Jackalwolf Posted February 25, 2018 Share Posted February 25, 2018 So just a little of an update to help out any fellow VI fans who are planning to buy and convert the Varagyr: ch Key learnings: It is possible to remove the heads but it does require for sure a Dremel and some precision, would be impossible or too long without it due to the amount of resin to take away in a very awkward placing to reach with conventional tools Even when successfully removing the heads, the braided beards are a massive problem and must be carved out very carefully with an X-acto knife, some of the sculpts will need some rebuilding of the studs in the collar since they´ll be impossible to save To re-sculpt the fur, first flat out the area by cutting the horrible fur, otherwise it´ll be too prominent I´ve found it extremely hard to sculpt fur accurately since the area is hard to access and the fang charms in the middle get in the way for the smooth downwards motions required to do good fur So unhappy with fur sculpting that will finish this since fur sculpting needs several layers for it to work and if I don´t like will proceed to clip out and replace with 3rd party fur loincloths Any Cataphractii arms work well with the kit TiguriusX, mercbat, Huggtand and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/ Share on other sites More sharing options...
Dantay VI Posted February 25, 2018 Share Posted February 25, 2018 Figured as much. Thanks for the update though. Will look out some heads got them. Glad to see great minds think alike re using Justaerin. Also thinking red butchers Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/#findComment-5019410 Share on other sites More sharing options...
Jackalwolf Posted February 25, 2018 Author Share Posted February 25, 2018 Yes any arms work well, so I´m going to actually arm them with Wolf Claw + Power fist. On terms of shoulder pads, the SOH upgrade cataphractii are perfect, just trim out the X and you´ll have an engraved VI, add squad designation before and in the other shoulder pad, carve out SOH symbol and decal in our own legion. You got any ideas on fur replacement? Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/#findComment-5019420 Share on other sites More sharing options...
Dantay VI Posted February 26, 2018 Share Posted February 26, 2018 Besides removing altogether and replacing with Sons of Thor pelts, or making molds from other pelts and cutting to fit then I would just do it the way you have been. It was my original plan for doing the pelts anyway :D Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/#findComment-5019607 Share on other sites More sharing options...
Jackalwolf Posted February 26, 2018 Author Share Posted February 26, 2018 So wasn´t happy with green stuff, too hard to sculpt in these awkward angles so ultimate fix: -"Ragnaaaar" - Rollo Turns off adding some good pelts goes a long way to making the Varagyr something awesome. Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/#findComment-5020253 Share on other sites More sharing options...
MaveriK Posted February 26, 2018 Share Posted February 26, 2018 Yes any arms work well, so I´m going to actually arm them with Wolf Claw + Power fist. On terms of shoulder pads, the SOH upgrade cataphractii are perfect, just trim out the X and you´ll have an engraved VI, add squad designation before and in the other shoulder pad, carve out SOH symbol and decal in our own legion. You got any ideas on fur replacement? http://www.greenstuffworld.com/en/inicio/675-texture-plate-wolf-fur.html?search_query=fur&results=11 Huggtand 1 Back to top Link to comment https://bolterandchainsword.com/topic/344768-varagyr-modification-summary/#findComment-5020296 Share on other sites More sharing options...
