The Wolfguard Posted February 4, 2018 Share Posted February 4, 2018 So I ended up getting a load of Forgeworld Deathshroud back when I was playing using 30k Death Guard. Come around to 8th and now I know nobody playing Horus Heresy. I have a bunch of Deathshroud and was wondering if anybody knew or had any advice on how to bulk them up or make them slightly taller so they fit in a bit better. I'm not very good at greenstuffing myself I'm afraid and don't have much in the way of spare bits as of yet, but do you think there would be any easier solutions? I added a small bit of greenstuff between the chest and legs to make them a small bit taller and they're still quite a way off as you can imagine, they don't need to be the perfect size but there must be something that will make them a bit closer? Here's a picture for comparison, sorry for the not so good quality: https://media.discordapp.net/attachments/270617707429232642/409820022685433866/20180204_211803.jpg?width=870&height=652 Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/ Share on other sites More sharing options...
Wolf Lord Loki Posted February 4, 2018 Share Posted February 4, 2018 Possibly stand them on a bit of cork or something (dead marines etc) to give them more hight Its what im doing to blend A few Dark Vengance marines in with the new Dark imperium death guard Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5002947 Share on other sites More sharing options...
The Wolfguard Posted February 4, 2018 Author Share Posted February 4, 2018 That would definitely work height wise. I'm also worried about how thin/frail they look next to the other rather bulky terminators. Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5002989 Share on other sites More sharing options...
Checkmate77 Posted February 23, 2018 Share Posted February 23, 2018 I wouldn't worry about that. Lore shows that Death Guard come in all shapes and sizes depending on what diseases they are infected with. For some, this will result in bloated monstrous figures, but for others it could wither them away. If anything, having your Terminators look different will make your army more unique. Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5018003 Share on other sites More sharing options...
Nomada Posted February 26, 2018 Share Posted February 26, 2018 Completely agree with Checkmate77. Bear in mind as well that a Chaos terminator with all it's spiky bits on the top doesn't differ a lot from one which doesn't have it. Using the correct base the model needs I wouldn't bother too much in the actual bulk of the model (when it's not that different). Another thing would be to use the 30k Mortarion in a 40k match.. which sadly I can't do neither Checkmate77 1 Back to top Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5019679 Share on other sites More sharing options...
Wolf Lord Loki Posted March 4, 2018 Share Posted March 4, 2018 Possibly stand them on a bit of cork or something (dead marines etc) to give them more hight Its what im doing to blend A few Dark Vengance marines in with the new Dark imperium death guard Ive since found that potentially its the new 32mm base that add the extra hight to the new plague marines. I stood on of the dark vengance chaos marines on the bace witht the new plague marine and the size difference was negligible Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5024730 Share on other sites More sharing options...
Charlo Posted March 5, 2018 Share Posted March 5, 2018 One easy one would be to put some Cataphractii shoulder on them, as opposed to Tartaros - keeps them a little more 40k in terms of equipment. Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5025333 Share on other sites More sharing options...
Vaz Posted March 5, 2018 Share Posted March 5, 2018 I would take the new plastic there, and cut each arm at the armpit area or so. Then fit the resin DG scythe and arms to the pad. While the arms themselves will be slightly thinner than the legs, could argue they are kept nimble as disease piles on elsewhere. That'd give you solid looking custom work. I'm mixing my plastics with some DG FW bitz as well. Hopefully once HH gets a proper update armies will be able to go back and forth. Espeically seige of terra style nurgle, which should not be far off from the armies we build today. Link to comment https://bolterandchainsword.com/topic/344091-bulking-up-the-fw-deathshroud/#findComment-5025779 Share on other sites More sharing options...
