dudemanmcgee Posted February 2, 2018 Share Posted February 2, 2018 So I recently got a bunch of sisters models and inquisition and the index and now I've been looking at what to build with it, and was looking for suggestions on this. The models I have to work with are: Celestine and two Geminae 1 Immolator 4 Rhinos 24 Battle Sisters W/ Bolters 2 Battle Sisters w/ Flamers 2 Battle Sisters w/ Meltas 3 Sister Superiors 1 Canoness 9 Repentia Sisters 1 Mistress of Repentance 2 Death Cult Assassins 1 Ministorum Priest 1 Sister Hostipilar 1 Sister Dialogus 1 Penitent Engine 1 Inquisitor w/ Power Sword and Inferno Pistol 1 Inquisitor w/ Incinerator 1 Iquisitor Karamov 1 Daemonhost So yeah as I said I'm fairly fresh with sisters and was just for help on what I could build with my sisters possibly in the 500 or 100 point range. Thank You for the help. Link to comment https://bolterandchainsword.com/topic/344020-army-help/ Share on other sites More sharing options...
A.T. Posted February 2, 2018 Share Posted February 2, 2018 You'll want more special weapons (melta and stormbolter) - you can bash up/proxy the latter from bolter sisters. At low points with what you have a spearhead of melta and stormbolter dominions with Celestine (or a canoness with relic and bodyguards in small games) will probably be the way forwards. Push early with everything that isn't holding an objective. Penitent engines and repentia are to individual taste, and always take a priest with the latter. You can proxy up a missile launcher on a rhino for an exorcist - roughly the same firepower as a las razorback - and for anti-psyker an inquisitor/greyfax with minimum acolyes is relatively cheap. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5000670 Share on other sites More sharing options...
Beams Posted February 2, 2018 Share Posted February 2, 2018 I'd say try running a melee army (Repentia, Cannoness, Celestians) in smaller games. At the very least, it'll be fun. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5000690 Share on other sites More sharing options...
robofish7591 Posted February 2, 2018 Share Posted February 2, 2018 I would definitely recommend picking up or converting some special and heavy weapons. It does look like you have a pretty decent foundation to an army though! Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5000869 Share on other sites More sharing options...
dudemanmcgee Posted February 2, 2018 Author Share Posted February 2, 2018 Any specials/heavies in particular? I heard meltas and storm bolters are decent this edition. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5000906 Share on other sites More sharing options...
Atrus Posted February 2, 2018 Share Posted February 2, 2018 Meltas and storm bolters for sure. Heavy bolters are a fair investment too. Heavy flamers and multimelta are to taste. Multimeltas are absuredly over priced. I never leavy home without heavy flamers myself. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5000970 Share on other sites More sharing options...
robofish7591 Posted February 2, 2018 Share Posted February 2, 2018 As far as special weapons go, melta and stormbolters are the most popular. Flamers are ok, but storm bolters are longer range and more reliable. I have had some success with a dominion squad loaded up with four flamers and a combi flamer in an immolator though. For heavy weapons, heavy bolters and heavy flamers are the go to. Heavy bolters are one of our only "long ranged" weapons. I like to stick my heavy bolters in retributor squads with a simulacrum nearby to give them acts of faith. My heavy flamers usually go in my battle sister squads, since they are usually moving up to go take objectives and what not. I usually will pair the heavy flamer with either a regular flamer or a melta gun, it usually depends on how I have the rest of the army set up since I only have a limited amount of models. Multi meltas can be useful, but the -1 to hit for moving really hurts them I feel. I would rather just take two normal meltas that can move and fire normally. Also, by the way, flamer immolators are amazing. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001026 Share on other sites More sharing options...
bkde Posted February 2, 2018 Share Posted February 2, 2018 4-5 Heavy bolters will go a long way. 4 HB armed rets are a staple of a lot of lists. Otherwise as others have said meltas and stombolters. Meltaguns are always great, stormbolters are more a fad of this edition. Heavy flamers/flamers have fallen out of favour a bit this edition due to the 8" range. Immo flamers are amazing though. Once you're ready to branch out Seraphim should be your next purchase. Regarding list options, at 500pts Celestine will butcher most things. If you want to go more balanced with what you have: Cannoness w/relic power sword 5-10 BSS w/2xflamers in a rhino 5 dominions w/2x meltas in a flamer immo The above is a good start, can season with a penitent engine or priest + mistress + repentia in a rhino or Celestine to taste. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001078 Share on other sites More sharing options...
Purifying Tempest Posted February 2, 2018 Share Posted February 2, 2018 Celestine + 2 Geminae Canoness 5 BSS + Superior + 2 Meltagun + Rhino (8 sisters) 5 BSS + Superior + 2 Flamers + Rhino (8 sisters) 9 BSS + Superior + Rhino (10 sisters) 3-5 Repentia + Mistress in Immolator Penitent Engine That may not be the best army, but it is closing in on 1200 points and +3 CP for a battalion, with the models you listed. I would definitely look at adding meltaguns (at least 2 for a Dominion squad of 4 meltas in your Immolator). That'd be the easiest, most efficient, and least costly upgrade to your army. A heavy flamer would give you a Heavy Flamer + Flamer combo on one of your basic battle sister squads, which is a decent upgrade. As many have said, the basic flamers are not that great this edition. If you're wanting to spend money: Seraphim and Heavy Bolters are efficient upgrades, as well as an Imagifier to hang out and cheer on your HB Rets. That will probably put you in the 1500 point range pretty easily. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001102 Share on other sites More sharing options...
Ficinus Posted February 2, 2018 Share Posted February 2, 2018 People are saying that basic flamers aren't great, but I love running heavy flamer, flamer, combi-flamer in squads of five doubled up in Rhinos. It is very demoralizing for the opponent to see you auto-hit with HF, auto-hit with flamers, and then do it again with a second squad. Also, it's fantastic for defence against most charges (those within 8"). Still miss those templates, though. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001192 Share on other sites More sharing options...
dudemanmcgee Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks for the advice so far everyone I started converting 6 basic sisters into melta sisters using the ends of Stikkbombs to create the melta end and a few other plastic bits for tubing. I'll definitely need to look into some heavy bolters as well by the sounds of it and probably another immolator. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001198 Share on other sites More sharing options...
Atrus Posted February 2, 2018 Share Posted February 2, 2018 You can also convert a rhino or two into the revered Repressor. Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001212 Share on other sites More sharing options...
robofish7591 Posted February 2, 2018 Share Posted February 2, 2018 Sounds like a nifty conversion, you should post some pictures if you can. I'm sure everyone would like to see them! Link to comment https://bolterandchainsword.com/topic/344020-army-help/#findComment-5001217 Share on other sites More sharing options...
