Rat_Punter Posted February 20, 2018 Share Posted February 20, 2018 Hi all, I'm trying to maintain the Khorne theme of my army but am struggling to influence opposition deployment strategy (as I do when using ratlings/scout marines). Nurglings are the ideal unit for this and ensure a decent deepstrike zone for the bloodletter bombs. With the above in mind, do any of you fine warmongers have any third party suppliers that might be able to provide Khorne style large base swarms? GW Nurglings are just too fat and rotten. Thanks in advance, Rat Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/ Share on other sites More sharing options...
Mileposter Posted February 20, 2018 Share Posted February 20, 2018 Depending on your proficiency/comfort with Green Stuff, grabbing some Rat swarms from Age of Sigmar and adding horns, blades, teeth, etc. Might be a ticket. Alternatively, could get some Spirit Hosts, cut them down a bit, and use the cut bits + Green Stuff for malevolent Daemon Apparitions. Several Daemon stories made it sound like the very air tried to murder them in Khornes influence... Now it could! Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5015136 Share on other sites More sharing options...
Dinobot Posted February 20, 2018 Share Posted February 20, 2018 You could indeed fashion Spirit Hosts as Blood-Elementals. bozo69pd 1 Back to top Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5015139 Share on other sites More sharing options...
Rat_Punter Posted February 20, 2018 Author Share Posted February 20, 2018 Cheers for the advice peeps. I am utterly garbage at sculpting.... id struggle to sculpt a ball of bluetack! As to the spirit host point, nice! I think theyre my ticket! Low toughness, but surprisingly resilient :) Ill have to give them a go! Thanks again! Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5015321 Share on other sites More sharing options...
Rat_Punter Posted February 22, 2018 Author Share Posted February 22, 2018 Impulse bought the spirit hosts. They aint perfect but certainly will suffice! Ta for the input! O7 Commissar K. 1 Back to top Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5016652 Share on other sites More sharing options...
Mileposter Posted February 22, 2018 Share Posted February 22, 2018 You're probably going to want to cut them down a bit, so that they can at least emulate the height of the Nurgling's they're going to represent stat-wise. It'll also help their stability - they're modelled to come from a single piece rising from a grave/skeleton/etc, so cutting that down should give you a wider base to work with (also some extra bits to make them a little more to your liking). Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5016751 Share on other sites More sharing options...
Rat_Punter Posted February 22, 2018 Author Share Posted February 22, 2018 Yeh I never play tourneys so the size issue is down to opposition grace. As they have no shooting ability then it seems like I am the only one to have to work with a negative. If I go to a tourney ill just slap some nurglings down properly and to hell with my theme of khorne only... O7 Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5016791 Share on other sites More sharing options...
Mileposter Posted February 22, 2018 Share Posted February 22, 2018 Oh, I meant that less from a tourney point of view and more that I'm a perfectionist. >.>; Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5016817 Share on other sites More sharing options...
Rat_Punter Posted February 23, 2018 Author Share Posted February 23, 2018 Aaah fair play. I think the spirit hosts fulfil the idea that the very air wants bloody murder during a Khorne invasion!! Thus their height isnt so important to me. O7 Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5017613 Share on other sites More sharing options...
bozo69pd Posted February 24, 2018 Share Posted February 24, 2018 Another way to influence deployment well without dipping into Nurgle units is to bring Khorne Alpha legion... which just so happens to work great with berserkers and cultists! Infiltrate then charge! Very fluffy. Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5018542 Share on other sites More sharing options...
Rat_Punter Posted February 24, 2018 Author Share Posted February 24, 2018 Thats cool but can be shut down by scouts. The epic thing about Nurglings is that they deploy in normal sequence. I cant tell you the number of games where an enemy has placed a scout wall as his first two drops.... With no shooting to clear them off its an entire turn delay to bloodbomb. The alpha legion would not be be able to infiltrate in this scenario. O7 Link to comment https://bolterandchainsword.com/topic/344603-khorne-themed-nurglings/#findComment-5018618 Share on other sites More sharing options...
