The really basic one sits at 1443 according to my battlescribe. Don't have the codex with me, so can't check. But 3 sorcerors, 6x10 cultists, 3 hellbrutes, 3 spawn (not demons or beasts imho), 3 vindicators. Not that I'd ever want to field a list like that, but that's the cheapest choices with the limits you've proposed. So it's doable within 2K, if you want to, but if it's fun or decent on the table is another thing.
If you make it a bit more specific, it becomes easier to get closer to what you want.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5005316
Brigade WITHOUT tzaangors? tough sell.
I have 20 cultists in my 1k sons,
So a decent brigade for me looks like:
Ahriman
Exalted on foot
Exalted on disc (sword)
10 cultists
10 cultists
10 tzaangors
10 tzaangors
5 rubrics
5 rubrics
hellforged contemptor (duel kheres)
Helbrute (missile/plasma)
Tzaangor shaman
spawn
3 enlightened with bows
defiler (heavy bolter, havoc launcher)
Maulerfiend
Mutalith vortex beast
Sitting at 1835. so you have 165 to play with.
If you "really" wanted to you could drop a tzaangor unit and stick 5 more rubrics in there.
Admittedly it is very hard to get us to have a good 2000 point brigade, I think us getting a solid 9 command points with 2 battallions is far far easier. You lose 3 command points but you gain far more ability to adjust.
The list above has enough variety and enough mixes of units to be "reasonably" effective, but as with all brigades its MSU city in here lol. My big inclination is to drop rubrics entirely for this list (for those of you that know me; thats unusual as my rubrics rule on the table) and do 20 cultists, and 40 tzaangors, filling out your troops and then start dumping the extra points into the HQ slot.
all cultists is fine, but I find mixing Tzaangors/rubrics/cultists will mathmatically and CP wise (as well as competetive...) will be one of the best options, splashing each will have its merits.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5005446
That's barely worth calling a TSons army with just Cultists, Helbrutes, spawns and Vindicators lol
Didn't say I'd field it, did I? ;)
To me it's not really a TS army either, but he asked for a non-beast, non-tzaangor and non-daemon brigade at 2k.
If I were to just make a brigade, mine would be quite a lot closer to what Sonoftherubric21 suggested though with a few tweaks.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006003
Ahriman
Exalted on foot
10 cultists
10 cultists
10 tzaangors
10 tzaangors
5 rubrics
5 rubrics
Tzaangor shaman
spawn
Maulerfiend
Brigade without Tzaangors, Daemons, or Beasts?
Renegades and Heretics have you covered.  Let the SPAM BEGIN!!!:smile.:
HQ
3 Renegade Commanders (Covenant of Tzeentch)-75
Elite
3 Command Squads (4 Man each)-72
Troops
10 Militia (Mortar)-45
Fast Attack
1 Scout Sentinel (Multi-Laser)-45
Heavy Support
Renegade Heavy Weapon Squad (3 Teams-Mortars)-24
Congratulations!!!
You are now the proud owner of 15 Mortars (all the rage these days), 3 Scout Sentinels for board control and pushback, and a whole TON of disposable, WS/BS 5+ morons. :smile.:
All for the low, low price of 624 points, leaving you 1376 for ACTUAL members of the 15th Legion.....and yet more command points.
That's frankly quite frightening given the effectiveness of even BS 5+ mortar spam and the fact that a command point-hungry army like TS now no longer has that worry in this case. The board control and pushback capability are also nasty.
With that 1376, you can get Ahriman, an Exalted, a Terminator Sorcerer, 10 Scarab Occult, 10 Rubricae, 2 ML/Twin Heavy Bolter Helbrutes, and a bit left over for some extra wargear. You can also forget the brutes and just keep spamming characters or add more dust bunnies. Or you could spiff up the Renegades a bit....maybe throw in some Malefic Lords or Covens for theme instead of one or two of the Commanders or replace some of the Command Squads with Sniper Marauders.
With the spend I just suggested, you'll end up with 13 command points. Relics and Stratagems Ahoy!!!
EDIT: You could also put lascannons in those BS 3+ Command Squads if you wanted and then maybe drop one for an Enforcer so your idiots don't run.
Just. As. Planned. :)
Edited by GreaterChickenofTzeentch
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006746
Amazing outlay of Tzeentchian goodness.
My concern is that you can see issue of CP distribution on Elite armies when running mono-faction. Grey Knight, PA, etc. I really think it should be connected to HQ's directly as they're the only consistent factor across armies.
More HQ's, more CP. Max 3 detatchment, 12 CP limit in matched play.
CP per detatchment is decided by type of detatchment and amount of HQ's. All detatchments gain CP equal to the minimum HQ requirement for the detatchment multiplied by X plus 2 per any additional HQ beyond this.
X = 3 for battle-forged mono-faction armies, 2 for soups or mixed factions.
Seems pretty fair. People already take whatever is best and then a minimum of guard/renegade/daemons for CP so why not?
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006782
Do that again; but this time only from the THOUSAND SONS CODEX :p
I dont play the Thousand sons codex for chaos guard lol.
Correct but do you want hell command points or pure thousand sons? As far as Chaos faction keyword that is a solid way to get major CP and with the helm we will be able to regenerate them as well. I think it is a solid way. Not a "Thousand Sons" army but that's not the fous of that list.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006820
Do that again; but this time only from the THOUSAND SONS CODEX :tongue.:
You already covered Cultist spam, so I had to go further (and the OP doesn't play Thousand Sons for Tzaangors, Spawn, and Mutaliths, apparently). :)
BTW: 1300 points is pretty much an actual army....small one, but you can still have a couple HQ's, a couple Elites, and some Rubricae. Go light on Terminators and you can have an entire Battalion.
It honestly reminds me of those entire planets that worship Ahriman as a god of fire and hidden knowledge. Just get some old metal Ahri figs and paint them up like golden statues and use those on little arks/palanquins instead of Chaos Sigils....then keep the whole TSons detatchment in the Webway or Teleportarium and have him show up to "answer prayers." Kinda like those poor sods who finally solved that ancient equation and unwittingly opened a warp gate into their hidden library so he could walk in and plunder it. :)
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006852
Ah okay I admit that I forgot about the OP requirement.
Hella command points doesnt innately win ya a game though...though perhaps a million BS/WS 5+ bodies might :tongue.:
And mortar spam and DS denial and three beefy characters, plus Scarabs, Rubrics, and/or Helbrutes. The actual TS have to be the hammer to the renegade anvil or it will struggle.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5006868
Apologies for the radio silence, life gets on the way sometimes...
To be more specific, am wanting mostly rubrics, with a couple of cultist unit for points efficiency...
SOT and hellbrute for elite choices
I would prefer no vindicators as I find them lacklustre...
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5007011
I can’t help but agree that CP distribution is a problem. Especially the high CP lists with access to options to increase them even further.
I like the system, 2 matching keywords (or specified single one, I.e catachan or 1ksons) gives a certain bonus as you’ve suggested based off HQs. This would still allow cheap CP through guard which could be their thing.
Otherwise maybe rethinking the big detachments to be more around points (or far I say power points) that just raw unit counts.
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5007117
I think my brigade would do pretty well which consists of:
Ahriman (not WL)
2x flying claw DP's wielding dark matter and crystal helm
5x cultists (try to include 1 big blob)
9 man rubric unit (or bigger) that is going to deep strike with Ahriman
3x spawn
3x helbrute
3x mutalith vortex beast that are going to buff the cultists marching forward (the buffs stack)
https://bolterandchainsword.com/topic/344199-brigades/#findComment-5010097
Register a new account
Sign in
