librisrouge Posted February 8, 2018 Share Posted February 8, 2018 I keep trying to make pure Militarum Tempestus army work and I keep stumbling upon the problem of taking out tough targets. While overcharged plasma forgiveth a multitude of sins, having to get six shots through to kill a single russ makes it a limited tool, better yet if I find myself facing multiple knights or a super heavy. First, let me define "pure" MT. It's anything with the following keywords: Militarum Tempestus Militarum Auxila Aeronautica Imperialis Inquisition Ordo Perfectus Ministorum (but not Adeptus Sororitas) To me, this leaves use with a few options: Plasmaguns on Scions - Works, especially on armies with only a bit on armor, but -1 to hit or armor spam quickly makes them inefficient. Meltaguns on Scions - Even more expensive than plasma, less shots, harder to get in range, but better AP and the possibility of 2d6, keep the highest, at least makes it worthy of consideration. Vendetta Gunship - Six lascannon! However, a LOT of points. Also, if you move (and its a flyer), you're hitting on 5s. Boo. Taurox Prime with Missiles - Two AT shots on a vehicle almost the costs of a russ. Worth looking into because we're shy on options but the gatling is just that much better at this. Combi-Weapons on various inquisition units - More expensive that Scion equivalents for less BS. Pass. Hellstrike Missile on various flyers - Chapter Approved made this option highly obsolete. Did I miss anything? Does anybody have any other ideas? Am I simply facing an uphill battle with not good answer? Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/ Share on other sites More sharing options...
Kontakt Posted February 8, 2018 Share Posted February 8, 2018 Aren't auxilia (bullgryn) available to MT? Power mauls are STR7 - kinda useful duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5006680 Share on other sites More sharing options...
Halfpint100 Posted February 8, 2018 Share Posted February 8, 2018 I think you are facing an uphill battle with the units you have available for their price. Missile, autocannon taurox spam might be the best option tbf. Though they are pricey librisrouge and Guardsman Bob 2 Back to top Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5006709 Share on other sites More sharing options...
Tirak Posted February 8, 2018 Share Posted February 8, 2018 Vendettas suck, if you want overpriced flyers look toward the Lightning, 2 Lascannons and 4 hellstrikes blasting away at 4+ to hit and -1 to get hit. Guardsman Bob and librisrouge 2 Back to top Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5006728 Share on other sites More sharing options...
duz_ Posted February 9, 2018 Share Posted February 9, 2018 Bullgryns in Valks would be the best option? At least then they can get close enough and tie them up... Not the most effective option though?Why not just take a spearhead of LR's?You won't lose the MT RD and they'll be obsec too! :D momerathe and Guardsman Bob 2 Back to top Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5006749 Share on other sites More sharing options...
Cap'm Heckus Posted February 9, 2018 Share Posted February 9, 2018 Telepathica is also available without harshing your doctrines. Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5006787 Share on other sites More sharing options...
Frater Cornelius Posted February 18, 2018 Share Posted February 18, 2018 Most non-infantry tools MT would have access to are better at mulching infantry, so I’d say Plasma and Melta Scions on top of Maul Bullgryns. The reason I like Meltas against Tanks is that they synergize well with the Scion re-roll to wound order. Plasmas will usually overcharge, hence they need the re-roll 1s to hit order. Meltas have the choice between 1s to hit and all to wound. The latter is statistically superior, especially against T8. Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5013315 Share on other sites More sharing options...
Kontakt Posted February 18, 2018 Share Posted February 18, 2018 If you can stomach an added detachment, you could add in a tank detachment or a super heavy detachment. Link to comment https://bolterandchainsword.com/topic/344264-militarum-tempestus-at/#findComment-5013708 Share on other sites More sharing options...
