Sneakybamsen's pain(t)ful work
sneakybamsen
This is an attempt for me to make my own progress log of my big love (apart from my wife and kids) - my Dark Angels.
As I am writing this I have a total of barely 6000 points (wargear included) of painted models, of which a few are not completed, but only painted to a degree, and as such will need revisiting at some point. I'd like to try and take pictures of all of my fully painted stuff, and get them uploaded here, but that will probably be a while before that is done. For now I'll start out with the pictures I have already, and I hope you can accept that my painting skills are far from a lot of the awesome work that is being posted on these very pages. Also I don't have the best lighting at home, so some pictures are quite dark. I shall try to fix this in the future.
My Librarian and (interrogator-)chaplain on bike
My Ravenwing Apothecary
My Land Speeder Vengeance
My Imperial knight warden/crusader (he's magnetized)
Techmarine
Librarian in terminator armour
Interrogator-Chaplain
Company Master
Land Raider
Razorback
Rhino
Drop pod
Contemptor Dreadnought
Venerable Dreadnought
Dreadnought from Assault on Black Reach
Dreadnought
Another Dreadnought
Deathwing
Devastators with grav cannons
Assault squads
I will try to update this with the work I am doing, but will probably not be taking a lot of WIP shots. The idea of this log is to try to keep my motivation going, so I can reduce my backlog of over 9000 points.
Edit: Updated a couple of pictures as I now have a lightbox for taking photos of my models.
https://bolterandchainsword.com/topic/344273-sneakybamsens-paintful-work/
I finished the apothecary last night, and the land speeder vengeance on wednesday last week. The next model to be treated will be my take on Sableclaw. Right now he is just primed, but here's to hoping I can get started on applying base colors this weekend.
  • 3 weeks later...
Here's my take on the company champion. I am not a great modeller by any means, and the photo isn't exactly awesome either, but it does give an idea of the pose of the model, which I absolutely stole from Rizaras beautifully modelled primaris company champion, which you can see here
Champion conversion looks great, don't downplay the skills, keep it up.
I have to ask about the headlights on the bikes, particularly the Chaplain.  It really pops, besides what appears to be white and blue paint (sorry the names of which escape me as I'm still in old GW paint), what techniques did you use to get this effect?  One drawback to getting to the end of a piece is realising you have to pop some $$$ on 2 or 3 paints just to finish up headlights/windows/lenses etc.  Was hoping for some insight before I bite the bullet.
The Champion's looking good brother; I do feel the sword may be a little oversized and the pose could be improved by changing its angle so that it's pointed over the top of the shield, however some photos from different angles would determine this a bit better.
Thank you for the kind words. The bike headlights I kept simple - white with Baharroth Blue near the edges. Used small brush and tried to keep it tidy. No fancy tricks to that, although if you invest more time and effort than I did, I think you could easily improve it. I only did it that way because I feel yellow headlights is not something that belongs in the 42nd millennia.
Regards
Thank you. I can see what you mean, but I felt it had to be more than a regular powersword (it's the one GW uses for Sableclaw, as far as I know) while still made for power armour use, as it afterall is a Blade of Caliban. With regards to angle and being pointed over the shield, I am not sure what you mean? I know the way the blade is twisted in relation to the models hand and arm is a bit off, but damn shoulderguard wouldn't let me do it any other way.
Photos of it now will be different, it's been primed black just after I took that shot. I'll see if I can get some shots of the model if/when I get that lightbox I ordered.
That's a good point regarding the need to differentiate between the blade and a regular power sword, it might just be me to be honest, I find the space marine relic blade from the vanguard kit to be way too long too...
With the sword/shield angle, it looks to me as if he's stabbing over his shield or in a guarding stance, almost akin that held by a warrior in a shield wall, however the angle's not quite right. If this wasn't the intended pose, then no worries. I get what you mean with the arm positioning too, shoulder pads with the larger trim/guards have been the bane of my chaos arm-positionng attempts.
  • 1 month later...
Very nicely painted! Those black Deathwing Terminators look very unique!
If I may, I'd like to give you the tip to drill out the barrels of guns. It really adds that extra bit of realism.
You may, and have already done so elsewhere. My Sableclaw has the Heavy bolter muzzles drilled, and I'll try to get it done as I go along, but until it becomes habit, it's hard to remember :)
Fair enough! I sometimes forget if I've told specific folks before. Since this topic didn't have a post of mine, a assumed I hadn't!
I tend to drill them as soon as I build something. If you need to do it afterwards for 9000 points of backlog, it'll take some time indeed. I recommend putting on some good music and start drilling :D
You may, and have already done so elsewhere. My Sableclaw has the Heavy bolter muzzles drilled, and I'll try to get it done as I go along, but until it becomes habit, it's hard to remember :smile.:
I tend to drill them as soon as I build something. If you need to do it afterwards for 9000 points of backlog, it'll take some time indeed. I recommend putting on some good music and start drilling :biggrin.:
Perhaps it was an overstatement on my part, you haven't told ME to do it before, but you suggested it to another user, and I seconded your opinion. I think the GW drills will enable drilling bolters, heavy bolters and maybe even storm bolters and bolt pistols. Perhaps plasma pistols will be drilled too in time.
Yes Stobz, I've stopped being a slacker, at least for now. Somehow that ETL motivates, especially now that I know I can pledge my knight. So much so, that I started painting a scout squad and some plasma devastators last night! :o
Terrific work here brother, solid paint jobs all around! Your green looks really great on the vehicles too
I’m curious about the black DW. Why did you choose that, if you don’t mind me asking? They look awesome, don’t get me wrong! I’m just curious as to why
Thanks a bunch, Greenz!
I don't mind the question at all, and I'm happy to answer, that I am not a fan of the bone theme GW gave them. I much enjoy the story of how they went from black to bone though, a squad defending against a Tyranid infestation (yeah, that's how badass Deathwing should be). So my Blackwing, as I call them from time to time, is paying homeage to that particular part of our fluff. Luckily we have the rule of cool to "refer" to when deciding on how to model our little dolls and how to paint them, so there is no obligation to do as GW suggests.
It has a downside, though. I'm not too fond of painting black, which I found out after I had painted my first terminators, but I'm not going to redo what I have done just because the future work might be slightly offputting (Belial, chaplain in TDA and 20'ish terminators if I want to have Tartaros too). That said, black does take less basecoating, which is nice :smile.:
I've sort of come to the realisation that my bases are dull and don't do enough for my models. I have been basing them i simple and quick, but it's not going to cut it. Luckily it's not all my painted stuff that I'll have to rebase, a lot of it hasn't had the treatment I used to use. A good example is the knight crusader and my Blackwing. For instance my Deathwing Ancient is missing a tuft on his base. It was glued in place, but the stuff just drops off. The same goes for the flock, it falls off as it sees fit. Been trying PVA both watered down and not, doesn't seem to make a difference. Neither does the thickness of the layer of glue.
Some of my dreadnoughts have themed bases from their boxes, I could lean towards creating similar looks for the rest of my models.
I'd like some input to this if possible, preferably some thing fairly simple, as I'll never get anything done if I am to spend an hour per base :smile.:
Let's hear what you do.
Regards
Sneaky
Regards
Sneaky
I use PVA glue only for flock and/or sand. Everything else (=bigger/coarser) i just dab into CA glue and superglue in. Good practice, if you are not doing that already is to go over it once or twice with varnish. That really seals the things in, especially flock.
But generally, I water down my PVA 1:1 and leave it to cure at least 24 hours, seems quite okay and solid bond. With paint coat afterwards and the varnish, it holds fairly okay. Unless I chip at it with fingernail, try really hard to "smudge" it off with my finger or the mini falls off table or terrain in very unpleasant way, it is good.
Was talking to a guy at the club the other day, after listening to him I have decided to try the cork-mat method to give that rock-like look. Ripping out chunks from the mats, put the model on them, maybe add sand around the base, prime. It means I'll have to paint the bases, but even the ones my dreadnoughts are on didn't take long, so I think I'll be happer with that.
Hopefully I'll seen get more work done on my ETL pledge.
