Res Ipsa Loquitur Posted February 27, 2018 Share Posted February 27, 2018 Does anyone know of a commercially available Katyusha model that works within the GW aesthetic or can be made to work within it without huge amounts of effort? Also, if you looked across the table and saw Katyushas but your opponent said they were, say, Heavy Quad Launchers, would you have an issue with that? Link to comment Share on other sites More sharing options...
Inso Posted February 27, 2018 Share Posted February 27, 2018 One of these: http://c8.alamy.com/comp/EA56EK/moscow-russia-7th-nov-2014-a-katyusha-rocket-launcher-rolling-throughin-EA56EK.jpg Link to comment Share on other sites More sharing options...
Res Ipsa Loquitur Posted February 27, 2018 Author Share Posted February 27, 2018 Yeah, a Katyusha. Link to comment Share on other sites More sharing options...
Pendent Posted February 27, 2018 Share Posted February 27, 2018 Generally speaking I'm fine with however my opponent wants to proxy stuff, as long as it's consistent. For something like this I feel like a Manticore would fit a lot better since they're basically the same thing. Imperator Deus and walter h 2 Back to top Link to comment Share on other sites More sharing options...
Res Ipsa Loquitur Posted February 28, 2018 Author Share Posted February 28, 2018 I do too, and that was my initial plan; Basilisks and Manticores. However, my guys have committed some "light" treason and Renegades & Heretics can't take Manticores. Manticores don't look too much like Katyushas, either. Would you be ok with using Manticores to represent Heavy Quad Launchers, in-game? Link to comment Share on other sites More sharing options...
robofish7591 Posted February 28, 2018 Share Posted February 28, 2018 If you don't mind the taurox prime, one of those with the missile launcher load out has a sort of similar look to it. You could use it or proxy something else as a missile taurox. Link to comment Share on other sites More sharing options...
shandwen Posted February 28, 2018 Share Posted February 28, 2018 If wyvrnns are still ok that would be a reasonable fit rules wise, even if it's not a good unit. Link to comment Share on other sites More sharing options...
Noserenda Posted February 28, 2018 Share Posted February 28, 2018 Assuming you are still truck mounting them, a Quad launcher would be fine by me. Though the crew might just look like malingering guardsmen :D Link to comment Share on other sites More sharing options...
Pendent Posted February 28, 2018 Share Posted February 28, 2018 Hopefully this isn't too much of a derail but I keep hearing people talk about how Wyverns are bad- can someone explain this a bit? Looking at it from the outside they seem pretty solid. It's less shots than heavy weapons teams with mortars but has some fringe benefits that seem to me like they'd balance it out a bit like the increased toughness or smaller footprint making it easier to keep fully out of LOS Link to comment Share on other sites More sharing options...
Ulrik_Ironfist Posted February 28, 2018 Share Posted February 28, 2018 Hopefully this isn't too much of a derail but I keep hearing people talk about how Wyverns are bad- can someone explain this a bit? Looking at it from the outside they seem pretty solid. It's less shots than heavy weapons teams with mortars but has some fringe benefits that seem to me like they'd balance it out a bit like the increased toughness or smaller footprint making it easier to keep fully out of LOS The main problem with wyverns is not their shot output. They actually put out 1d6 more shots than a mortar squad. The problem is with points efficiency. Even with the Wyvern's ability to re-roll failed wounds, it still does less damage per point in cost than a mortar squad. A wyvern dishes out 1d6 more shots and rerolls of failed wounds, but at an increase of 70 points. Most players don't find that the wyvern does enough to make up for its cost, and it can't move and shoot effectively (unless tallarn). So Mortar squads are now once more a staple. I hope that answers your question. Does anyone know of a commercially available Katyusha model that works within the GW aesthetic or can be made to work within it without huge amounts of effort? Also, if you looked across the table and saw Katyushas but your opponent said they were, say, Heavy Quad Launchers, would you have an issue with that? I'd have an issue with quad launchers, simply because they're not vehicles and can't move. Now, if you paid points for a centaur along with that heavy quad launcher so you could move it, I'd be more ok. Unless you're doing it for aesthetic purposes, and not trying to move the launchers. As for the model, you could use the Taurox with a 6x6 wheel conversion and the launcher bits from a Manticore. That would actually look sick, and I'd love to see how you implement that. Here's a kit. I'm actually tempted to try that myself now, and use them as manticores... Link to comment Share on other sites More sharing options...
Res Ipsa Loquitur Posted February 28, 2018 Author Share Posted February 28, 2018 (edited) They would be Heavy Quad Launchers for all game purposes. The Taurox is a good idea, but I think I'd be ok with tracks. My army is 40k first, third-rate Red Army knock-off second. But now I look at it, I'm mindful of how much cheaper it would be to just buy the Taurox Missile Rack as bitz and make them ground units, rather than truck-mounted. Edited February 28, 2018 by Res Ipsa Loquitur Link to comment Share on other sites More sharing options...
walter h Posted February 28, 2018 Share Posted February 28, 2018 Check out ,Anvil for some parts. Link to comment Share on other sites More sharing options...
Emicus Posted February 28, 2018 Share Posted February 28, 2018 Put the manticore rack on a taurox? :p walter h 1 Back to top Link to comment Share on other sites More sharing options...
Inso Posted February 28, 2018 Share Posted February 28, 2018 Yeah, a Katyusha. I had to look it up. It always helps to add an image ;) Link to comment Share on other sites More sharing options...
Ranulf Posted February 28, 2018 Share Posted February 28, 2018 Yeah, a Katyusha. I had to look it up. It always helps to add an image I was a visualising a mustached soldier in a furry hat. Link to comment Share on other sites More sharing options...
Res Ipsa Loquitur Posted February 28, 2018 Author Share Posted February 28, 2018 Apologies, I assumed that everyone knew what a Katyusha was in this context. Mea culpa. As for moustaches, 'Katyusha' is a ladies name; an affectionate version of 'Katherine'. Link to comment Share on other sites More sharing options...
Colonel_ Logan Posted March 3, 2018 Share Posted March 3, 2018 I once made one for a Chimera from the old Gorkamorka/3rd edition tank trap and some hunter killer missiles. Res Ipsa Loquitur 1 Back to top Link to comment Share on other sites More sharing options...
