Share on other sites More sharing options...
Hrolf the Cunning Posted January 29, 2018 Share Posted January 29, 2018 I have a pack produced by the company Master Tools. It has two chain sizes with link dimensions of: - 1.5mm long x 0.8mm wide - 2mm long x 1.1mm wide I think the scale for infantry miniatures is pretty spot on. It seems to be pretty widely available online. https://www.sceneryworkshop.nl/universal-fine-chains-set-40cm-tr-06624.html Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4996793 Share on other sites More sharing options...
Arkhanist Posted January 29, 2018 Share Posted January 29, 2018 Greenstuff world do 1.5mm chain, which is a good size for standard minis. The 1.5mm is on the top, 3mm on the bottom. http://www.greenstuffworld.com/461-thickbox_default/hobby-chain-15-mm.jpg Lucerne 1 Back to top Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4996829 Share on other sites More sharing options...
Lucerne Posted January 30, 2018 Author Share Posted January 30, 2018 Thanks everyone! Link to comment https://bolterandchainsword.com/topic/343867-infantry-scale-modelling-chain/#findComment-4997181 Share on other sites More sharing options...
