Markconz Posted January 30, 2018 Share Posted January 30, 2018 Hi, can you stack this psychic power on a unit? Thanks. Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/ Share on other sites More sharing options...
Charlo Posted January 30, 2018 Share Posted January 30, 2018 No. In open play, while you can cast the power more than once, each unit can only be affected by a single instance of the same psychic power. In matches play, you can only cast the power once per turn regardless. Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/#findComment-4997263 Share on other sites More sharing options...
Markconz Posted January 30, 2018 Author Share Posted January 30, 2018 Ok thanks Charlo. Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/#findComment-4997449 Share on other sites More sharing options...
Markconz Posted January 30, 2018 Author Share Posted January 30, 2018 And just to clarify, the channeling stratagem is rather limited then, given you need 3 psykers close together to do it, and you can't cast something already cast. Can a psyker cast smite for a second time or is that out too? Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/#findComment-4997688 Share on other sites More sharing options...
Charlo Posted January 30, 2018 Share Posted January 30, 2018 Smite can attempted to be cast once by each Psyker in your army per turn :) Brother Aether 1 Back to top Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/#findComment-4997753 Share on other sites More sharing options...
Markconz Posted January 30, 2018 Author Share Posted January 30, 2018 Yeah ok that's what I thought, cheers again Carlo. Link to comment https://bolterandchainsword.com/topic/343891-can-unleash-rage-stack/#findComment-4997761 Share on other sites More sharing options...
